ARB Summit Bar Winch Install
Discussion in '3rd Gen. Tacomas (2016-2023)' started by t8fanning, Jun 4, 2018.
  1. Jun 4, 2018 at 12:00 PM
    t8fanning
    t8fanning [OP] Active Member
    Utah
    2018 Quicksand TRD OR
    33" KO2s, TC UCA, 3" OME lift, ARB front bumper
    I have a 2018 with an ARB summit bar, and just picked up a Smittybilt X20 10k winch. Have any of you installed a winch in this bumper? Is it possible without pulling the whole bumper off?
  2. Jun 4, 2018 at 12:06 PM
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    Subed for info
  3. Jun 4, 2018 at 12:39 PM
    Dirty Harry
    Dirty Harry Well-Known Member
    Andrew
    SW Florida
    2021 Tacoma 2.7 SR 4x4
    Does the ARB bolt onto the 6 bolts on the frame beneath the radiator support? If so I believe you have to remove the entire bumper. Its something like 125 pounds if I'm not mistaken. After you add the winch that's gonna be one heave mother. You may need a buddy.
  4. Jun 4, 2018 at 1:16 PM
    swissrallyman
    swissrallyman Well-Known Member
    2017 Tacoma TRD Sport
    You could certainly add a winch to an ARB bumper after the fact on a 2nd gen. Its just a bit tricky. Bet you also can with the third gen
  5. Jun 4, 2018 at 1:54 PM
    t8fanning
    Utah
    It looks like I can pull the skid plate and try and slide the winch up in there. I think I'll try that first and see how it goes.
    AvocadoTaco17 and Dirty Harry like this.
  6. Jun 4, 2018 at 2:02 PM
    Dirty Harry
    Andrew
    SW Florida
    I'd try that as well. Good luck to you.
  7. Jun 4, 2018 at 3:47 PM
    Joe23
    Just some info actually might depend on which winch.
    I know when I was emailing them as this is the bumper I want I was asking same thing because of the price of both winch and bumper etc.
    They said you cannot do it but that was with a warn zeon winch, any warn supposedly requires a separate mounting system.
    Now I don't know if that's what made it why you cannot do it with the bumper already on, or if it's just in general you can't do it.
    Hence why I'm curious to hear outcome.
  8. Jun 4, 2018 at 6:41 PM
    t8fanning
    Utah
    The winch body is in. I didn't pull the bumper. I'm still waiting on the fairlead adapter and I need to mount the control box somehow. I want it pretty low so it doesn't interfere with the Toyota safety sense, so I'm not sure the ARB adapter will work. I'll figure it out though.
    I had to pull the ARB skid plate, and undo two bolts to the stock Toyota skid plate, and that was it. I lifted the winch up from the bottom and did the whole job by myself.
    The hardest part was rotating the motor housing and getting the brushes back over the winding. But both housings line up well now. The ARB instructions say to clock the electrical connections so that they point up, but the Smittybilt winch has an alignment pin that prevents this. I made them point toward the rear of the car, but the lines are plenty long and will reach fine. The clutch handle is nice and accessible.
  9. Jun 4, 2018 at 6:48 PM
    cfagan14
    cfagan14 GaTacoma
    Atlanta
    2017 DCLB 4X4 TRD OR Quicksand
    The top mounting bolts were a real PITA to get in. Glad you made it work though!
  10. Jun 4, 2018 at 6:53 PM
    t8fanning
    Utah
    Oh yeah they are. They're really hard to start, especially with non-child sized hands. But once I had one or two threads in, they were fine. Just took a long time to tighten.
  11. May 1, 2019 at 7:13 AM
    BeardedYinzer
    BeardedYinzer Well-Known Member
    Ian
    NOVA
    2018 TRD Sport
    Wheels / Tires / Softopper / Fox 2.5's ext travel set to 2.5" of lift/ 600 pound 14" springs / Total Chaos UCAs/ ARB Summit Series Bumper / SOS Offroad Sliders /OV Tune / SPOD / Ditchlights /10K winch/ a bunch of other stuff
    Great info OP. I'm planning to do this next weekend.
