ARB Locker Help!
Discussion in 'Technical Chat' started by DanGer, Aug 11, 2009.
  1. Aug 12, 2009 at 4:34 PM
    Killer Red Taco
    Killer Red Taco NorCal Rock Whore
    Whatsurname
    BFE–Norcal
    007 Tacoma A/C TRD O/R Impulse Red 4x4
    Bilstein 5100 on front at 1.75 setting • 5100 on back• K&N Air Filter• TRD Seat Covers• Day Time Running Lights• Foglights Anytime• Hella 500 lights in grille• Rear TSB Springs• Alternative Locker Mod• CB and 4 ft firestick II• Billet Grille• Kid puke in the back!• 265/75R16 Goodyear MT/R• 16" Devino wheels• Hose Clamp Mod• Revenge Fab Sliders• No Sway Bar• A Hottie as Copilot
    Miles don't effect the locker so much as Lock-Unlock cycles, the seal will go bad and leak air. Test it before you buy by hooking it up to some air (75 psi max) to see if locks you'll hear it click.
    Miles effect the ring and pinion.
  2. Aug 12, 2009 at 4:48 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Personally, I dont think I would buy a unit that was installed in a rear that busted.
  3. Aug 12, 2009 at 4:56 PM
    DanGer
    DanGer [OP] Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    What are the implications of that?
  4. Aug 12, 2009 at 10:31 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    This rear end has been used for quite some time in the 4Runners. From the outside, the third members look identical to yours, although are quite different internally. The RD132 supersedes the RD23.
    Anyways, none of that stuff really matters. Start looking for the RD129, that is the only ARB that will work in the so called 8.4 rear end. :thumbsup:
  5. Aug 12, 2009 at 10:33 PM
    DanGer
    Thank you all for your help with this! for $450 I wanted to see if I could make it work in any way so thanks for walking me through it all
