Archive Hanger Install Assistance/Motivation
Discussion in '3rd Gen. Tacomas (2016-2023)' started by CAG Gonzo, Apr 5, 2020.
  1. May 4, 2022 at 7:46 AM
    #81
    Buttskevin21
    Buttskevin21 Well-Known Member
    Kevin
    Washington
    2019 Brocoma, 37s, Lt, Dual Tcases, blah blah blah https://www.instagram.com/kevinjbutts/
    Stock-ish
    Let me know if you need any photos/measurements! I've 63 swapped 3 newer Tacoma's, doing another one this weekend actually haha.
  2. May 4, 2022 at 8:58 AM
    #82
    dk_crew
    dk_crew Well-Known Member
    Dave
    Austin, TX
    2005 Tacoma 4x4
    thanks @Buttskevin21 - I may move questions over to the 63 swap thread (sorry for hijacking) and will certainly add questions or possibly PM you as I run into issues I can't wrap my head around ... if you have any "keep this front and center in your head" tips please shoot over the notes. For me the basics include:
    • do you remove the bed and gas tank? I assume that makes everything simply easier in terms of access and maneuvering - not to mention welding near the tank?
    • measure, measure, measure. I have an 05 and initial estimates have me pushing the front hangers 4 5/16" forward, tack in and work from there - but will methodically go through once I'm in there.
    • add some weight to the bed (I have 400lbs of weights in the garage where I'll be doing the swap) when setting the rears and shoot for a good shackle angle (? ~15* ?) and verify a good lift height.
    • patience
    I have the ruff stuff kit but referencing the lowrangeoffroad instructions since they have quite a bit of detail.
  3. May 4, 2022 at 9:20 AM
    #83
    05 4x4
    05 4x4 Well-Known Member
    On a stock 3rd gen, when hitting some extended length potholes, potholes on turns and transitions from ac pavement to dirt roads, my back end gets jumpy, loose and feels like it wants to loose control. One time has lost control(but I saved it easily). Would these hangers help in these situations?
  4. May 5, 2022 at 9:44 AM
    #84
    Glueman
    Glueman Yersinia pestis
    Utah
    The Plague....
    6 inch Douche Bag lift...what else do I need?
    Not likely.
    05 4x4[QUOTED] likes this.
  5. May 5, 2022 at 9:51 AM
    #85
    05 4x4
    I thought thats what they essentially did. Thats what the advertisements say it does. Im just looking to confirm... Any additional input would be appreciated!
  6. May 5, 2022 at 10:03 AM
    #86
    Buttskevin21
    Kevin
    Washington
    Stock-ish
    The rear end can only handle so well.
    Varies with shocks, shock tuning, leafs, tire size, tire pressure, how much your truck weighs, how much weight you have over the rear end, etc. Not just if you have hangers or not.
