Arbitration didn't go well..........
Discussion in '2nd Gen. Tacomas (2005-2015)' started by XJ1100JKen, Aug 4, 2014.
  1. Aug 4, 2014 at 9:19 PM
    XJ1100JKen
    XJ1100JKen [OP] Well-Known Member
    Ken
    Tullahoma, TN
    2014 BIG SILVER LEMON
    We purchased the Tacoma (22 miles) the end of March 2014. Noticed vibrations at highway speeds, been back to the dealer 7+ time (they only documented 5). The dealer aired the tires, balanced the tires, balanced them again, road force balanced them twice and tried a different set of wheels and tires.
    On our own, we had the tires replaced, driveshaft balnced/trued and a host of other adjustments and tweaks.. nothing changed the vibration felt in the cab, floor, doors and seats.
    Toyota calls it a characteristic, they also call the slow speed shudder the same thing, a characteristic, only there is no "fix" for the high speed vibration.
    Anyway, back and forth with the dealer (Toyota of Murfreesboro, TN.), then back and forth with Toyota Corp, no satisfaction and they both were terrible to deal with. Close to 1,000 miles driving back and forth to the dealer and mechanics/specialists.
    On to dealing with NCDS (National Center for Dispute Settlements) to gather information and schedule the arbitration. The hearing was held at the selling dealer, Toyota sent a regional GM, Dirk Hammersmith. The dealer had their service manager sit in as well. We documented every phone call, email and visit to anybody regarding the truck, we thought we were well prepared. Dirk spent most of his time stating how all manufactures build thousands of vehicles every year and they all have different "characteristics", some are addressed/fixed, some are within engineered specifications and left as is.
    He then spent several minutes discrediting a Toyota service manager that sent me an email stating the vibration is a known issue and there is no fix for it according to Toyota. And another service Toyota service tech that "really wasn't sure what kind of vibration I was referring to", even though he accompanied me on several test drives during this process.
    We received the "verdict" today, our claim was denied... seems that everybody is in agreement with Toyota. as long as nobody calls the vibration a problem/issue/manufacturing defect and DOES call it a characteristic, it's totally acceptable!
    I've talked to a couple of local Tacoma owners, they have felt the high speed (45/75mph) too. The dealer told them, after re balancing the tires a couple times.. that the tires are not the greatest, difficult to get perfectly balanced. The dealer told them to run the tires till it's time to replace them, a new set of will smooth everything out.
    Anybody else experiencing any vibrations at 45 mph and then intensifies around 75 mph?
    ******************* Update****************************
    Trying to find an attorney (we contacted over 40 firms) that is willing to take a LL case in TN is a huge waste of time. Apparently TN is pro business, not pro consumer (or pro employee either) so the odds of winning this type of case is not good. The attorney also informed me that Toyota will drag the process out, for years in some cases and the consumer usually gives up and the firm gets nothing (fee reversal, no win-no pay) such is the world of big business.
    We have tried new tires, different wheels and tires, balancing and truing the 2 piece drive shaft and installing a custom made 1 piece aluminum drive shaft too. The tires have all been road forced balanced with the proper adapters and equipment.
    The TSB for low speed vibration was installed (mine did not have it, but in some cases the mid speed vibe was eliminated) and caused it to vibrate at around 25mph. The dealer re-installed the original springs. and most of the low speed vibration is gone..
    The vibration at 45 mph and the high speed vibration 70 mph on up past 80 mph remains.
    I am taking it to a different Toyota dealer Monday, he does know the history and has spoken to the Toyota field service tech that originally ruled that this vibration is a characteristic of the truck. So he's not really sure if they can help either, not unless they feel it's unreasonably bad.
    The other approach we are going to take is speaking with the lender, maybe they'll do something... I don't know.
    Everyplace I take it, tire store, alignment shop, transmission shop, suspension shop... they all say it's a good looking truck, then they go for a ride and the vibrations start, then it's they say "this is a damn shame, I can't believe Toyota is telling you this is normal for a Tacoma to shake like this!" So it' not just me that's taken back by Toyota's decision to call it a characteristic.
  2. Aug 4, 2014 at 11:10 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    I've had the 45 mph vibe since new
  3. Aug 4, 2014 at 11:27 PM
    cdthiker
    cdthiker Well-Known Member
    Tim
    WAY north Idaho
    2012 Tacoma RC 4X4 5speed
    I had this problem as well.
    Part of it was tires but not all of it.
    After many trips to the dealer they finally sent the drive shaft off to be balanced.
    Helped a lot but it is still there just a wee bit. But only half the time. When the tires are rotated it goes away. So one set not sure which when it is moved to the front or the back makes it better or worse.
    Good luck
  4. Aug 5, 2014 at 2:28 AM
    dm1215al
    dm1215al Well-Known Member
    Dan
    Fl
    2014 TRD Offroad 4x4
    Step tubes,Window tint, HomelinK rear view mirror, changed the entune image screen Rear Differential Breather Relocation Extended AC condensate hose KB Voodoo tailgate cap Redline Tuning QuickLIFT ELITE hood lift system.
    Have not noticed this with mine.
  5. Aug 5, 2014 at 2:46 AM
    Gearheadesw
    Gearheadesw Well-Known Member
    Davenport Fl
    2016 GMC 2500hd
    some
    I've got a 50 mph hop that has been there since new. Tires are different, wheels are different, still the vibe. I think in my case it's the drive shaft. When I load it tail heavy the vibes lower in speed from 50 to like 45 40 depending on the load. So that tells me it is indeed the drive shaft on my truck, the angles change and so does the vibration.
    Keep us posted.
  6. Aug 5, 2014 at 3:11 AM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    Surprised that regular cabs can have this problem as well.
    Thought only it was an Access or Double cab problem because of the double drive shaft and carrier bearing.
  7. Aug 5, 2014 at 3:21 AM
    bigmooze
    bigmooze Well-Known Member
    Richard
    Belle River, ON
    2009 4x4 access cab SR5
    Bilstein 5100's all round (0" up front with stock springs), 265/75/16 Goodyear Wrangler Duratracs, K&N 63 Series Aircharger Kit, Flowmaster Super 44 Muffler, Delta Champion Toolbox, fog lights, back-up lights, Sirius satellite radio with PA15-TOY, Midland 1001z CB radio with 2' Firestik II antenna, Weathertech floor mats, AVS sill protectors, Marathon SuperHides Seatcovers (Universal Digital Camo), trimmed front mud flaps, Viair 20005 OBA, Warn W650D driving lights and W650F fog lights on N-Fab light bar, Hi-Lift X-treme jack with off road accessories, TracRac "TracONE" system
    Would your money not be better spent on new tires, instead of a lawyer?
  8. Aug 5, 2014 at 3:26 AM
    sgtnewundies
    sgtnewundies Well-Known Member
    Eric
    Florida, Citrus County
    14 trd sport red
    Working on it now....UNDER CONSTRUCTION
    Unfortunately nobody wins a dispute like this except the lawyer. One thing to remember. These vehicles are mass produced and there is no such thing as perfect.
  9. Aug 5, 2014 at 3:54 AM
    xbxb
    xbxb Well-Known Member
    Jim
    O.P. Kansas
    2013 SR5 DC, SB, 4WD Pyrite Mica,
    undercover flex, Clazzio seat covers, Flyzeyes, Pop N Lock, Shackle to drag me out
    keep us informed.
  10. Aug 5, 2014 at 3:56 AM
    nealkas
    nealkas Well-Known Member
    nealkas
    Pee-Ay
    08 Superwhite DCSB 4x4, stock.
    What is your hoped for resolution?
  11. Aug 5, 2014 at 4:48 AM
    MagneticTaco79
    MagneticTaco79 COLD ASS HONKY
    AARON
    WV
    Mag Grey 2012 Tacoma AC TRD Sport 4x4
    ALL KINDS OF SHIT
    Welcome to TW!!:thumbsup:
  12. Aug 5, 2014 at 5:41 AM
    wake100
    wake100 Well-Known Member
    Syracuse, NY
    2013 dcsb sr5 4x4
  13. Aug 5, 2014 at 5:53 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    Tundra, double cab.
    LED interior lights, stubby antenna, Pioneer in dash screen, good driver mod.
    Curious as well.
    Ive heard about the vibration since I joined back in 2008... I got wheel shake around 60mph... my current 06 Tundra has wheel shake at 60mph also... annoying? Yes. Worth blowing money on a lawyer? not a chance in hell.
  14. Aug 5, 2014 at 5:55 AM
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    Black Taco '12 4x4
    Delay wiper mod. "Access" Tonneau cover. BedMat.
    At this point I'd either live with it and not be happy, or trade it in for another vehicle. The loss during the trade should be less than the Lawyer's fees and you have an immediate fix.
    Sanity has it's price. :spy:
    Canufixit
    "Sanity is too important to let reality get in the way !"
  15. Aug 5, 2014 at 5:59 AM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    Was the unacceptable vibration not addressed at the time of purchase?
    I would only assume this issue would have been discovered during the test drive.
    There are a number of FJ owners that have vibration issues at the 55 mph to 60 mph range but it goes away. One solution is to change a spring in the steering that stiffens up the feel but helps eliminate the vibration sensation.
  16. Aug 5, 2014 at 6:01 AM
    OCNutty
    OCNutty Well-Known Member
    Northern, Va.
    Silver Prerunner DC v6 SR5 Tow
    Was the TSB 0008-14 done? or is this too new a '14 for it to apply? Not all vibs are 'normal' but some may be. I get a slight vibe at 40-ish and feel the 20mph vibe under certain conditions.....on other forums reported that other vib's were helped with the tsb was installed....
  17. Aug 5, 2014 at 6:02 AM
    Canufixit
    New England
    Black Taco '12 4x4
    Are you referring to the steering intermediate shaft?? I think there was a TCB for replacement with an updated part for previous models??
  18. Aug 5, 2014 at 6:10 AM
    Mobtown Offroad
    Mobtown Offroad The Man Vendor
    Joe
    Greensboro, MD
    2016 DCSB TRD OR, 2013 F-150
    None! Yet...
    Have you asked to drive another similar truck from the dealer and try to recreate the problem you're having in your truck? This way you have a better leg to stand on if it truly is your truck that is the issue.
  19. Aug 5, 2014 at 6:14 AM
    scottalot
    scottalot ...
    on TW
    2015 DCSB Offroad 4x4 MGM Love Machine
    Back Stock Again..Dakkars,305/70/16 MT's, Extended length Fox Coilovers, Fox RR rear Shocks, Total Chaos UCA's, Dakar Leaf packs, LED Map and Dome, Breather relocate, Slimer from Ghost-busters starut up screen, Vent Visors, LED Pod's on Ditch Brackets soon, Level 8 Strike 6 Wheels, New MT Tars - Fierce Attitude, SOS front bumper -steel, SOS bed rack, LED white marker lights, LED reverse, TRD exhaust, Wheelers Super Bumps up front, SOS sliders bolt on with fill plates, Csjummper2003 White/Amber DTRL and white parking led bulbs, RTT rack basket Sold 2013, sold 2014 Tacoma. All listed stuff was on the '14 Bed Mat, WeatherTech Rain Guards, Ultra Gauge, TW Sticker amongst others, Useless Free OEM Bug Deflector, Flyzeye, OME Kit with 885's and Dakar and Nitro Shocks front and Rear . Tailgate mod, SOS Concepts 1/4" Skid Plate, White LED's interior Dome and Maps, Goodyear Wrangler MTR Kevlar 275/70/17, Wet Okole Seat Covers - full piping in Charcoal Grey, Lamin-X Green Fog light film, 17"x8 -10 offset Level 8 MK6 wheels in Gun Metal Finish, SOS Concepts Sliders W/ Kickout 12/21/14, Stubby antenna, LED reverse lights, lift removed 2/20/15 - making changes and trying to make up my mind
    Sounds like a winner to me.
  20. Aug 5, 2014 at 6:23 AM
    Hbr01
    Hbr01 Well-Known Member
    Brian
    Jax, FL
    12 DBC 4x4
    I have this exact same problem, I was just trying to get some new leaf packs and maybe a new drive shaft!
    Some of the vibes at 75+ MPH get pretty strong and it almost feels like I got free dealer issued massage seat.. It feels like it orignates from the back passanger side tire and vibs up through the drive shaft and into the floor boards.
    I have been to the dealer several times and the latest results from the Tech where either 1) a tire out of round... 2) non stock rims 3)lug nuts (non stock) I swapped the lug nuts out with shanked acorn style and it helped alot but the main vibes at 45 and 70+ are still happening.
    I have decided to just live with it though. Mine is a 2012 4x4 Doublecab short bed.
