ARB rear locker
Discussion in '4 Cylinder' started by Taka The Tacoma, Dec 11, 2017.
  1. Dec 11, 2017 at 10:44 AM
    Taka The Tacoma
    Taka The Tacoma [OP] Enjoy the Roy
    2017 SR 2.7L 4WD
    TRD Rims, duratrac tires
    Hello all! I’m in the Washington state, Seattle area and I’m in the market to purchase an ARB rear locker, compressor, and full installation. I have a 2017 Tacoma SR manual 4 cylinder. I’ve contacted numerous areas near me for a quote and managed to only get one. Here is the quote...
    “The ARB air locker runs $929, the CKSA12 standard compressor runs, $279, the inflation kit with all the accessories to inflate tires and such runs $35. Air locker in the rear differential install runs $550 plus $18 in fluid. The compressor is hard to say for sure without seeing it. I'm guessing you'd be 2 to 3 hours ($220-$330) to build a mount for compressor, install, plumb/wire and mount switches. Roughly $2141 + tax total.”
    Does this sound reasonable? Does anyone else know of reputable dealers near me?
    Thanks in advance!
    tacoburrito likes this.
  2. Dec 14, 2017 at 7:52 PM
    TYetti
    TYetti 4cylinders of awesomeness
    Mat
    Abbotsford, BC, Canada
    09 Tacoma AC 2.7L 5spd 4x4
    Considering you're not doing it yourself ya that sounds reasonable. Honestly the compressor install is an easy afternoon diy could save yourself a few bucks that way. Also if you wanna run the locker and fill up tires you should go with the dual compressor. The single might manage for a while but in the long run the dual compressor is the way to go
  3. Dec 14, 2017 at 8:04 PM
    Wyckedan
    Wyckedan Well-Known Member
    Dan
    Woodinville WA
    2014 Stormtrooper AC 2009 Ducati Hypermotard 1100s.
    1 fully operational Death Star
    Check with Mule Expedition Outfitters in Issaquah?
    Taka The Tacoma[OP] likes this.
  4. Dec 15, 2017 at 1:13 AM
    Taka The Tacoma
    2017 SR 2.7L 4WD
    Yup, went with them instead. They offered a much better package with gears! Great people to work with.
    Acivichb likes this.
