ARB Twin Compressor
Discussion in '2nd Gen. Tacomas (2005-2015)' started by AlaskaTXPro, Dec 17, 2014.
  1. Dec 17, 2014 at 11:52 PM
    AlaskaTXPro
    AlaskaTXPro [OP] Member
    Parker
    Port Orchard, WA
    11 TX Pro
    Nfab double cab step, Bilstein lift adjustable 5100s front 5160 back, ARB twin Compressor, hood and bed lights LEDs, TRD shift knob, Wet Okole full set TX Pro emblem
    I have been doing some searching but haven't been able to find anybody that has made engine bay mounting brackets for the ARB twin compressor. There is the space passenger side next to firewall. If you know of any fabricators that have already created please let me know.
  2. Dec 18, 2014 at 12:03 AM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    I don't think those are mass produced by anyone. You'll probably have to just contact a local fab guy near you, or someone handy that can make something up for you, or contact a fabricator on here and ask them if they can do it.
  3. Dec 18, 2014 at 12:35 AM
    AlaskaTXPro
    Parker
    Port Orchard, WA
    11 TX Pro
    Where have most people mounted there compressors? Any places people have found to be convenient.
  4. Dec 18, 2014 at 12:52 AM
    VolcomTacoma
    Jeff
    NorCal
    There's plenty of places to mount it, if you're willing to run the wiring. I know behind the seats is a good spot, in the bed, under the bed. Just get creative and think about how much you're going to use it and what kind of weather you want affecting it
  5. Dec 18, 2014 at 12:54 AM
    Idaholandho
    Idaholandho The other white meat
    3 Now - 2022 Trail Edition, 2015 TRD 4x4 and a 2006 SR5 4x4
    2015 Tacoma, Magnuson Supercharger, Bully Dog Flash and GT, Safari Snorkel, Toytec BOSS 2.5 Coil Over Front, Toytec BOSS Aluma 2.5 Rear, Toytec 10 Leaf Pack, Stainless Brake Lines, Icon UCA's, CBI Reverse Adj Shackle Mounts, CBI Ubolt Flip Kit, Timbren Bump Stops, CBI Bushmaster 2.0 Front Bumper w/ Warn M8000S Winch and SR2 Rigid Flood Lights, CBI Bushmaster 2.0 Rear Swingout Bumper, Rigid SR2 backup lights and Dual RotopaX / Fuel/First Aid Pack, CBI Rock Sliders, CBI Full Skids and CBI Rear Diff Armor, BAMF LCA Skids, FrontRunner Outfitters Slimline II Roof Rack w/ Rigid SR2 40" Combo Light Bar, Rock lights, Rigid pods in Bed Rack, Intelligent Battery System w/ Dual NorthStar batteries, Spod Power Distribution, illuminated switch panel in sunglasses holder, Viar Extreme Duty On-Board Air w/ 2.5 Gallon Tank under bed, Air 2 Air Sys, Magnaflow Exhaust, Fuel Off Road Trophy Wheels, 285/75/17 Toyo Open Country R/T, Diff breather mod, FX-R BHLM Demon Eye headlights, Esuse LED Fog Kit, Pelfreybilt Camera Relocation mount, Pelfreybilt ax/shovel bed mount, Debadged, tint, a 2006 Tacoma SR5 and a 2022 Trail Edition
    In the bed passenger side bed compartment is a fantastic spot to mount the compressor and gauge.
  6. Dec 18, 2014 at 10:40 PM
    AlaskaTXPro
    Parker
    Port Orchard, WA
    11 TX Pro
    I don't want it ripped off so under chassis is not a possibility. only problem with the bed is that its easily accessible to others more likely to be stolen.
  7. Dec 18, 2014 at 11:46 PM
    WOODY2
    WOODY2 Well-Known Member
    RAMONA,CA.
    On my 2014 there are a couple of existing points on the passenger front wheel well that worked great. I just took some poster board and folded it to get the angles and shape correct flattened it out cut thin aluminum and bend up using a vice. BTW i have the mid sized ARB compressor.
  8. Dec 19, 2014 at 11:27 AM
    Pcyc
    Pcyc Self Proclaimed Leader
    Fritz
    Concord, CA
    09 DCSB TRD OR - Supercharged - Dual Cased - Twin Sticked
    https://www.tacomaworld.com/threads/pcyc-fj40-build.444289/ https://www.tacomaworld.com/threads/pcycs-2nd-gen-build.308160/
    OP PM sent. I am working on a bracket.
