ARB Twin Compressor (CKMTA12) Wiring
Discussion in '3rd Gen. Tacomas (2016-2023)' started by shacol, Jan 27, 2020.
  1. Jan 27, 2020 at 6:04 AM
    shacol
    shacol [OP] Well-Known Member
    Florida
    2018 Offroad DCSB
    Hello Everyone,
    I am hoping for some advice/confirmation that I am on the right track.
    I am trying to sort out wiring a CKMTA12 as simply as possible.
    I'd like to have a simple switch (no illumation) right next to the compressor under the hood. I also don't plan to have it switched by the ignition, meaning it'll come on with just my simple switch. I plan to have the QD and switch side by side, so I'll need to open the hood to use the QD and will just operate the switch at that time. I also know that it isn't recommended to use the compressor with the truck off, and I don't plan to, but I'll just manage that myself.
    I have attached a pic of the wiring diagram, with the modifications that I *think* will work.
    Any thoughts?
    Thank you!
    PS - I don't have air lockers...
  2. Jan 27, 2020 at 6:59 AM
    shacol
    Florida
    2018 Offroad DCSB
    Well, shoot, that is even simpler than what I thought!
    Did you do this yourself? Or, is it just evident from the wiring diagram?
  3. Jan 27, 2020 at 3:51 PM
    caribe makaira
    Caribbean, Puerto Rico
    Evident...
  4. Jan 27, 2020 at 4:00 PM
    shacol
    Florida
    2018 Offroad DCSB
    gotcha, thank you very much!
  5. Jan 27, 2020 at 6:10 PM
    shacol
    Florida
    2018 Offroad DCSB
    That makes sense.
    But since that's the case, your first diagram of just wiring the purple and black to a switch is the simplest ... I think I'll go that route.
    I very much appreciate you taking time time to help me out!
  6. Jan 27, 2020 at 6:12 PM
    caribe makaira
    No problem...:hattip:
  7. Jan 28, 2020 at 4:47 AM
    shacol
    Florida
    2018 Offroad DCSB
    Sorry to bug you with this again, but I do have one other question.
    I noticed on the diagram that I first posted, one of the switches - the isolation switch - is tied to 12v(ignition).
    I am in no way saying that your diagram is incorrect, I just wanted to point that out in case you missed it. Is that a valuable clue or no? Just do it as you described originally?
    I don't care about it being switched by the ignition, but it made me wonder if I needed to pick up 12v somewhere for the other side of the switch...
  8. Jan 28, 2020 at 5:38 AM
    caribe makaira
    Yeah I missed that.:(
    You'll need power to the PURPLE. 8 amps is mentioned in the install instructions but I think that is for when all 3 switches are used. So 8/3= 2.333. I say get a 3A fuse, if it fails then up to 5. The switch you use must handle the 8+ amps just to be within specs...The ARB ones are Carling types, they are 20 amps.
  9. Jan 28, 2020 at 6:15 AM
    caribe makaira
    You can also do this:
  10. Jan 28, 2020 at 6:19 AM
    shacol
    Florida
    2018 Offroad DCSB
    Ahh, ok then!
    So, it'll be like my first diagram, but you recommend a fuse 3A (or up to 5A) on the purple line next to the battery.
    Here is a new diagram just to be sure that I have it correct.
    Again, THANK YOU!
  11. Jan 28, 2020 at 6:21 AM
    shacol
    Florida
    2018 Offroad DCSB
    Ahh, gotcha, I was making a reply when you posted this... this is also workable for me! Thanks for the option!
  12. Jan 28, 2020 at 6:22 AM
    caribe makaira
  13. Feb 9, 2020 at 9:52 AM
    shacol
    Florida
    2018 Offroad DCSB
  14. Feb 9, 2020 at 9:54 AM
    caribe makaira
    :hattip:
  15. May 27, 2020 at 1:20 PM
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    Can you post pictures of the completed install? I'm in the same boat as you. I want onboard air (tire fill ups), but don't see the point of running a switch into the cab.
    Thanks in advanced.
  16. May 27, 2020 at 1:48 PM
    shacol
    Florida
    2018 Offroad DCSB
    @Bertw192 Yes, happy to do so, give me a couple of hours and I'll get you some pics.
  17. May 27, 2020 at 1:55 PM
    shacol
    Florida
    2018 Offroad DCSB
    ohcjam and Bertw192 like this.
  18. May 27, 2020 at 2:00 PM
    Bertw192
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    That's super clean! Ok... time for all of the questions...
    What mount is that?
    In your wiring diagram (post #10), you're proposing an engine bay mounted switch. Is that the switch in your photo (black with yellow font)?
    I'm sure more questions to follow.
    Thanks again!
    cc-rider and galito like this.
  19. May 27, 2020 at 2:10 PM
    shacol
    Florida
    2018 Offroad DCSB
    Bertw192 likes this.
  20. May 27, 2020 at 4:10 PM
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    I'm not running the dual setup, just the single but I don't think switching black in connector 2 will work. Black in connector 2 is coming from ground connection in connector 1 to complete circuits on air solenoids (high side switched) and the switch backlights. So switching ground on 2 won't do anything here and as soon as purple gets 12V the compressor will run due to the relay coil being connected to ground via connector 1.
