ARB Superwinch install
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Krazie Sj, Sep 26, 2011.
  1. Sep 26, 2011 at 1:14 PM
    Krazie Sj
    Krazie Sj [OP] Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    So I'm having issues with the Solenoid pack. Fucker is getting in the way of the install, and even if I could install it there, it would be a nightmare to put the line in if I wanted to use it.
    Thus I'm forced to move it. How? I've looked at the extension kit which seems to be my only option, but it's another $60.00 not including shipping from the States. Has anyone done this without using the extension kit? Or making one themselves?
    Otherwise the only thing I can think of is taking the end of the winch off and rotating it 90ishº. I'm not even sure I can with that side of the winch. (I did with the clutch side, which was pointless because the clutch handle knocks against everything if you try to put it in a more friendly place thus negating the purpose of moving it in the first place!)
  2. Sep 26, 2011 at 5:16 PM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    BTW - Getting your thumb stuck between your ARB and an 85lb winch will in fact take skin off as if you tried cuddling a razor on the end of a dremel.
  3. Sep 27, 2011 at 11:33 AM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Twin bumps.
  4. Sep 27, 2011 at 12:49 PM
    maxamillion2345
    maxamillion2345 Leaves the bay but brings all its problems
    Max
    Nevada
    80 series LC
    Tons and 40s
    You'll have to buy some wire, probably a heavier gauge than the stock wires from the solenoid to the winch. Just extend them and put it on the bumper or in your engine bay. Then extend the controller plug wires or leave it on the box. I'd suggest solder on connections and heat shrink.
    A propane torch and some solder should do. Tin the wire. Stick it in the connections and then feed in solder while you heat it. Make sure you slip heat shrink behind it all and then just pull it up, a little heat and you'll have longer lines.
    Crimp on connections and heat shrink would work too.
    Any industrial supply or maybe welding company should have the wire.
  5. Sep 27, 2011 at 1:41 PM
    jrdbrn
    jrdbrn Borne Fishing
    Jared
    Louisiana
    '16 Inferno Tacoma TSS
    Came here for this :D
  6. Sep 27, 2011 at 1:43 PM
    chadderkdawg
    chadderkdawg Don't ask questions you don't want the answer to..
    Des Moines, Iowa
    09 FX4 F150
    x2, totally worth it :)
  7. Sep 27, 2011 at 1:49 PM
    Pugga
    Massachusetts
    '18 Ford F-250 SCREW
    F-250 Land Yacht Mod
    I'm sorry, what was the question?
  8. Sep 27, 2011 at 1:50 PM
    Seabass
    Seabass Chrome won't get you home
    Adam
    AZ
    '06 Sport 4x4
    Let's be honest... you really only care about your own rig.
    We were playing "woodja" I thought
  9. Sep 27, 2011 at 7:33 PM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    This was the answer I was after. Much appreciated good sir.
  10. Sep 27, 2011 at 7:35 PM
    Andrew H
    Andrew H What is this "search" you speak of?
    Dirty Tucson
    2017SSMDCSBTRDS
    yum.
  11. Sep 27, 2011 at 7:36 PM
    davestaco
    davestaco TW's number one gear whore
    David
    Schofield Barracks
    00' tacoma xtra cab trd v6 4x4
    I bet their backs fucking hurt as far as there trying to push there asses out....but i aint complaining:D
  12. Sep 27, 2011 at 7:44 PM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    No they are good :D
