Arb twin compressor help.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jardoo, Feb 23, 2022.
  1. Feb 23, 2022 at 8:59 AM
    jardoo
    jardoo [OP] Well-Known Member
    Beirut, Lebanon
    2016 DOUBLE CAB MGM 4X4 TRD OFF ROAD SHORT BED
    I’m currently installing my arb twin compressor in my third gen.
    There is a blue/white wire which is supposed to be to illuminate the switch and a red/yellow wire which is supposed to go to the ignition. I attached add a fuse to both, so where do I put them and what amperage do I use in each?
    I’ve tried searching but I’m so confused. Thanks.
  2. Feb 23, 2022 at 9:19 AM
    TacoMike
    TacoMike Well-Known Member
    Pennsylvania
    '19 SR AC Utility 4x4
    This is for a single but it might help.
    jardoo[OP] likes this.
  3. Feb 23, 2022 at 10:24 AM
    slowpoke16taco
    slowpoke16taco Well-Known Member
    Jayson
    SoCal
    2016 MGM TRDOR DCSB
    Stock, but not stock (but stock)
  4. Feb 23, 2022 at 10:43 AM
    jardoo
    Beirut, Lebanon
  5. Feb 23, 2022 at 10:49 AM
    Mark77
    Mark77 Well-Known Member
    Mark
    2021 White TRD Off-road
    Nothing yet
    Same issue! And no good answers. Mine has been waiting for me to finish wiring it for like 3 months.
    Arbs directions suck ass.
    jardoo[QUOTED][OP] likes this.
  6. Feb 23, 2022 at 10:51 AM
    jardoo
    Beirut, Lebanon
    hah, well it seems the instructions are for people who are more electrically inclined/experienced. But yeah I’m determined to finish wiring mine today. I won’t sleep lol.
    Mark77[QUOTED] likes this.
  7. Feb 23, 2022 at 11:09 AM
    slowpoke16taco
    Jayson
    SoCal
    2016 MGM TRDOR DCSB
    I have my switch in poutlet2, which makes the compressor work only when the engine is running (vs able to use in ACC mode). I'll need to go to my truck to see what fuses I used in the add-a-fuse.
  8. Feb 23, 2022 at 11:29 AM
    slowpoke16taco
    Jayson
    SoCal
    2016 MGM TRDOR DCSB
    So my add-a-fuse is in the 15A poutlet2, with both slots using 15A fuses. For the switch illumination, I tapped the cargo light wires since the switch was nearby.
  9. Feb 23, 2022 at 11:32 AM
    TacoMike
    Pennsylvania
    The red/yellow you want to fuse tap to an ignition on fuse, ie; a fuse that is hot when the truck is turned on if that's how you want to run your compressor. The blue/white can tap to your tail lights to illuminate your switch when you turn your lights on. Use the same fuse rating as the one you're tapping into, both fuses the same amperage.
  10. Feb 23, 2022 at 11:34 AM
    jardoo
    Beirut, Lebanon
    does that apply to the red wire too? Use both the same amperage? And which one is always hot that I can plug it into? Thanks.
  11. Feb 24, 2022 at 12:59 AM
    jardoo
    Beirut, Lebanon
    oh also, what if i just want the light to illuminate when the button is pushed in?
