ARB Roof Rack Basket
Discussion in '3rd Gen. Tacomas (2016-2023)' started by thughunter1961, Nov 7, 2017.
  1. Nov 7, 2017 at 1:46 PM
    thughunter1961
    thughunter1961 [OP] Member
    Brian
    2016 Tacoma TRD Sport, Inferno
    None....yet
    I recently installed the p/n 3800250 ARB roof basket, on my 2016 Tacoma using the p/n 372010 fit kit. The install was simple and the rack quality built. HOWEVER...the rack killed my fuel mileage. I lost 2-3 mpg at 70mph even with optional aero front cover. It has been tested and verified with the rack off and on. The rack is now for sale. This posting is to advise what to expect should you put one of these on your ride. I should have researched.
  2. Nov 7, 2017 at 1:52 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    You might want to remove the eBay and item number out of the posting as that's circumventing the Buy/Sell/Trade Rules. As showering you are selling it on eBay.
  3. Nov 7, 2017 at 1:57 PM
    thughunter1961
    Brian
    None....yet
    Reference to eBay removed. Thank you sincerely for advising me of the rule infraction. Coop
    Unchained 5150 likes this.
  4. Nov 7, 2017 at 3:29 PM
    Tuh-coh-mah
    Tuh-coh-mah Huh?
    Caluhferneeah
    17MGMTRDORDCSB4WDAT
    TRD catback, BAMF sliders, lots o trail stripes
    Thanks for the heads-up; I've been considering this basket for lighter stuff on longer trips.
    That's a huge difference for such a small change to aero. I'm assuming the test was with the basket empty?
  5. Nov 7, 2017 at 3:35 PM
    thughunter1961
    Brian
    None....yet
    Yes with basket empty. At 70mph the truck was consistently turning over 3000rpm with little or no head wind.
    Joe23 and Tuh-coh-mah like this.
  6. Nov 7, 2017 at 3:38 PM
    blackcloud08
    blackcloud08 Well-Known Member
    WNC
    Have you thought of buying the brackets to mount on the bed rails so it'll sit behind the cab?
  7. Nov 7, 2017 at 3:41 PM
    thughunter1961
    Brian
    None....yet
    No I wanted it roof mounted.
  8. Nov 7, 2017 at 3:45 PM
    ElBlancoTaco
    ElBlancoTaco Well-Known Member
    Ron
    Scottsdale, AZ
    2014 SR5 DCSB 4x4
    I was shocked when I tried a basket about 15 years ago on a Subie Forester I had. Killed my mileage and wind noise was huge.
    Tuh-coh-mah and blackcloud08 like this.
  9. Nov 7, 2017 at 3:54 PM
    Tuh-coh-mah
    Tuh-coh-mah Huh?
    Caluhferneeah
    17MGMTRDORDCSB4WDAT
    That's wild, I hadn't heard about mileage issues with baskets. Appreciate you posting this.
  10. Nov 7, 2017 at 3:57 PM
    blackcloud08
    WNC
    Wind noise and fuel mileage loss are guaranteed with a roof top basket.
  11. Nov 7, 2017 at 3:58 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Not necessarily.
    You can put an RTT on the roof and barely notice it, either in drag or MPG loss. A basket might make more noise but saying it’s a given to be dramatically suffering in economy isn’t true.
  12. Nov 7, 2017 at 4:03 PM
    blackcloud08
    WNC
    I have to disagree buut that's what makes the world go around.
    KB Voodoo likes this.
  13. Nov 7, 2017 at 4:07 PM
    T4RFTMFW
    .. firsthand experience doesn’t. :)
  14. Nov 7, 2017 at 4:41 PM
    Omar RVA
    Omar RVA Well-Known Member
    Omar
    OR
    2020 Ram 2500 Power Wagon; 2019 Land Cruiser
    I’d be shocked if a RTT on the roof didn’t effect mpg, I’d expect any rack to have an effect as well, though less noticeable.
    I keep meticulous fuel records with the road trip app. After adding my frontrunner rack (far more low profile than an ARB basket) in August, I dropped a solid 1 to 1.5 MPG on average (before any fuel blend switches). That said, it was all to be expected and I didn’t care since I bought a truck and not a Prius (not to mention it’s all better than my 5th gen 4Runner).
    2 to 3 MPG seems extreme but I don’t know OP’s driving conditions. Lots of high speed/high wind scenarios could make the effect worse.
    OA
  15. Nov 7, 2017 at 4:43 PM
    T4RFTMFW
    Haven’t lost anything with my Slimline II. :notsure:
    Omar RVA likes this.
  16. Nov 7, 2017 at 4:44 PM
    blackcloud08
    WNC
    Yea an RTT behind the cab and a basket on the roof aren't comparable but apparently it's all about firsthand experience.
    Omar RVA[QUOTED] likes this.
  17. Nov 7, 2017 at 4:51 PM
    Omar RVA
    Omar
    OR
    It could just be our respective driving conditions. It’s definitely proven itself on paper for me. That said the newer frontrunner racks (initially a 3rd gen only design that they moved to both 2nd and 3rds) sits taller than the older 2nd gen design too. When did you get your rack?
    Wasn’t trying to start a pissing contest - just stating that if you’re all city driving or something along those lines (generally lower speed) wind resistance won’t factor in much. In my case it definitely made a difference. For some it won’t at all.
    OA
  18. Nov 7, 2017 at 5:13 PM
    T4RFTMFW
    It’s always about first hand experience, or as close to it as you can get.
  19. Nov 7, 2017 at 5:48 PM
    phsycle
    phsycle Well-Known Member
    CA
    I’d say based on prior vehicles, a good rule of thumb is 10% mpg hit with roof racks. Plus, they’re noisy.
    Which is why got a truck so I can haul stuff in the bed, not on the roof.
  20. Aug 14, 2018 at 7:50 AM
    DBehr
    DBehr New Member
    Dave
    I'm researching roof top racks and ARB is one of my contenders.
    In reading this I think application may have been outside the purpose of a roof rack. Roof racks serve a purpose to haul gear on top - not as a trim to drive around empty 98% of the time. It cannot be expect that gas milage will not take a hit on a permanent fixture on top of your cab - especially if your are doing 70mph! One the other hand I expect hauling gear on top while over-landing, where 35mph is fast, will have a negligible wind resistance effect.
    So I think the bigger question is can I take my rack off when I do not need it? It seems like the ARB fitment kit allows easy removal of the rack when not required. For me that's paramount.
