ARB Compressor Isolation Mount
Discussion in '2nd Gen. Tacomas (2005-2015)' started by HBMurphy, Dec 26, 2009.
  1. Dec 26, 2009 at 8:18 PM
    HBMurphy
    HBMurphy [OP] Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
    So maybe I'm anal :anonymous: but I wanted to mount my ARB High Volume compressor on a isolation mount to minimize the buzzzzzzz :lalala: that the compressor makes and who knows, maybe extend the life of the compressor.
    Compressor Buzz
    http://www.youtube.com/watch?v=pu-fdyYgp2g
    First I made a hat section out of some steel stock from Lowes. I didn't have a brake so I had to make due with a hammer, a vice and some peices of wood. I think it came out half-way decent considering I was using farm methods.
    Next, being that I am so green ;), I went to my local tire shop and collected my, now favorite isolation bushings - these are actually the rubber that they cut off from the valve stems to remove them. I like em! :D
    Next I drilled some holes (taped the flanges with hammer to transfer location of the 3 studs on passenger side fender well and used the ARB backing plate to locate the ones for the compressor).
    Note that I drilled out the ones for the compressor to 1/2 inch so that they would be large enough so that the bracket would not touch the bolts when I tightened them. A little primer, 2 coats of gloss black, a little time in my oven...
    I put two of my new favorate isloation bushings on each compressor mounting bolt (one above the bracket with round end down and one below the bracket round end up). Then I tightened the compressor mounting bolts so that 1.5-2.0 threads are showing.
    Tomorrow I'm going to mount this thing in my truck, wire it up and see how buzzworthy the mount is or isn't. :turtleride:
    Oh yeah, sorry for the cell phone pics! :p
  2. Dec 26, 2009 at 8:51 PM
    HBMurphy
    Paul
    So California Coast
    None
    Yeah... You've got a great rig with a great attention to detail! I'm jealous - I still want to see the tigerfan paint job!!!
  3. Dec 27, 2009 at 8:10 AM
    HBMurphy
    Paul
    So California Coast
    None
    Thanks. I would love to have a york with a clutch running off the engine but I just can't see it fitting unless there's some major juggling of things up front. :(
    But once again, you do it right and your ocd is really working for you! ;)
  4. Dec 27, 2009 at 10:08 AM
    silver07taco
    silver07taco Well-Known Member
    COIL
    Maryland
    13 Tundra RCSB 5.7 4x4,07 Tacoma AC 4.0 4x4
    2013 Tundra RCSB 5.7 4x4, 2007 Tacoma AC 4.0 4x4
    Nice work, I might try to do something like that for my viair in my tool box.
  5. Dec 27, 2009 at 4:08 PM
    HBMurphy
    Paul
    So California Coast
    None
    I feel your pain. I just did a 1 hour job that should have taken 15 minutes. Didn't like the idea of crimping electrical connections when I had perfectly good soldering iron, shrink wrap and heat gun!!! ;)
  6. Aug 9, 2010 at 10:55 PM
    Santi
    Santi Active Member
    Santiago
    Baja, MEXICO
    2005 4WD TRD Off Road Tacoma 6 Spd Short Bed
    JBA headers, TRD exhaust system, Air Aid Throttle Boady Spacer, AFE Cold Air Intake, Fitch Fuel Catalyst, Weathertech floor liners, Wet Okole seat covers, I-pod jack, Tuffy steel bed tool box, SUNGtop Camper Shell, ARB high output air compressor, Total Chaos UCA´s, BILSTEIN heigth adjustable shocks.
    Hello I just installed the High Output ARB air compressor in ´05 4WD TRD Off Road Toyota Tacoma,And I wonder if you can give me a hand sending me some pictures of how should I connect the air hose for the tire inflation kit, I am kind of lost with all the fitting, since my Tacoma has the rear TRD electric locker, I am using the air compressor only as an accessory, for the moment I have no intentions to install a front ARB.
    Can you please guide me on this little issue?
    Best regards
    Santiago Olachea
    santiago.olachea@gmail.com
  7. Aug 9, 2010 at 11:26 PM
    HBMurphy
    Paul
    So California Coast
    None
    I don't have that option installed but I know someone that does - let me get a picture from him and hopefully I can post tomorrow.
  8. Aug 10, 2010 at 11:18 AM
    Santi
    Santi Active Member
    Santiago
    Baja, MEXICO
    Thanks, I really hope you can give me a hand, I emailed ARB in the USA yesterday and they have no reply yet.
    But it is always great to get the information from the real world of off roaders and Tacoma drivers.
    Thanks
    Santi
  9. Oct 14, 2010 at 11:25 AM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    I know i know thread revival blah blah...did you ever post pics on the install?
  10. Dec 14, 2010 at 1:36 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    bump for more pics.
  11. May 26, 2015 at 6:16 PM
    Pigpen
    Dan
    Northwest Montana
    Moar pics pleeze! Compressor en route...
    Yes, bringing this one back from the dead - looking for anyone's under the hood install pics.
