Archery Talk
Discussion in 'Guns & Hunting' started by -TRDMAN-, Jan 21, 2009.
  1. Nov 23, 2020 at 3:26 PM
    #8421
    JDAM
    JDAM Well-Known Member
    J
    Worshington
    12 DCSB TRD OR
    are you sure it's opposite of rifle sights? quick google search on iron sights.
    If your shot is below (needs to be higher) your target using both sights facing directly at your target, the rear sight should be moved higher or your front sight should be moved lower. Always remember: Move the rear sight in the same direction you want your point of impact to move & your front sight the opposite direction you want POI to move.
    anyways it's all the way down right now. unless I'm dumb.
  2. Nov 23, 2020 at 3:28 PM
    #8422
    six5crèéd
    six5crèéd Be the light
    Southern Virginia
    8 lugs no plugs
    Could just be me but the D looks a little high.
  3. Nov 23, 2020 at 3:36 PM
    #8423
    Z7Xtreme
    Z7Xtreme Always Overestimated
    Chuck
    In a tree somewhere
    2015 trd Black Ops edition
    884's and 5100's with HS 1/4" taco lean spacer,1 inch toytec block and 5100's,SPC uca's,SCS Ray 10 wheels,265/75/16 Falken Wildpeak AT3,oem running boards,oem skid plate,WeatherTech floor liners,WeatherTech window deflectors,Access tonneau cover,WeatherTech stone and bug shield ,BPF tow hook,oem bed mat,pro grill,tacomabeast headlights,cali raised ditch brackets with Rigid lights,Rough country 30” lightbar on Rigid brackets RCI bedrack, KC rear lights,maxtrax,dual rotopax.
    Did you have the peep sight tied in to fit you or is that where it was for the previous owner?
  4. Nov 23, 2020 at 3:39 PM
    #8424
    JDAM
    J
    Worshington
    12 DCSB TRD OR
    everything is setup as the previous owner had it. and he just restrung and retuned before 2019 hunting season.
  5. Nov 23, 2020 at 3:39 PM
    #8425
    Z7Xtreme
    Chuck
    In a tree somewhere
    Sure does!!! I think he should have a pro shop set everything to fit him.
  6. Nov 23, 2020 at 3:42 PM
    #8426
    Z7Xtreme
    Chuck
    In a tree somewhere
    @JDAM ^^^^ my last post.
  7. Nov 23, 2020 at 3:59 PM
    #8427
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    the peep should be at a comfortable point for YOU at full draw... If you are streatching your neck up you are too high down you are too low,
    https://www.bowhuntingmag.com/editorial/goof-proof-tips-for-sighting-in-your-bow/310633
  8. Nov 23, 2020 at 4:03 PM
    #8428
    JDAM
    J
    Worshington
    12 DCSB TRD OR
    roger that. feels comfy to me though. I had the draw length adjusted to be comfortable to me. I guess that's the only thing that changed since I bought it.
    Now if the D loop is high wouldn't lowering it cause it to shoot even lower?
    sorry if I'm derailing this thread whilst people are hunting. There is a good shop I can go to about 30 minutes away.
  9. Nov 23, 2020 at 4:10 PM
    #8429
    wilcam47
    Will
    Bourbon state
    Well the d loop should be centered on the arrow rest mounting holes. Like in the begining of the video i posted.
    Your sight height needs to come down to raise your arrow.
  10. Nov 23, 2020 at 4:18 PM
    #8430
    wilcam47
    Will
    Bourbon state
    If you are hitting above the intended spot, move the sight body up. Move it down if you are hitting below your intended spot. If you are hitting to the left of the spot, move the sight body to the left. Move it to the right if you are hitting to the right of the spot.
    1buzzbait and six5crèéd like this.
  11. Nov 23, 2020 at 4:43 PM
    #8431
    JDAM
    J
    Worshington
    12 DCSB TRD OR
    ya that's the problem. I'm hitting low and the site body won't go any lower. it's maxed out in that direction.
    1buzzbait and wilcam47[QUOTED] like this.
  12. Nov 23, 2020 at 4:47 PM
    #8432
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Can you adjust the pins individually?
  13. Nov 23, 2020 at 4:48 PM
    #8433
    Wyckedan
    Wyckedan Well-Known Member
    Dan
    Woodinville WA
    2014 Stormtrooper AC 2009 Ducati Hypermotard 1100s.
    1 fully operational Death Star
    Knowing you and I are about the same height, you should have zero problems getting the sight low enough. It just needs to be setup. It definitely appears out of whack
  14. Nov 23, 2020 at 4:51 PM
    #8434
    rtkbowhunter
    rtkbowhunter Well-Known Member
    Southeast PA
    2011 Tacoma Quad Cab SR5
    Where are you anchoring at full draw? Perhaps a kisser button an 1" to 1-1/4" above the D loop.
  15. Nov 23, 2020 at 4:58 PM
    #8435
    JDAM
    J
    Worshington
    12 DCSB TRD OR
    only the lower four pins move
    ya I guess another trip to The Nock Point is in order. It's not hitting all that low though. I just aim a few inches high and hit my bullseye at 20. I have to clear some brush to set up a longer range.
    thanks for the help all. I'll get it figured out.
  16. Nov 23, 2020 at 4:58 PM
    #8436
    wilcam47
    Will
    Bourbon state
    The way you have it now its on the high side...
  17. Nov 23, 2020 at 4:59 PM
    #8437
    Wyckedan
    Dan
    Woodinville WA
    That's not the problem. You shouldn't have to have the sight that low to shoot 20 yards. That bow should be good out to 100. There's no way you could shoot that with the sight where it is
    1buzzbait, six5crèéd and wilcam47 like this.
  18. Nov 23, 2020 at 5:00 PM
    #8438
    wilcam47
    Will
    Bourbon state
    How many pins is it? 4 or 5?
  19. Nov 23, 2020 at 5:12 PM
    #8439
    buckhuntin-tacoma
    Dennis
    Quincy IL
    If your pins aren’t bottomed out try lowering your pins which should raise your point of impact.
    wilcam47 and six5crèéd like this.
  20. Nov 23, 2020 at 6:34 PM
    #8440
    StayinStock
    Bob
    Missouri
    Yes I do
    Some
    I may be wrong here (I usually am) but I'm with @six5crèéd , if you lower the d loop, it lowers the back (nock end) of your arrow...which should raise the front (broadhead end) of your arrow. So basically, take it to a shop.
