ARB Locker
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JR I, Jul 15, 2009.
  1. Jul 15, 2009 at 7:03 PM
    JR I
    JR I [OP] Member
    Buena Park
    2006 4x4
    walker evens suspention with 3'' lift, 285x70x17 coopers, rear ARB locker with on board air.
    has any one installed a locker? I installed it on my taco and it does not leak at all but I noticed that when I go from Parking to Drive or reverse it leaks then stops but only does it the first time? I had the locker on for about 2hrs and it not one leak but the minute that I move to drive it does then stop, Any suggestions.:annoyed:
  2. Jul 15, 2009 at 7:04 PM
    beastlytaco
    beastlytaco Well-Known Member
    Ian
    08 Access Cab SR5
    i take its not an air locker?
  3. Jul 15, 2009 at 7:07 PM
    JR I
    JR I [OP] Member
    Buena Park
    2006 4x4
    yes it is
  4. Jul 15, 2009 at 7:09 PM
    JR I
    JR I [OP] Member
    Buena Park
    2006 4x4
    it leaks air from the axel houseing then stops.
  5. Jul 15, 2009 at 7:09 PM
    JR I
    JR I [OP] Member
    Buena Park
    2006 4x4
    It is
  6. Jul 15, 2009 at 7:17 PM
    beastlytaco
    Ian
    08 Access Cab SR5
    oh. well i dont know a whole lot about lockers to be honest with you. all i can say is check the connections on it and see if you can hear under the truck where it might be leaking from
  7. Jul 15, 2009 at 10:03 PM
    rossk35
    rossk35 Do Work Son!
    hawaii
    07 TRD Sport Supercharged
    TRD S/C/TRD Intake/TRD Boost Gauge/DT Headers/OEM TL/ZKW retro/Pioneer DVD w/Ipod/Magnaflow/20% Tint/BHLM/JL 10" sub, JL VR components, JL 450/4 amp/Helwig Sway bar/Viper 791/ 18" limited 4runner rims
    This is posted in the technology section why?
  8. Jul 15, 2009 at 10:07 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    I'd say..."PERFORMANCE"
  9. Jul 15, 2009 at 10:12 PM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    06 DC 4x4 TRD Off-Road
    You should have posted this in the Off-road or technical section.
    But to answer your question, until the locker fully engages, you will hear the sound of air leaking. Once it is locked in, you will not hear the air leaking out.
  10. Jul 15, 2009 at 10:14 PM
    JR I
    JR I [OP] Member
    Buena Park
    2006 4x4
    Thank you very much. Still new to posting. Thank you for the info.
  11. Jul 16, 2009 at 4:18 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Where at the axle housing?
    Does it leak at the fitting into the housing?
    Does it leak at the breather fitting?
    When you say it engages, are you SURE it's engaging fully?
    When you disengage it (at the button), do you get a blast of air out of the solenoids?
  12. Jul 16, 2009 at 7:35 AM
    JR I
    JR I [OP] Member
    Buena Park
    2006 4x4
    It leaks in the houseing not at the line. We did test and the seals were holding with no problem. I knoe it stops when it id engaged because i had it in the air when I was testing.
  13. Jul 16, 2009 at 1:03 PM
    Janster
    Jandy
    Lancaster, PA
    So, it's getting enough air to engage it?
    Is it holding the air and keeping it engaged?
    When you disengage it, do you get that blast of air out of the solenoids?
    If its inside the housing, then my guess would be...you need to get inside the housing and find where the leak is. Whatever is leaking, will eventually get worse and perhaps the locker won't engage when you want it to.
  14. Jul 16, 2009 at 1:19 PM
    BeachBoy
    BeachBoy Well-Known Member
    VT & QC
    '09 DC LB Sport+Leather
    Icon Extended COs / Camburg UCA / ATX Predator Teflon / Mickey Thompson MTZ / Color-Matched emblems / All-Pro Bumper & skids / Stubbs HD-SKO / Alcans custom leafs / U-Bolt flip / Icon rear resi shocks / Rear Bumper
    check on ttora.com
    a bunch of guys have the locker and will be able to answer
