ARB compressor wiring assistance
Discussion in '1st Gen. Tacomas (1995-2004)' started by Jguardino, Jul 19, 2020.
  1. Jul 20, 2020 at 8:48 PM
    Jguardino
    Jguardino [OP] Well-Known Member
    jacob
    209
    01 Dbl cab, 22 TRD OR PREM
    not a bad idea once I get it figured out. I’m just trying to find the right fuse to tap into. I’ve gotten it to run for a few seconds off some 12v fuses but idk. I do think taking out the locker wiring would be nice since I’ll never use it
  2. Jul 20, 2020 at 8:49 PM
    Jguardino
    jacob
    209
    I found somewhere online it should be 15, I tapped a couple different 15s and the switch would light & compressor would run for a few seconds and turn off. One day at a time
  3. Jul 20, 2020 at 8:54 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Hmm, that's odd.
  4. Jul 20, 2020 at 8:54 PM
    02hilux
    Planet: EARTH
    It's suppose to turn off once the tank receives enough pressure. The mid size compressor will engage for about 2-3 second only
  5. Jul 20, 2020 at 8:55 PM
    Jguardino
    jacob
    209
    i made sure to put the original fuse first also. Yeah idk.
  6. Jul 20, 2020 at 8:56 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    I've made that mistake before, putting the stock fuse in the wrong spot.
  7. Jul 20, 2020 at 8:56 PM
    Jguardino
    jacob
    209
    oh really? I figured there’s no way it can be max in only a couple seconds... but I won’t be suprised if I’m wrong
  8. Jul 20, 2020 at 8:58 PM
    02hilux
    Planet: EARTH
    Don't take much if you're not cycling the tank. Try hooking up an air line and and inflating a tire and see if thre compressor will engage again (make sure to turn comp on)
    BartMaster1234 likes this.
  9. Jul 20, 2020 at 9:11 PM
    02hilux
    Planet: EARTH
    Mine cycle off in about 3 seconds if I don't engage the lockers. Once the locker is activated, the compressor engages for another 2-3 second. Because the air in the manifold got diverted to the line and locker and the compressor must refill the manifold.
  10. Jul 20, 2020 at 9:33 PM
    Jguardino
    jacob
    209
    I’ll def try tomorrow and get back
  11. Jul 20, 2020 at 9:39 PM
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    The fuse for the original circuit stays the same. The fuse requirements for the new switches can be found right in the installation guide. Page 13.
    The compressor runs for only a couple seconds as the manifold it's pressurizing is extremely small. Again, understand what it is that's going on and don't assume things are functioning wrong just because you don't yet understand what proper function is. Do some testing and investigation and reading before assuming.
    I installed a cheapo analog pressure gauge in my manifold. No guessing needed.
    Jguardino[OP] likes this.
  12. Jul 21, 2020 at 7:17 PM
    Jguardino
    jacob
    209
    you were correct thank you. I found a fuse and it runs 12v key turned and 0v off. Works good I just didn’t know why it shut off so quick. Thank you for the help
  13. Jul 22, 2020 at 11:16 PM
    Jguardino
    jacob
    209
    Welp it was working yesterday just fine. Trimmed the compartment for the switch, replugged and it wouldn't work and a 10amp fuse blew on the add a circuit. Back to retracing. Always something when learning
    hornito likes this.
  14. Aug 2, 2024 at 2:55 PM
    spicy_fish_taco
    spicy_fish_taco Well-Known Member
    '18 2.7L Taco 4x4 Access Cab
    any update? my 10amp fuse keeps blowing. was working fine for a year with a add-a-fuse hooked up to the ignition spot inside under the drivers side fusebox. ignition fuse is also 10amp
    hornito likes this.
