ARB Locker Group Buy - Nov 2014
Discussion in 'Group Buys' started by Nitrag, Oct 13, 2014.
Thread Status:
Not open for further replies.
  1. Nov 15, 2014 at 9:53 PM
    #221
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    :rofl:
    Keep the front sway bar attached? Dude ifs is shitty enough. It doesent need any more help being useless.
    Cvs are actually not absurdly strong, neither is the 7.5" clamshell. But I will enjoy the challenge an make do
  2. Nov 16, 2014 at 6:40 AM
    #222
    SGTCap
    SGTCap Well-Known Member
    Cap
    Summerville, SC
    4x4 6-spd,
    37s, 4x4 6-spd, OME 886s, Allpro Expos, SOS sliders and front/rear bumpers,Rack,Skids, 4.56s, Lockers,Recon Winch, TJM RTT, Lots of tools, boxes and gear. Shaggy mutt behind the seat
    That brings up a good point, where is a good place to order CVs from?
  3. Nov 16, 2014 at 9:26 AM
    #223
    overlanderaz
    overlanderaz Well-Known Member
    Phoenix
    2013 SR5 4x4 SC'd
    35" tires, 6"lift, Volant cold air intake, Magnuson SC, 2.4" pulley, AEM Methanol Injection, AEM 340LP, Cam Exhaust Gears, HD-SKO Rock Sliders, ARB compressor, RTT, LED lighting, ARB Lockers, and 4.56 gears.
    Thanks for the education bro :D
    However, you only need one front wheel on the ground when you have a locker. That is kind of the engineering philosophical debate of Tacoma front ends...to improve suspension and articulation...keeping both wheels on the ground or to accept the articulation for what it is and install a locker to overcome the inadequacies of the Tacoma IFS.....That's why we are going with lockers...after all, if both front wheels are squarely and evenly planted on the ground lockers are useless.
    And absolutely yes, if you can limit the angle of CVs they will remain and CVs are extremely strong, although the clamshell is not (which was not part of the comment).
    CVs strength exponentially decreases as the angle of operation increases. This is caused by a reduction in their contact area when pushed to the extremes of their travel. Perhaps you should brush up on your calc I/II classes and calculate the torsional strength of a Tacoma hardened half-shaft and its corresponding cv joint; unless you are not familiar with stress analysis testing....as I am.
    They are not weak just because you know a guy with a mullet (sorry mullet headed friends) that broke a CV on the trail doing something he did not mechanically understand and then later gave a campfire dissertation on the weakness of cv joints because they come stock on his girl friends Honda Civic.
    With that being said, watch out for axle wind up....it will snap any CV joint given the opportunity with 35" plus tires and perfect traction.
    I would laugh back at you, but there is nothing funny about your affliction. ;) Why you mad bro? :D
    Have a good one.
  4. Nov 16, 2014 at 9:56 AM
    #224
    Nitrag
    Nitrag [OP] Well-Known Member
  5. Nov 16, 2014 at 10:05 AM
    #225
    overlanderaz
    Phoenix
    2013 SR5 4x4 SC'd
  6. Nov 16, 2014 at 12:57 PM
    #226
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    Im mad because my truck is ifs and will remain so for a little while lol.
  7. Nov 16, 2014 at 1:14 PM
    #227
    Danjor2
    Danjor2 Well-Known Member
    Daniel
    Riverside
    01 Limited Double Cab Prerunner
    Got mine ordered yesterday! What is the average cost to get a rear locker installed?
  8. Nov 16, 2014 at 1:19 PM
    #228
    Nitrag
    $700 - 1000 deepening on a few factors. You can install and wire most of the compressor and switches to save some cash and bring it down a bit. I'm hoping for around $550 to do locker into diff and I'll have already done the rest.
  9. Nov 16, 2014 at 5:26 PM
    #229
    Danjor2
    Daniel
    Riverside
    Thank you!
  10. Nov 16, 2014 at 6:39 PM
    #230
    bayareataco
    bayareataco Well-Known Member
    Jimmy
    Petaluma
    2021 Tacoma TRD OR
    Do the switches come with the units?
  11. Nov 16, 2014 at 9:24 PM
    #231
    Jiveydude
    Jiveydude Well-Known Member
    Micah
    OH
    04Taco
    Stuff and things that make it better.
    Yes.
  12. Nov 16, 2014 at 10:15 PM
    #232
    SnowroxKT
    SnowroxKT Well-Known Member
    Kyle
    Anchorage Alaska
    2008 TRD OR
    FYI if you take out your own diff the prices will drop a lot, a local shop quoted me about 100 for the rear install. (Just the differential work)
  13. Nov 18, 2014 at 7:13 AM
    #233
    V5ioV
    V5ioV My drinking team has a wheeling problem
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    King 2.5 Rem Resi Ext Travel w/comp adj w/700# springs, TC Uni-Ball UCAs, ARB/OME Dakar Leaf Springs w/ King 2.5 Rem Resi w/comp adj and custm eyelets, Stealth Custom Series F-5 Wheels wrapped on: 285/75/16 Fierce Attitudes, BORA 2.25 wheel spacers, GOODRIDGE extended Brake lines, Triple-6" Double Row LED Light Bars behind lower grill, ATFL MOD, TRD Ball Type Shift Knob, Husky WeatherBeater Floor Liners, 60'' HiLift Xtreme, 4xInnovations Bolt-On Sliders w/Kickout, Spring Hanger Skid, Custom BlackPipe Fabs CMC and custom FYL Bed Rack, CVT Mt. Shasta RTT, Trasharoo, 4xInnovations HiLift Bedside Mounts, 4xInnovations Front Skid Plate, TOYWERX Ghost Raptor thin-lip Satoshi Grill, RedLine Hood Struts, 4xInnovations Transmission Skid and T-Case Skid Plates, Wheelers Rear SuperBumps Bump Stops, All-Pro Off Road U-Bolt Flip Kit, UltraGauge, ARB OBA, Pelfreybilt HC rear Bumper, Rotopax system (Single Mounting Plate and Bed Rail Mounting Plate both with LOX handles.
    Quick question....
    I received an email on the 14th that my order was completed and shipped, but never received an actual tracking #. I also checked under "my account" on their site and it states the same "shipped" but can't find a tracking number.
    Did anyone get or sees their tracking # on their account?
  14. Nov 18, 2014 at 7:24 AM
    #234
    Nitrag
    There were a couple emails. One had just a link to FedEx tracking (unhelpful) and another email had the actual tracking number. Look for "Your order (13345) Updated" email.
  15. Nov 18, 2014 at 7:33 AM
    #235
    V5ioV
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    Neither of the 2 email I received have a #, but Chase reached out and is going to get it for me.
    ...and again, Thanks for all the leg work you put on this gb, you really stayed son top of it dealing with a ton of PMs and in-thread questions... and Thanks to ECGS for the GB
  16. Nov 18, 2014 at 9:29 AM
    #236
    Russtoy
    Russtoy Well-Known Member
    Russel
    Ohio
    2000 4Runner SR5
    Damn...I can't believe I missed this!! Any chance they'll reopen this or let in a few stragglers??
    Thanks
    Russel
  17. Nov 23, 2014 at 8:45 PM
    #237
    otis24
    otis24 Hard Shell Taco
    Mark
    California
    OtisBound Outdoors Bodonkadonk
    OtisBound Bodonkadonk
    I have the opposite feeling. I'm glad it's over. I held out....barely.
  18. Nov 24, 2014 at 2:22 PM
    #238
    Pcyc
    Pcyc Self Proclaimed Leader
    Fritz
    Concord, CA
    09 DCSB TRD OR - Supercharged - Dual Cased - Twin Sticked
    https://www.tacomaworld.com/threads/pcyc-fj40-build.444289/ https://www.tacomaworld.com/threads/pcycs-2nd-gen-build.308160/
    Any word on drop ship date?
  19. Dec 3, 2014 at 10:27 AM
    #239
    tacomacrazy
    tacomacrazy ExPo Truck
    Bryant
    Coral Gables, FL
    07 DC 4x4 TRD Offroad
    HIDs 10k & 3k, AFE Intake, LEDs Red Map & dome, Pioneer 4300 Walker Evan 2.5 coilover 2.0 rear with all pro expo leaf pack. SnugTop Campershell Famous Fab rear bumper/ tire carrier. Dual Battery System Upgrade 250a Alternator
    Hey where are you guys planning on mounting the air compressor?
  20. Dec 3, 2014 at 11:44 AM
    #240
    SnowroxKT
    Kyle
    Anchorage Alaska
    2008 TRD OR
    Passenger wheel well. I dont have ABS, so it is a perfect spot.
Thread Status:
