Arb front locker?
Discussion in '1st Gen. Tacomas (1995-2004)' started by shawnster88, Jul 8, 2018.
  1. Jul 8, 2018 at 5:55 PM
    shawnster88
    shawnster88 [OP] Well-Known Member
    Shawn
    Defuniak Springs, FL
    96 Tacoma Reg cab 2.7 5 speed
    OME 881 coil springs, OME nitrocharger sport shocks front and rear. Nitro 4:56 gears. ARB rear locker. Shrockworks front bumper with Warn M8000S winch. 17x9 SCS Ray 10 wheels w/ 285/70/17 Toyo Open Country RT Trail tires. Corbeau Trailcat bucket seats. Go Rhino roll bar w/ KC Daymaker lights. GMRS Radio. Ham Radio.
    Anyone here running ARB front locker on a IFS? If so, have you had any problems with the cv shafts breaking with it locked off-road? About to order some for the rear and maybe the front. I have the 7.5” clamshell ifs front with manual hubs.
  2. Jul 8, 2018 at 9:10 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Just dont be stupid ...works great. Have used it a few times. The rear arb usually does the job. Love having the front, just in case
    Prayn4surf and stumbles like this.
  3. Jul 8, 2018 at 9:51 PM
    v5ensx
    v5ensx CARB legal is not CALI legal
    Why not try tjm prolocker?
  4. Jul 8, 2018 at 9:55 PM
    stumbles
    stumbles 1 eye
    bryan
    mesa
    2002 White Double Cab
    Works great. Have used mine a lot in the rocks. Just turn it on when needed and off right after.
  5. Jul 8, 2018 at 9:58 PM
    eon_blue
    Azusa, CA
    @Prayn4surf has one up front IIRC
    Just have to be careful when using it and you should be fine. If you're running huge heavy tires it makes it more of a risk but if you're on stock size or 33s you should be okay.
    Having a selective locker up front is key with IFS suspension....auto lockers (Spartan, Detrioit, Lockrite, etc.) are attractive because they're cheap but they are much more risky on an IFS drivetrain.
  6. Jul 8, 2018 at 10:10 PM
    Prayn4surf
    Prayn4surf 20 minutes late
    Socal
    2004 Tacoma xtra cab
    I have a harrop, but same same, dont leave it on n turn too much at all, just use it when needed and you will love it! Auto lockers arent the best thing to do imo.
    eon_blue[QUOTED] likes this.
  7. Jul 8, 2018 at 11:06 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I've been running mine for about 4 years (~40K miles) with no ADD axle troubles. I use it sparingly tho, only engage it to clear the obstacle and little or no turning. Takes huge effort to turn anyway. Tells you something right there.
    Prayn4surf likes this.
  8. Jul 9, 2018 at 7:32 AM
    shawnster88
    Shawn
    Thanks for the replies. I’ve never had a locker before. I’m only running 265/75/16. Being the stock cv axle shafts are the weak link I wasn’t sure if I’d regret putting it in the front and snapping axle shafts. Thanks again.
  9. Jul 9, 2018 at 8:24 AM
    Prayn4surf
    Socal
    Id put one in the back first or both if your opening your diffs up. A rear locker gets you places. A rear locker doesnt have to be used as sparingly and I use mine quite often. I do the same as @Digiratus and only use my front on certain obstacles that require it and no turning really. It is super hard to turn while locked in the front and doing a lot of that will snap a cv id imagine. Better a cv than your gears though.
  10. Jul 9, 2018 at 8:47 AM
    shawnster88
    Shawn
    Cool... I’m doing both.
  11. Jul 9, 2018 at 8:59 AM
    Prayn4surf
    Socal
    You will be super happy with that decision!
  12. Jul 9, 2018 at 5:10 PM
    otis24
    otis24 Hard Shell Taco
    Mark
    California
    OtisBound Outdoors Bodonkadonk
    OtisBound Bodonkadonk
    I’m on the same boat. I’m gonna regear soon and am debating getting a front locker. I have the rear e-locker and use it frequently.
  13. Jul 9, 2018 at 5:30 PM
    shawnster88
    Shawn
    I regeared last summer. Didn’t have the funds for lockers then and really didn’t think I needed them. Been doing more more off roading since and have realized I do need them. I did the gears myself so not looking forward to pulling everything apart again. But kinda excited about it too. Probably order both locker in the next couple weeks and put them in when I got time and looking for a project.
    otis24[QUOTED] likes this.
  14. Jul 9, 2018 at 5:58 PM
    otis24
    Mark
    California
    For sure.
    One thing about a front locker is I’d lose some fitness from less rock stacking.
    I’m gonna do the ECGS 3rd member and do the work myself as well. I’m only gonna do it once so I might as well put in a locker. Or put the money toward other things. Still undecided.
    Most likely what will happen is I’ll put the order together and say F’ it at the least second and get it.
  15. Jul 9, 2018 at 9:21 PM
    Digiratus
    Roaming the PNW
    The RedHead
    If you are going to open up the front clamshell anyway, it makes no sense to not put an ARB in there. Most places that do it don't charge any additional labor to install the ARB either.
    Another factor for me was the locker actually makes the weak 7.5" front diff stronger by replacing the spider gears.
  16. Jul 9, 2018 at 9:47 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    I might be wrong but if you're changing the stock carrier with an ARB you should only have to set the backlash again. The pinion depth shouldn't change, so it shouldn't be too bad.
  17. Jul 10, 2018 at 5:11 AM
    shawnster88
    Shawn
    That’s what I’m understanding also. Pinion shims was a major PITA!
  18. Jul 10, 2018 at 6:01 AM
    otis24
    Mark
    California
    Yeah, ECGS doesn't charge anymore for shipping the third member and I'm doing the rest of the work myself. Still need to mount the compressor, run the hose, run the wires, mount and install the switches.
    The Locker plus ARB compressor, manifold and switches should run a bit more than $1200. I could use that for all kinds of other things. I do wheel a bit here and there. I'm just not sure I wheel enough to warrant that much money.
    Another advantage is having a nice mounted compressor. I have CO2 tank plus a back up compressor now, but having it mounted to the truck and not having to refill CO2 would be nice.
  19. Jul 14, 2018 at 10:58 AM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    ARB / thread over. do it..
  20. Jul 14, 2018 at 11:07 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    There are many schools of thought that range from "open diffs are more likely to cause CV breakage because of spinning wheels" to "lockers cause more breakage because of the added traction (i.e. stress) on the drivetrain" to everywhere in between.
    As others have said, in this thread and others, IFS lockers CAN work great. I've heard of enough people that put a locker in and start breaking shit to give me pause, however.
    Your weak points will be the CVs, so carry spares - maybe practice replacing them at home with your "trail tools"... Probably a good idea to carry a spare CV locked or not, though...
    I think an LSD is a great compromise, might be worth looking into one...
