Arb tire deflator vs Staun tire deflator
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jake slatnick, Mar 2, 2017.
  1. Mar 2, 2017 at 8:02 PM
    jake slatnick
    jake slatnick [OP] Well-Known Member
    jake
    San Diego
    Cement TRD Pro
    285/75r16 KO2's, Baja XL 80's on CBI ditch brackets, TRD intake, opticoat pro, clear bra running the bottom sides, morimoto LEDs, all white LEDs inside, mounted shovel and axe above wheel well in the bed, linex'd the bed...
    What's your opinion on the better option for a tire deflator? I'm kind've lazy so I'm leaning towards the Staun... What do you guys think?
    The ARB tire deflator where you do each tire manually...
    Or the Staun deflators that do all 4 at once?
    UPDATE:
    Got the Staun tire deflators. Took a bit to set them up. Ended up putting them on all four tires, turned the car on and got the reading of each tire, and then adjusted each individually. After turning the car on like 20 times, I got them all exactly at 15.
    Been offroading twice now with them. Just walk around and put each one on... By the time you get the last one on the first one is just about down.
    Threw on some loctite also so they stay there.
    Love these things! So worth it.
  2. Mar 2, 2017 at 8:06 PM
    OdiN1701
    OdiN1701 Well-Known Member
    Colorado
    2017 Quicksand TRD OR DC SB
    I like my Staun deflators.
  3. Mar 2, 2017 at 8:07 PM
    Silverspool
    Silverspool Come at me Bro!
    Frank
    DFW
    18T4RORP 17GT350
    Anyone seen my wallet?
    Do 3rd gen give you psi readout on the dash? If so... staun all day long
  4. Mar 2, 2017 at 8:08 PM
    jake slatnick
    jake
    San Diego
    Cement TRD Pro
    Ya they do, but it takes a few minutes to calibrate after you turn the car back on. Not real time...
  5. Mar 2, 2017 at 8:08 PM
    OdiN1701
    Colorado
    You don't need a readout, you set them to the PSI you want and they stop when done.
  6. Mar 2, 2017 at 8:09 PM
    jake slatnick
    jake
    San Diego
    Cement TRD Pro
    Is it pretty easy to get them all to the same PSI? I know they come set at 18, but I usually run 15.
  7. Mar 2, 2017 at 8:10 PM
    Silverspool
    Frank
    DFW
    18T4RORP 17GT350
    Oh sweet. Didnt know that.. def staun either way then
  8. Mar 2, 2017 at 8:13 PM
    SuperBad
    SuperBad Well-Known Member
    Dallas, TX
    2017 MGM Tacoma OR DCSB
    Truck stuff
    I like the ideal of the staun but after destroying a cap my last time off roading i'm not sure I would want to risk breaking the staun.
  9. Mar 2, 2017 at 8:14 PM
    jake slatnick
    jake
    San Diego
    Cement TRD Pro
    But don't you put them on, deflate, and then take them off before you start wheeling?
    SuperBad[QUOTED] and Silverspool like this.
  10. Mar 2, 2017 at 8:15 PM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    Staun! thats the brand I was looking for my next GB
  11. Mar 2, 2017 at 8:15 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Staun. Used them for 10 years. Set them all once to your desired psi, then when you are at the tail head just walk around the truck putting them on each corner. They deflate the tire to the set psi and automatically turn off. Walk around and remove in the same order. By the time you have the 4th one installed, the first one is about done.
    tacopromatt, DavesTaco68 and SuperBad like this.
  12. Mar 2, 2017 at 8:16 PM
    DukesTaco
    DukesTaco Well-Known Member
    AZ
    2nd Gen Double cab Pre Runner
    You don't leave them on. You remove them after the tire pressure drops.
  13. Mar 2, 2017 at 8:21 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
  14. Mar 2, 2017 at 8:21 PM
    DukesTaco
    AZ
    Silverspool likes this.
  15. Mar 2, 2017 at 8:21 PM
    jake slatnick
    jake
    San Diego
    Cement TRD Pro
    Ordered on Amazon for $67.34 :)
    https://www.amazon.com/Staun-SCV5-Tire-Deflators/dp/B00QBPBLWY
    crashnburn80[QUOTED] likes this.
  16. Mar 2, 2017 at 8:23 PM
    jake slatnick
    jake
    San Diego
    Cement TRD Pro
    No way these are the same quality as the Stauns though...? Probably went out the back door of the factory Smitty built is using... At cost the Stauns must be at least $15 to make
  17. Mar 2, 2017 at 8:28 PM
    SuperBad
    Dallas, TX
    Truck stuff
    Didnt realize you dont leave them on. I just figured they where meant to replace the caps all the time. When i think about it its the same amount of work or easier than the arb ez-deflator. Looks like i may have to order a set.
  18. Mar 2, 2017 at 8:28 PM
    Silverspool
    Frank
    DFW
    18T4RORP 17GT350
  19. Mar 2, 2017 at 8:29 PM
    DukesTaco
    AZ
    Don't have stauns to compare them to but have had them for two years and the get the job done. The set on my Tacoma are set to 16 psi and on my crawler to 8psi. Setting them up takes a bit of trial and error but that goes for all of them. After I got mine set up I put a few drops of locktite on them. After I air down on the trail I still check tire pressure with a digital guage.
  20. Mar 2, 2017 at 8:29 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    It is easy enough to make something that looks the same. The real test is if you set them to 12psi, use them a few times and then check that your tires are actually at 12psi when they shut off. I always double check my tires with a digital pressure gauge with my Stauns and they are spot on.
