ARB front/rear lockers on a Gen 3 Tacoma Sport?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Edslittleworld, Nov 11, 2023.
  1. Oct 5, 2024 at 6:48 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    An expensive but easy solution that doesn’t affect the wiring would be to order up a used 4x4 non-locker 4WD ECU. For 2019, that would be 89533-04030. Plug and play and everything would remain exactly as is except the locker button on the console would no longer do anything.
  2. Oct 5, 2024 at 8:44 PM
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    You need to spoof the existence of the locker solenoid so the start-up check is satisfied.
    https://www.tacomaworld.com/threads...g-rwd-with-locker.785879/page-6#post-28149898
    danielgonzzz and Ricardo13x like this.
  3. Oct 6, 2024 at 6:11 PM
    TAROist650
    TAROist650 Member
    2019 Black TRD Off Road 4x4
    Bilstein 8100 & 8112 Icon Billet Aluminum Delta Joint UCA & RXT Leaf Springs QEM Pro Grill Cali Raised Catalytic Converter Shields
    Thank you!
