ARB vs stock Locker
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ColdSteelTiger, Oct 22, 2011.
  1. Oct 22, 2011 at 5:59 PM
    ColdSteelTiger
    ColdSteelTiger [OP] Well-Known Member
    so I have an SR5 and may get a locker in the future and I was wondering if the ARB is better than the stock TRD locker and why?
  2. Oct 27, 2011 at 2:05 PM
    ColdSteelTiger
  3. Oct 27, 2011 at 2:50 PM
    04LTtacoma
    04LTtacoma Well-Known Member
    Morty
    Outer Space
    Both are going to be about the same price.
  4. Oct 27, 2011 at 2:54 PM
    Pugga
    Massachusetts
    '18 Ford F-250 SCREW
    F-250 Land Yacht Mod
    TRD locker uses electronics, ARB uses compressed air. If you have the need for on board air, the ARB might be a good option since you'd have to add a system for the locker anyways. If not, you might be able to get a used TRD Off Road rear axle and wiring and do the swap out and save some $$.
  5. Oct 27, 2011 at 3:11 PM
    ColdSteelTiger
    So I can't just simply add a locker to a stock sr5 4x4
  6. Oct 27, 2011 at 3:12 PM
    Pugga
    Massachusetts
    Not a TRD locker, you can add an ARB to your stock rear end.
  7. Oct 27, 2011 at 3:39 PM
    all.on.black
    all.on.black Well-Known Member
    Auburn, WA
    06 Double Cab Sport with a few mods
    The ARB has a stronger carrier and engages smoother/faster. I would choose the ARB over the e locker every time.
  8. Oct 27, 2011 at 4:02 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    My Elocker engages smoothy each time every time.
  9. Oct 27, 2011 at 5:55 PM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    The SR5 truck's rear end is a larger rear end then the stock e-locker rear end, so add an ARB and you will have stronger, locked rear IMO. Then, upgrade the compressor for a clean, on board air set up. Much cheaper then swapping out axles, electricals, etc. and a better set up many would agree. Plus, this would be a good time if you wanted or needed to re gear. :D
  10. Nov 2, 2011 at 1:34 PM
    ColdSteelTiger
    I see. Will regearing effect VSC?
  11. Nov 2, 2011 at 3:03 PM
    Brandon H
    Brandon H Well-Known Member
    Newhall, CA
    07 DC Offroad
    2017 4Runner TRD Offroad Premium. Icon stage 7, RCI skids, SCS SR8 wheels, budbuilt sliders, 285/70/17 BFG Ko2s (Old rig) 07 Taco TRD Offroad FUlly Locked, Icon Extended Travel CO's w/ remote resis., Alcan AAL's,Icon Remote Resi Rear Shocks, All Pro Front bumper w/ warn 9.5xp,winchline synthetic winch cable,All Pro IFS Skid plate, OME Shims, OME Carrier Bearing drop, Trail Gear Sliders, Yakima Load Warrior Basket, OEM Roof Rack, Hi Lift Extreme, Cobra model 19, Wilson Lil Wil Antenna, Yaesu ft-7800
    My E-Locker has never let me down, and has always engaged with no problems. But if I had my choice between the two, I would choose the ARB.
  12. Nov 2, 2011 at 5:33 PM
    ColdSteelTiger
    Guess ARB it is
  13. Nov 2, 2011 at 5:37 PM
    SiRMarlon
    SiRMarlon The Photo Ninja!
    Marlon
    Los Angeles
    Canon 5D MarkIII
  14. Nov 2, 2011 at 6:12 PM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    Agree, and with ARB, you have air for filling tires, etc.
  15. Nov 2, 2011 at 6:19 PM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    ARB all the way :)
