Arb front locker?
Discussion in '1st Gen. Tacomas (1995-2004)' started by shawnster88, Jul 8, 2018.
  1. Jul 16, 2018 at 5:48 PM
    #41
    License2Ill
    License2Ill Woke like a Coma Toyota Tacoma
    Ian
    It's a dry heat thou, AZ
    2004 SC'd 5VZ DC 5spd 4x4 TRD.GOV
    Bailing wire & Duct tape
    Yeah. Well with manual hubs you get .01 better mpg's. Ha.
    But with manual hubs you can basically drive home with a busted CV. And it's not completely necessary to carry trail spares. Unlike ADD hubs. Where you're not going anywhere without a replacement CV.
    If you have one tire in the air with a trutrac, the tire in the air gets 100% traction. In that scenario you can use the e-brake to get the trutrac fooled into giving traction to the tire on the ground.
  2. Jul 16, 2018 at 5:57 PM
    #42
    License2Ill
    Ian
    You can convert ADD spindles to manual hub spindles. That's how my 04 has them.
  3. Jul 16, 2018 at 6:59 PM
    #43
    eon_blue
    Azusa, CA
    I have ADD and busted a CV once and was able to drive in 2wd just fine for a few miles until I got to where I could pull off and replace it with a spare I had. Of course in 4wd it was clunking like mad while busted but when I disengaged 4hi and went into 2wd, it went away and was seemingly normal. It had busted in the inner tulip.
    But yeah I would hate to have manual hubs and risk breaking the hub assembly too, especially somewhere remote.
  4. Jul 16, 2018 at 7:14 PM
    #44
    License2Ill
    Ian
    Yep. Wish I'd of known before I converted.
  5. Jul 16, 2018 at 7:32 PM
    #45
    UnderFire
    UnderFire Well-Known Member
    You'd have to have the manual hub part though, which is the tough part to get a hold of.
  6. Jul 16, 2018 at 8:00 PM
    #46
    License2Ill
    Ian
    Are talking about the hub dial? You can buy them for $140 all day long.
  7. Jul 16, 2018 at 8:38 PM
    #47
    charliegt35r
    charliegt35r MALL CRAWLERs
    CenCal
    2003 tacoma dc
    OME 2.5 LIFT 285/75/16
    The cost is 1500+ havent seem anyone running them
  8. Jul 16, 2018 at 9:58 PM
    #48
    UnderFire
    No, the actual hub that's pressed into the spindle is what gets messed up, I believe it's like 170$ from the dealer for a brand new one, then you've gotta buy new bearings and have it all pressed together. Probably a 500$ deal using all new parts. Junkyard ones are tough to come by.
  9. Jul 17, 2018 at 12:05 AM
    #49
    License2Ill
    Ian
    Yep, you're correct. It can be expensive when you bust a manual hub CV. But all the new parts are (for now) easy to find.
    Used to be cheaper when you could buy the bronze bushings separately. That's the most likely part to damaged on the hub assembly.
    I drove 500 miles home on a busted birf stub and only needed to replace the hub dial assembly and birfield. $200.
  10. Jul 17, 2018 at 8:02 AM
    #50
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    That doesn't explain how the E-brake (which operates the rear) affects the front TruTrac?
    I remember a guy back in the day dragging his foot brake, but not the e-brake.
  11. Jul 17, 2018 at 9:38 AM
    #51
    snotaco
    snotaco Well-Known Member
    Lewiston, Idaho
    2003 prerunner tacoma
    2003 tacoma double cab, prerunner, 4wd conversion, 5 speed conversion, dual cases with inchworm clockable adapter, toytec ultimate coil overs, trd supercharger with urd 7th injector, 37 inch mastercraft mxt's, arb front locker
    running manual hubs, with arb front locker on 37s, and supercharged with a 5 speed and duals. have no issues with the shafts breaking (except for jumping in the sand dunes last summer) i was having issues with the outer cages exploding at full turn and throttle until i welded on bigger steering stops to limit how open the cage can be, since then i have not broke anything. all about learning why there is a weak point, and upgrading it
    https://youtu.be/uxObymWbg4c
    BassAckwards likes this.
  12. Jul 17, 2018 at 10:17 AM
    #52
    License2Ill
    Ian
    That's the best explanation you're going to get from me. If you're that interested in the specifics you can always Google it.
  13. Jul 17, 2018 at 10:27 AM
    #53
    jbrandt
    Justin
    I have, granted that recently, but the last I remember reading is that for a front trutrac, you drag the brake pedal, not the e-brake because that only works on the rear.
  14. Jul 17, 2018 at 10:41 AM
    #54
    Wulf
    Wulf no brain just damage
    rock raisin
    I get 2-3 MPG improvement with the hubs unlocked.
    As for the original topic: you can easily break a CV with and open diff if you are spinning a tire and then it suddenly gains traction. Having a locker will make it easier to gain traction and break a CV in that scenario, but if you have a locker you should be avoiding wheel spin anyways.
  15. Jul 17, 2018 at 11:17 AM
    #55
    License2Ill
    Ian
    I guess you meant to say 'not that recently'?
    I've only used the e-brake technique twice after I busted a CV going up Surprise Canyon up in the Panamints outside Deathvalley. It seemed to work. That road isn't very 2wd accessable.
  16. Jul 17, 2018 at 11:19 AM
    #56
    Wulf
    rock raisin
    I think RCV is the only one making aftermarket shafts but they are spendy.
  17. Jul 17, 2018 at 11:21 AM
    #57
    Wulf
    rock raisin
    I'd reccommend signing up for pirate4x4 and PMing vendors in the Axle section with what you are looking for. They don't post prices publicly and I think it is because they are below the manufacturer's set minimum advertising price.
  18. Jul 17, 2018 at 11:23 AM
    #58
    jbrandt
    Justin
    haha, yes, "not that recently"...
  19. Jul 17, 2018 at 11:25 AM
    #59
    snotaco
    Lewiston, Idaho
    unless something has changed super recently, rcv doesnt make shafts for our first gen tacomas
  20. Jul 17, 2018 at 11:58 AM
    #60
    Wulf
    rock raisin
