Archery Talk
Discussion in 'Guns & Hunting' started by -TRDMAN-, Jan 21, 2009.
  1. Sep 17, 2021 at 5:43 PM
    #9301
    tonykarter
    tonykarter Crappie Savant
    Snuff Gully, Texas
    2018 DCSB 4x4 Sport 1993 4Runner SR5 4x4, 411,000 miles
    Pine tree air freshener
  2. Sep 17, 2021 at 8:58 PM
    #9302
    Dangerdave
    Dangerdave Official TW jeep representative
    David
    Wilmington, NC
    20 F150
    Got some decent bucks on camera the last month or so. Hoping they stick around for the rut. Got a hunt planned for my land in E TX and one more for Buffalo NY before season ends
  3. Sep 18, 2021 at 1:31 PM
    #9303
    rustyfromskowhegan
    rustyfromskowhegan Well-Known Member
    2013 AC 4x4
    Anyone have experience with Diamond bows by Bowtech? I’m looking at a used Diamond Rapture that I’m hopeful I can get for a good price (hopefully 150ish) then take to a shop and get it tuned and fit for me (first bow). The diamond bows seem to be well reviewed but not sure if there are any bows of the brand that I should stay away from. Went to a shop today but wasn’t able to pull any and they only had 2 used bows
  4. Sep 18, 2021 at 1:42 PM
    #9304
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    they prob had it set too high or out of your draw length.
    We had a diamond for my wife, she had it at 50lbs and could draw it easily. I shot it a few times. It was really light easy draw. Had to sell it because wifes shoulder surgeries wouldnt let her hold at full draw for long and caused her pain. Not cuz of the bow.
    50-60lb draw is plenty to kill a deer or even elk. Fyi
  5. Sep 18, 2021 at 1:47 PM
    #9305
    rustyfromskowhegan
    2013 AC 4x4
    I should have specified, I didn’t pull any because I didn’t request it and the guy working was dealing with another customer and I was really just kicking tires and seeing what they had in stock. But in reality no chance I’m able with to pull a 70lb bow consistently or making an accurate shot. 50-60 is probably where I’ll be. White tails in the northeast is what I’m after. Thanks for the feedback on the diamond. I liked that the draw weight and length are widely adjustable. I have longish arms so my draw length is likely between 30-31 inches
  6. Sep 18, 2021 at 1:51 PM
    #9306
    wilcam47
    Will
    Bourbon state
    Yeah make sure they get your draw length right. Im not sure what the max is on that bow.
    buckhuntin-tacoma likes this.
  7. Sep 18, 2021 at 1:55 PM
    #9307
    rustyfromskowhegan
    2013 AC 4x4
    From what I could find online it looks like it goes up to 31”. I was hoping to find a used one at a shop, but their cheapest one was 315 without anything on it. No rest, sight, quiver, nothing. Gonna have to check out some more shops, but this cheap rapture leaves some $$ for tuning
  8. Sep 18, 2021 at 1:59 PM
    #9308
    wilcam47
    Will
    Bourbon state
    Check your local craigslist, sometimes a good deal there
  9. Sep 18, 2021 at 2:36 PM
    #9309
    Z7Xtreme
    Z7Xtreme Always Overestimated
    Chuck
    In a tree somewhere
    2015 trd Black Ops edition
    884's and 5100's with HS 1/4" taco lean spacer,1 inch toytec block and 5100's,SPC uca's,SCS Ray 10 wheels,265/75/16 Falken Wildpeak AT3,oem running boards,oem skid plate,WeatherTech floor liners,WeatherTech window deflectors,Access tonneau cover,WeatherTech stone and bug shield ,BPF tow hook,oem bed mat,pro grill,tacomabeast headlights,cali raised ditch brackets with Rigid lights,Rough country 30” lightbar on Rigid brackets RCI bedrack, KC rear lights,maxtrax,dual rotopax.
  10. Sep 18, 2021 at 2:39 PM
    #9310
    wilcam47
    Will
    Bourbon state
    :yes: good luck!
  11. Sep 18, 2021 at 3:04 PM
    #9311
    Taco-Grinder
    Dan
    Fond du Lac, WI
  12. Sep 18, 2021 at 3:06 PM
    #9312
    StayinStock
    Bob
    Missouri
    Yes I do
    Some
    :yes:
    Good luck!
  13. Sep 18, 2021 at 3:42 PM
    #9313
    Z7Xtreme
    Chuck
    In a tree somewhere
  14. Sep 18, 2021 at 8:48 PM
    #9314
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    I've never shot one but I've also never heard anything bad about them either. Not sure what model it is but one of them has a very large adjustment range for the poundage. I often see that recommended for beginners.
  15. Sep 20, 2021 at 11:03 AM
    #9315
    wilcam47
    Will
    Bourbon state
    cant go wrong with muzzy broadheads, G5 also good. Most Crossbows should have a crank you can buy for them, makes it super easy
    StayinStock likes this.
  16. Sep 20, 2021 at 11:55 AM
    #9316
    wilcam47
    Will
    Bourbon state
    400fps is pretty fast, def get the crank. You prob be good out to 80yds easy. But the fun in bow hunting gor me is under 40yds
    https://www.ebay.com/itm/2034011599...%3A1&msclkid=43fcec99bff21e08fa3a8dd167d8f7a6
  17. Sep 20, 2021 at 11:59 AM
    #9317
    wilcam47
    Will
    Bourbon state
    also note, some fixed broadheads will fly different than target heads. So always shoot with what you will be hunting with.
    Follow the maintenance or string lube/wax requirements. Keep fingers away from string travel.
    Front sight and StayinStock like this.
  18. Sep 20, 2021 at 12:02 PM
    #9318
    wilcam47
    Will
    Bourbon state
  19. Sep 20, 2021 at 12:14 PM
    #9319
    wilcam47
    Will
    Bourbon state
    Might want to lube the front part of the bolt also...
  20. Sep 20, 2021 at 1:11 PM
    #9320
    wilcam47
    Will
    Bourbon state
    the pull rope will help but still its a heavy draw weight for that speed crossbow.
    The crank is gonna be worth your time.
    If you are hunting out of a blind anything under 40yds is going to shoot right through a deer unless you hit spine or shoulder, even then with that bow it prob will blow through and not necessarily drop it. But depends where you hit it it most likely will be mortal.Helps to find the arrow/bolt to see if theres blood on it. And what it smells like.
    Oh also on practice targets, only shoot one at a time at the "bulls eye", you can and will stack the the bolts/arrows and thats expensive
