Arb compressor wiring
Discussion in 'Technical Chat' started by m.reed.1, Nov 14, 2014.
  1. Nov 14, 2014 at 7:22 AM
    m.reed.1
    m.reed.1 [OP] Well-Known Member
    Adam
    Sacramento, CA
    2015 MGM TACOMA TRD OFFROAD 4WD
    A few
    Hi. I have the arb ckma 12 compressor. Wandering how can I wire it without using a harness. I bought the compressor second hand without the harness and only will be using it for on board air. Any help will be greatly appreciated. ImageUploadedByTapatalk1415978570.999940.jpg
  2. Nov 14, 2014 at 7:27 AM
    Large
    Large Red
    Install a switch in the cab >
    Run hot from battery to switch >
    Run hot from switch to hot wire of compressor >
    Ground compressor >
    Make sure you use a properly rated fuse, you can get the amperage off ARB'swebsite.
    Drink a beer.
  3. Nov 14, 2014 at 8:07 AM
    m.reed.1
    Adam
    Sacramento, CA
    A few
    What about the pressure switch and relay?
  4. Nov 14, 2014 at 8:10 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Make sure that the switch can handle the amperage without melting down, I had that problem once. Best to use a relay to handle the high amperage of the compressor.
    Is this compressor the one used for the air-lockers? If so, it will take a real long time to air up. Be fore-warned.
  5. Nov 14, 2014 at 8:11 AM
    m.reed.1
    Adam
    Sacramento, CA
    A few
    It's the next one up from the small one just for lockers. It also is rated to air tires. I have the original arb switch, just trying to figure out a wiring diagram I can make to incorporate the relay and pressure switch.
  6. Nov 14, 2014 at 8:24 AM
    Large
    Large Red
    The compressor has a hot (Red/Wht) and a ground (Blk), there is also a pressure switch on the compressor with 2 wires (Red & Red/Wht). The red and white you can crimp / solder together, the black goes to ground, the solid red goes to the switch which the switch gets its power from the battery.
  7. Nov 14, 2014 at 8:25 AM
    Large
    Large Red
    Make sure to use a fuse, I think it's 30A for your compressor.
  8. Nov 14, 2014 at 8:27 AM
    m.reed.1
    Adam
    Sacramento, CA
    A few
    Gotcha. Will do this today and update. Thanks for the help!
  9. Nov 14, 2014 at 9:22 PM
    clc clc
    clc clc Well-Known Member
    PA
    2012 4x4 reg cab tacoma/2020 subaru crosstrek
    I don't mean to derail the thread but you'r post gave me some ideas as I have the same compressor. The quick connect for the hose is run off the compressor itself, could you spit that and have one in the front and rear of the vehicle? I plan on running the compressor in my bed cubby. Also, how well dId the ARB switch fit?
  10. Nov 15, 2014 at 8:49 AM
    Large
    Large Red
    Run separate quick connects on the tank you will use, or run some 1/4" SS tubing to a quick connect and mount one in the front and one in the rear and use a 'tee' fitting.
