ARB Differential Breather Mounting
Discussion in '1st Gen. Tacomas (1995-2004)' started by Wanderlust Bus, Jul 13, 2022.
  1. Jul 13, 2022 at 3:18 PM
    Wanderlust Bus
    Wanderlust Bus [OP] Well-Known Member
    Small Lake City
    2002 TRD Off Road
    So after blowing out my rear axle seals after a river crossing, I decided to get the big ARB differential breather. I find myself in water, snow, ice, and mud pretty often so moving the breather up somewhere higher probably is a good idea.
    Does anyone else have this breather? I'm trying to find a good place to mount it that is easy to access for cleaning. I'm thinking up under the hood nearby the front differential breather. Where do you all mount yours?
    https://www.amazon.com/dp/B00QBQYNF0
  2. Jul 13, 2022 at 6:00 PM
    okolesniffer
    okolesniffer Active Member
    02 tacoma DC 2.7L
    Timmy the Tool Man did his breather mod into the rubber grommet surrounding his gas tank filler neck, though he doesn’t use the ARB kit and honestly it might save you a couple bucks if you don’t too.
    Here’s a link: https://youtu.be/tCGMa4vng_g
    Other than that, near the front diff breathers would be fine too :)
  3. Jul 13, 2022 at 6:11 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Just be aware this system with a filter should be someplace warm the moisture in the filter could freeze on those frosty mornings if you venture into the mountains..
    Engine compartment for the win.
  4. Jul 14, 2022 at 11:28 AM
    Wanderlust Bus
    Small Lake City
    2002 TRD Off Road
    I never even considered the possibility of it freezing. You just helped me make up my mind. Good thinking.
  5. Jul 14, 2022 at 11:34 AM
    02hilux
    Planet: EARTH
    Why? Is it because you want ARB? You can vent both front and rear for ~25 buck. That price includes new hose, vents, clamps, the whole 9 yard.
  6. Jul 14, 2022 at 11:40 AM
    Wanderlust Bus
    Small Lake City
    2002 TRD Off Road
    Well, mostly because I didn't do enough research before I bought it. When I bought the ARB I didn't realize the transfer case already had a vent higher up so my plan was to connect both to the ARB. Second is because I bought the ARB last summer and I'm finally getting around to installing it and now it's too late to return it.
    :facepalm:
    Bivouac likes this.
  7. Jul 14, 2022 at 1:50 PM
    Bivouac
    I venture we all have bought things without enough thought at times.
    I know I sure have.
    In most cases just extending the vent hose up to the bottom of the bed is enough.
    Unless you pretend your Tacoma is a boat to often .
  8. Jul 15, 2022 at 11:50 AM
    Old green toyota
    Old green toyota Well-Known Member
    Sacramento,CA
    99 2.7 4x4 Standard cab
    Oil leaks
    Fuel pocket is where I routed the rear, front is just extended. I also blew seals out from a very mild water crossing.
  9. Jul 15, 2022 at 4:09 PM
    Bivouac
    When you think about seals most are set up to seal in one direction . Why a blocked vent allows the pressure to vent at the easiest place.
    Then to keep liquid from getting through a few pounds of water pressure would push right past.
  10. Jul 15, 2022 at 4:23 PM
    Extra Hard Taco
    Extra Hard Taco Well-Known Member
    R.J.
    Devil's Island
    2012 Tacoma TRD OR, 2007 DC (sold), 2003 TRD OR (sold)
    ARB Bumper, SOS sliders, SOS rear bumper, SOS skid plate. OME Lift. Some other stuff.
    Not ARB but I mounted mine in the gas tank filler area. I think running it from the rear diff to the engine compartment is too far.
