ARB Products - Opinions for Build
Discussion in '3rd Gen. Tacomas (2016-2023)' started by District Dog, Oct 25, 2017.
  1. Dec 10, 2017 at 1:51 PM
    #41
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I don't have a number for you, but I do know they'll protect from door dings. Even more than steps because they're tucked up higher.
  2. Dec 10, 2017 at 2:00 PM
    #42
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    From the bottom of the door, about 3" and eyeballing it from the outermost part of the body about 3/4" so they def will bock a door from hitting them.
  3. Dec 10, 2017 at 2:28 PM
    #43
    SanPedroTacoLover
    SanPedroTacoLover Well-Known Member
    2017 White Tacoma TRD-Off Road Double Cab
    Thank you for the info!
  4. Dec 11, 2017 at 5:15 AM
    #44
    foy1der
    foy1der Well-Known Member
    W1FOY
    2017 OR DCLB
    They probably won't stop another truck's doors be definitely a car door.
  5. Dec 11, 2017 at 9:28 AM
    #45
    SanPedroTacoLover
    foy1der, thanks for the info.
  6. Dec 23, 2017 at 10:04 PM
    #46
    david-oregon2999
    david-oregon2999 Well-Known Member
    Hey,
    I'm in the middle of adding the ARB Recovery Point to my ARB Summit Bull Bar, and there are a few things not addressed in the instructions. I sent these questions to ARB, want to bounce them off of you and see if you can send a few pics of your install.
    1. The instructions list but do not describe the use of 4584363 (WASHER, FLAT, M12 X 26 X 4mm). How is this part used? Is it used parallel to the SHORT SPACER in STEP 9?
    2. The instructions do not address re-attachment of the SUMMIT BULL BAR RIGHT WING PANEL that is remove in in STEP 1. How is the RIGHT WING PANEL re-attached?
    3. The instructions do not address re-attachment of the SUMMIT BULL BAR SUPPORT STRAP that is removed in STEP 3. How is the SUPPORT STRAP re-attached?
    Thanks!!!
    David
  7. Dec 23, 2017 at 10:26 PM
    #47
    helix66
    helix66 Well-Known Member
    DPRC
    2017 DclB TRDor MgM
    ProGrille,MesoStuff,Tinted,AllPro sliders, RCI ALL skids, BAMF diff skid, KDmaxPro tune, Demello bumper, Warn evo10s, BD s8 & squadrons, Accutune UCAs, Fox 2.5pes, Eibach & Deaver
    ARB makes great products but IMO it looks like you're over building your rig for what you want.
    That bumper looks like a deer & mpg killer.
    If you're not rock crawling you don't need DOM tubing sliders, and the bolt on ones will weigh even more with all the bracket BS.
    You might want to poke around pirate4x for some armor, slider & bumper ideas.
    Ground clearance is only achieved by larger tires......and your suspensions ability to articulate.
  8. Jan 10, 2025 at 4:17 PM
    #48
    chipcall61
    chipcall61 Well-Known Member
    North Carolina
    2017 Toyota Tacoma TRD Offroad
    2" OME Bilstein Lift Cooper ST MAXX 255 85R16 TRD Pro Grill OME Bedmat Weathertech Liners all around
    On safari in South Africa, Namibia, and Botswana, I noticed all the bush trucks and Landrovers are equipped with ARB front bumpers. They drive through and over bushes, small trees, and on my last trip, a feral donkey at high speed. Absolutely no damage to the Hilux we were in. I’ve always been paranoid about hitting a deer with my third gen TRD off-road because of the plastic front end. This last trip convinced me to go with a ARB Summit front bumper. I can attest to their robustness.
    helix66 likes this.
  9. Jan 10, 2025 at 6:51 PM
    #49
    helix66
    DPRC
    2017 DclB TRDor MgM
    Don’t forget to take into account what is available over there.
    They make good products but imo the one for the taco looks oversized, like it’s retrofitted from an f150.
