ARB On Board Twin Air Compressor Kit
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoIII, Jun 1, 2011.
  1. Jun 1, 2011 at 12:35 PM
    TacoIII
    TacoIII [OP] Mr. Boombastic
    Andrew
    Albuqerque
    10 Taco 4x4 off road package
    3" OME 886 coils, ARB bumper warn M8000, Lightforce 240's and 255/85 16 KM2, Redline hood struts,arb twin air compressor, 4.88's, Tepui kukenam, Pelfreybilt bed rack and rear high clearance with swing out, and custom offroad bodywork
  2. Jun 1, 2011 at 12:50 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    Its a brand new system they just came out with, thats probably why they're hard to find. Most sites probably just havent been updated yet.
  3. Jun 1, 2011 at 2:50 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    It's big enough you'll have to mount it somewhere other than under the hood.
  4. Jun 1, 2011 at 2:54 PM
    mjohn617
    mjohn617 Well-Known Member
    Petaluma, CA
    05 DC TRD sprt silver
    Haha...not doing it...can't make me!
    Brand spankin new, Relentless is right they might be easier to get directly from ARB. that thing is a beast, what do you plan on doing with it!
  5. Jun 2, 2011 at 3:56 AM
    TacoIII
    Andrew
    Albuqerque
    Does anybody know the dimesions?
  6. Jun 6, 2011 at 6:58 AM
    TacoIII
    Andrew
    Albuqerque
  7. Jun 6, 2011 at 9:44 AM
    pAP
    pAP ==========
    NJ
    24 Tacoma TH
    Just tint and ppl for now.
    Its 4.5"x7.5"x10.8" I looked into this myself. If you have a double cab, it will fit nicely behind the rear seat backrest compartment. Just vent it to the outside so you don't get the smell of diff fluid in the truck. The only downside is that you will hear it in the cabin. I don't think thats too bad considering it will only run for a quick second inside the cab when locking the diffs. Other than that, you will be outside the cab filling tires and whatnot. FYI - you still need a tank in order to run air tools.
    Pap
  8. Jun 6, 2011 at 9:49 AM
    pAP
    pAP ==========
    NJ
    24 Tacoma TH
    Clarification - you can run small air tools off it but nothing major without a tank.
  9. Jun 12, 2011 at 6:50 AM
    TacoIII
    Andrew
    Albuqerque
    thanks pAP so im guessing there is no place under the hood it could go. I dont like the idea of it being in the cab.maybe it could be mounted in the storage box in the bed with some modifications to the box.
  10. Nov 12, 2011 at 4:16 PM
    TacoIII
    Andrew
    Albuqerque
    Anybody have one yet?
  11. Nov 12, 2011 at 4:29 PM
    cummins6speed
    cummins6speed Well-Known Member
    '05 4Runner Limited Edition
    Custom extended travel 2.5" King RR coilovers, 1.25" Camburg uniball uppers, homebuilt tube bumper
    6.16cfm, that is a lot for a small compressor. I want to know at what pressure that is though, it doesn't say.
    For that price you can get two Viair's but they don't have that high of a rate of flow
  12. Nov 12, 2011 at 7:39 PM
    RelentlessFab
    Eric
    Sparks, NV
    Its gotta be a low PSI rating, I just saw its rated for 'nearly 3 CFM at 100PSI' in a write up in Fourwheeler magazine.
  13. Jan 12, 2012 at 7:27 PM
    TacoIII
    Andrew
    Albuqerque
    That is still pretty good isnt it?
  14. Feb 21, 2012 at 6:44 AM
    davevan
    davevan Member
    I also need such a kit but have not bought it yet but I will. Normally I use the air compressor rental if I need such a device. Which is very convenient but nevertheless I will buy this prospectively. Seems to be a good offer but I will check some more out and then I will buy one.
  15. Feb 21, 2012 at 7:31 AM
    Namtinker
    Namtinker Member
    AB, CA
    Tacoma TRD 6 spd
    Just finished a complete install of this unit on my 07 TRD.
    Installed behind the left passenger bench in the back. Fits - just. Also included was the little manifold kit required for any locker solenoids.
    Noise is not disturbing - the dampening effect of all the upholstery & seat helps a lot.
    The install was documented and should be available on Ouipack's site first week in March.
    Nice unit - but it will be challenging to find a spot inside the engine compartment. I have the snorkel and supercharger, and there was simply no space left.
    NT
  16. Feb 21, 2012 at 8:16 AM
    badger
    badger Well-Known Member
    07 SR5
  17. Mar 25, 2012 at 11:30 PM
    HBMurphy
    HBMurphy Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
    Or you can get one of these... if you can find one... they are now discontinued. I have one but I personally wouldn't use one without having two batteries (or at least one deep cycle battery) or an over-sized alternator - 120-140 amp draw - its a winch motor. Oh and it's small enough to keep in the bed of the truck! lol
    Warn Air Power VTC Portable Air Compressor
    Motor: 12 VDC Motor
    Max Pressure: 100 PSI
    Pressure Switch: Cuts off at 100psi, turns on when below 70 PSI
    Airflow: 20 CFM at 0 PSI, 8 CFM at 90 PSI
    Air Reservoir Size: 1gal
    Air Recovery Time: 45sec
    Air Up Time: Can fill a 32" tire from 0-32lb in about 1-2min
    Fan Cooled: Yes
    Warranty: 1yr
    Weight: 50lbs
    Dimensions: 12.25W X 14.26H X 16.668L
    Decibel Rating: 86
    Water Proof: No
    Duty Cycle: 30min continuous
    Amp draw: 125 Amps.
    Wire Size/Length: 6ga, 9ft
    Air Fitting: Industrial Interchange
