ARB Mini......Just Got It
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Snoyota, Jan 7, 2011.
  1. Jan 7, 2011 at 11:53 PM
    Snoyota
    Snoyota [OP] Well-Known Member
    Taylor
    Marin County, CA
    07 Black Dbl Cab Sport
    3" King coilovers with resi, king rear shocks with resi, ome dakar leafs, 4xinnovation kickout sliders, CBI front bumper, warn M8000 winch K&N filter. Pioneer deckplate with 500w alpine amp and 13" Focal Sub
    I just got the ARB mini compressor for christmas, I am planning on powering my rear locker once I get it. My question is if I get a tank can the compressor fill it with enough PSI so I can inflate my tires. All help is greatly appreciated
  2. Jan 7, 2011 at 11:57 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    2.5 gallons at 150 psi isnt even enough for 1 tire flat to 35 psi, 33s
  3. Jan 8, 2011 at 12:00 AM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Lusby, MD
    '07 TRD Sport 4x4
    Build thread in sig...
    I believe vair makes a 7 gallon tank, but that would have to be mounted in the bed, which you may not want, and more than likely still isn't enough for all of the tires. but if the compressor is hooked up correctly, you should be alright, they'll inflate tires surprisingly quick for their size.
    the only way to inflate tires with a reasonably small tank is to use a powertank or something similar
  4. Jan 8, 2011 at 12:20 AM
    swiss
    swiss Well-Known Member
    The ARB mini compressor is not rated to fill tires. It was designed to run the lockers. Assuming we are talking about the CSKA12, it rated at .47CFM at 29 psi with a duty cycle of 35%. Meaning you're not getting much volume at all at load and you can only run it continuously for 21 minutes then you have to let it cool for 39 minutes.
  5. Jan 8, 2011 at 12:27 AM
    Snoyota
    Taylor
    Marin County, CA
    I run A/Ts so i dont let their psi go below 10, And i run their street pressure at 33 psi. Can I fill my tires with my arb, with or without a tank, i wouldnt mind putting a large tank in the bed
  6. Jan 8, 2011 at 12:27 AM
    colinb17
    Colin
    Lusby, MD
    '07 TRD Sport 4x4
    my bad
  7. Jan 8, 2011 at 12:34 AM
    swiss
    Is it going to take more than 21 minutes to fill all 4 tires from 10 psi to 33 psi?
  8. Jan 8, 2011 at 6:42 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    The mini compressor could fill the tank - but it'd take a long time. You'll deplete the air in the tank and the mini will never be able to replenish the tank fast enough.
    Use the mini to get your locker functional.
    Then, down the road.....you can put in a full on-board air system and sell the mini. That's what my husband and I did with our jeep/arb's.
  9. Jan 8, 2011 at 6:53 AM
    sam_i02
    sam_i02 Well-Known Member
    Samir
    Kanata, Ontario
    05 PreRunner AccessCab
    BHLM, Satoshi grill, D-rings, Relentless Fab recovery shackle, DRL, Firestone RideRite airbags, WO seatcovers, added temp gauge, custom interior lights.
    ^^^^ i second this. You can fill tires, but between the duty cycle and the flowrate of the compressor it could take you a loooong time to do and will not be practical. Keep this compressor for the lockers and get a bigger one down the road to fill tires.
    The other thing you can do is put a 7 gal tank (like you suggested) in the bed and before leaving on an offroad trip, use a larger compressor, say one in your garage or at a gas station to fill the tank to 150 psi or higher (depending on the rating of the tank). You can then top your tires off directly off this tank without need of the ARB compressor.
    The third option is to get a portable compressor to fill your tires. There is a Vair 400 series for sale in the "Buy/Sell" section of this forum. Those things are pretty sweet. I just got a Vair 325 to run lockers and provide tire-fill for emergencies.
    Let us know what you decide
  10. Jan 8, 2011 at 8:18 AM
    Janster
    Jandy
    Lancaster, PA
    Also, if you seek air for your tires...you could also consider getting a liquid CO2 setup temporarily until you have a full blown onboard air system. I had a 10 gallon setup for a while and went to a 20gallon setup. Here's a writeup:
    http://www.lieblweb.com/liquidco2.html
  11. Jan 9, 2011 at 10:03 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Or, you could send the mini compressor back and get the "High Output" compressor which CAN be used to inflate your tires.
