ARB OME lift tire size question
Discussion in 'Wheels & Tires' started by chilly084, Nov 10, 2014.
  1. Nov 10, 2014 at 5:27 PM
    chilly084
    chilly084 [OP] Active Member
    North East US
    10' Tacoma crew cab 4X4
    2010 Tacoma with ARB OME heavy lift. 16X8 steel rims. I want to go up to tall narrow tires that will fit without rubbing issues, any size suggestions?
    Will 223/85/16 fit?
  2. Nov 10, 2014 at 5:29 PM
    Large
    Large Red
    I think you mean 225, Id go with 255/85/16, you should be good.
  3. Nov 13, 2014 at 8:38 AM
    neverstuck
    neverstuck Well-Known Member
    Guido
    Lebanon
    13 DCLB sport
    slide-in camper, OME Nitros w 884's and Dakars, Michelin A/T2, Pro EFX heated towing mirrors, Timbren HD bumpstops, KB VooDoo bed rails and tailgate cap, ImMrYo rvm bracket, G-Tek Fab door sill protectors, Ultragauge, window visors, hood deflector, Wet Okole seatcovers, in-vehicle safe.
    agreed. If you want something lighter the 235/85r16 would also work but they are a 32" tire so not super tall. Same height as 265/75r16.
  4. Nov 13, 2014 at 9:32 AM
    RogueTRD
    RogueTRD Learn to swim...
    Cade
    So. Oregon
    Supercharged '14 Pyrite Mica DCSB 4x4 TRD OR
    Stacked spacer lift, 22x12 wheels with stretched 33's, tow mirrors, bull nuts.
    255/85/16 I am probably going that route with my next set of tires.
  5. Nov 16, 2014 at 11:59 AM
    tacodane
    tacodane The Slow But Getting Somewhere Build
    Dane
    2013 Tacoma Prerunner SR5
    Led Interior Lights AFE CAI Stage II, Aero Turbine 2525 Muffler Snugtop Cab-Hi shell TRS Retrofitted Headlights
    sub'd. have an ome lift on my truck and plan to get some scs rims. whats the opinion on 285/75/16?
  6. Nov 16, 2014 at 1:08 PM
    RogueTRD
    Cade
    So. Oregon
    There are many different threads covering fitment of 285/75/16's.
    General consensus is:
    Probably have to do some minor trimming, perhaps a cab mount chop.
    Run a wheel with 4.5 inch backspacing, no more than 8" wide.
    If you want to run stock wheels, you'll have to run 1.25 inch spacers to clear the UCA.
  7. Nov 16, 2014 at 2:35 PM
    tacodane
    Dane
    yea ive seen the few threads was just seeing if other with ome lifts have any info with that size tire. thanks for the info
  8. Nov 16, 2014 at 2:50 PM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    Running this exact setup:
    full 3" OME lift with 285/75/16's wrapped around 16x8's with 4.5 BS
    - CMC
    - Minor trimming for on road driving
    - Removed mud flaps
    - SPC (LR) UCAs
  9. Nov 16, 2014 at 2:56 PM
    tacodane
    Dane
    you had to do the cab mount chop for 285's?
    depends on the funds after this year, I may be getting lr uca's.
  10. Nov 16, 2014 at 3:47 PM
    geekhouse23
    When I decided I wanted to go 285s, I began researching on TW how many people had to do a CMC. The results were that if you go off pavement and flex, you will rub on the cab mount with 285s. So, I went to a local member's house, NwiTaco, for some suspension upgrades and we did a CMC also that day in anticipation for the 285s.
  11. Nov 16, 2014 at 4:05 PM
    tacodane
    Dane
    do you think 275's wont require a cmc? just trying to find the biggest tire with little modifications
  12. Nov 16, 2014 at 4:06 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    I have 275/70/17 no rub
  13. Nov 16, 2014 at 4:07 PM
    tacodane
    Dane
    what wheels do you have oz
  14. Nov 16, 2014 at 4:11 PM
    OZ-T
    Peter North
    British Columbia
    Stock Sport alloys
  15. Nov 16, 2014 at 4:18 PM
    tacodane
    Dane
    So I should have any issues if I got a set of the SCS rims. sorry its probably redundant question
  16. Nov 16, 2014 at 4:26 PM
    OZ-T
    Peter North
    British Columbia
    IDK , depends what the backscpacing is
  17. Nov 16, 2014 at 4:41 PM
    tacodane
    Dane
    there 4.3" bs with 0 offset. Im just wanting a nice setup but fills the wheel wells
