ARB Locker Group Buy - Nov 2014
Discussion in 'Group Buys' started by Nitrag, Oct 13, 2014.
Thread Status:
Not open for further replies.
  1. Oct 26, 2014 at 7:08 PM
    #101
    Jiveydude
    Jiveydude Well-Known Member
    Micah
    OH
    04Taco
    Stuff and things that make it better.
    Nope, and I just realized that you are 2wd so, no front to lock. The only option you have for the ARB is to go junk yard searching for an 8.4" rear to swap out to, should be able to find one for under 300.00.
  2. Oct 26, 2014 at 8:12 PM
    #102
    suttonkb
    suttonkb GO TIGERS!
    Kevin
    Clemson, SC
    2003 Tacoma SAS incoming
    Front and rear price for a SR5 2005 Tacoma? Wanna be regeared for 4.56 as well
  3. Oct 28, 2014 at 8:34 AM
    #103
    overlanderaz
    overlanderaz Well-Known Member
    Phoenix
    2013 SR5 4x4 SC'd
    35" tires, 6"lift, Volant cold air intake, Magnuson SC, 2.4" pulley, AEM Methanol Injection, AEM 340LP, Cam Exhaust Gears, HD-SKO Rock Sliders, ARB compressor, RTT, LED lighting, ARB Lockers, and 4.56 gears.
  4. Oct 28, 2014 at 8:40 AM
    #104
    Nitrag
    Nitrag [OP] Well-Known Member
    As I've states before. I don't know y'alls trucks so you need to figure out what model #'s you need based on your trucks configuration. PM me exactly what you need it and I'll provide the quote.
    Sorry, missed your post. If anyone else is missing a quote PM me.
    Still going strong folks! standby, I know it's a bit of a wait until we order!
  5. Oct 28, 2014 at 8:41 AM
    #105
    SnowroxKT
    SnowroxKT Well-Known Member
    Kyle
    Anchorage Alaska
    2008 TRD OR
    How many are we at now on all the forums?
  6. Oct 28, 2014 at 8:42 AM
    #106
    Nitrag
    Same count as listed on the OP.
  7. Oct 28, 2014 at 8:43 AM
    #107
    V5ioV
    V5ioV My drinking team has a wheeling problem
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    King 2.5 Rem Resi Ext Travel w/comp adj w/700# springs, TC Uni-Ball UCAs, ARB/OME Dakar Leaf Springs w/ King 2.5 Rem Resi w/comp adj and custm eyelets, Stealth Custom Series F-5 Wheels wrapped on: 285/75/16 Fierce Attitudes, BORA 2.25 wheel spacers, GOODRIDGE extended Brake lines, Triple-6" Double Row LED Light Bars behind lower grill, ATFL MOD, TRD Ball Type Shift Knob, Husky WeatherBeater Floor Liners, 60'' HiLift Xtreme, 4xInnovations Bolt-On Sliders w/Kickout, Spring Hanger Skid, Custom BlackPipe Fabs CMC and custom FYL Bed Rack, CVT Mt. Shasta RTT, Trasharoo, 4xInnovations HiLift Bedside Mounts, 4xInnovations Front Skid Plate, TOYWERX Ghost Raptor thin-lip Satoshi Grill, RedLine Hood Struts, 4xInnovations Transmission Skid and T-Case Skid Plates, Wheelers Rear SuperBumps Bump Stops, All-Pro Off Road U-Bolt Flip Kit, UltraGauge, ARB OBA, Pelfreybilt HC rear Bumper, Rotopax system (Single Mounting Plate and Bed Rail Mounting Plate both with LOX handles.
    OP,
    Is there a time line set yet?
    ....and Thanks for all the leg work on this
  8. Oct 28, 2014 at 9:09 AM
    #108
    Nitrag
    Looking to start on Nov 9 and run for one week. Not confirmed yet though.
  9. Oct 28, 2014 at 1:48 PM
    #109
    la0d0g
    running for the hills
    For crawling not hauling
    I checked out the pdf but want to make sure. Front locker for 4:56 2nd gen is RD111 correct?
  10. Oct 28, 2014 at 2:13 PM
    #110
    92shawman
    92shawman Person
    K
    The Americas
    1992 Toyota Pickup
    Lots...see build
  11. Oct 28, 2014 at 4:16 PM
    #111
    Jiveydude
    Micah
    OH
    04Taco
    Correct.
  12. Oct 28, 2014 at 4:22 PM
    #112
    la0d0g
    Thanks!
  13. Oct 28, 2014 at 6:02 PM
    #113
    nimrod712
    nimrod712 Well-Known Member
    Jonathan
    Hot Springs, AR
    '08 Taco TRD
    Depends on which 4.56 gears you go with. If you get the Nitro thick cut 4.56s, you'll need the RD121.
  14. Oct 28, 2014 at 6:28 PM
    #114
    V5ioV
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    Is this same case for front and rear?
    I'm considering 4.56 Nitro thick cut but only need front locker.
    Thanks
  15. Oct 28, 2014 at 8:11 PM
    #115
    Jiveydude
    Micah
    OH
    04Taco
    Correct, you'll need the extra space to fit the thick cut gears.
    I think Nitro only makes thick cut gears for the front. Anyone know the answer...
  16. Oct 29, 2014 at 5:38 AM
    #116
    nimrod712
    Jonathan
    Hot Springs, AR
    '08 Taco TRD
    Correct, Nitro (and Yukon) only make the thick cut for the front. If you go with thick cut gears (4.56 or 4.88) on the front of a 2nd gen with the 8" clamshell, you need the RD121.
  17. Oct 29, 2014 at 5:58 AM
    #117
    Yaozer
    Yaozer Well-Known Member
    North Jersey
    2011 Red DCSB TRD Sport
    Flowmaster exhaust, 3" Old Man Emu lift, Konig Countersteer Rims, and too much more.
    I have a 2011 dcsb sport. I am only running 265 75 16 tires, so I don't think I have to worry about regearing. I think I may get a set of trail wheels with 285s, but I would prob only use them for wheeling and have another set for commuting.
    Would I just need the RD129 with lines and a compressor if I wanted to run a rear air locker? Are there other advantages or benefits to regearing that I'm overlooking?
  18. Oct 29, 2014 at 7:37 AM
    #118
    SnowroxKT
    Kyle
    Anchorage Alaska
    2008 TRD OR
    Correct.
    More braap :cool:, more torque gearing :cool:, less top end speed.
  19. Oct 29, 2014 at 3:10 PM
    #119
    92shawman
    92shawman Person
    K
    The Americas
    1992 Toyota Pickup
    Lots...see build
  20. Oct 29, 2014 at 3:15 PM
    #120
    V5ioV
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    OP, can one be on this go just for a compressor?
Thread Status:
