Arctic Travel - California to Arctic and Back in Winter
Discussion in '2nd Gen. Tacomas (2005-2015)' started by vijay, Dec 11, 2015.
  1. Oct 10, 2016 at 9:41 AM
    #321
    AKHawkeye
    AKHawkeye Well-Known Member
    Anchorage, AK
    15 AC Sport 4x4 6 Spd
    Locked as stock
    Yeah, straight through. I work 12-14 hour days anyways to it wasn't too bad. Left Coldfoot at 0530-0600. Arrived in Fairbanks around 1200. Left Fairbanks at 1400 and arrived in Anchorage at 1900. Had the truck turned back in at the lot and at home with a cold brew in hand by 1930. Drove approximately 652 miles and used around 35 gallons of diesel.
  2. Oct 12, 2016 at 12:39 PM
    #322
    vijay
    vijay [OP] Well-Known Member
    nice!!!!
  3. Feb 1, 2017 at 10:26 PM
    #323
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    i got a chance in Jan./17 to work in Alaska, and that included driving to remote Telecom sites from Deadhorse to Coldfoot. This seemed as good a place as any to add some pics. These are pics of the Atigun Pass, north of Coldfoot. This was in a leased for the Dalton' vehicle from Delta Leasing in Prudhoe Bay. Vijay's descriptions helped prep for the trip, or at least a heads up for what to expect up here.
    North Side bottom pullout awaiting the pass of a tanker.
    The north side of the pass, see the Tanker coming down the 10-12% grade. There are no runaway lanes.
    Cresting the pass, headed on South side.
    South side looking downhill
    near the north side crest, on a different day.
  4. Feb 1, 2017 at 10:49 PM
    #324
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Caribou. Did not get to see a fox, or bison, but did see some arctic (rock) ptarmigan. Found wolf tracks too near Coldfoot.
  5. Feb 2, 2017 at 10:45 AM
    #325
    Whitetrash
    Whitetrash Well-Known Member
    Jimmy
    San Diego CA and Enon OH
    2008 Prerunner Regular Cab SR5
    Wheeler's AAL, 5100s at 1.75, 265/75r16
    this is by far one of the coolest threads i have ever seen! took a while to read through it and very glad i did. AWESOME TRIP AND PICTURES!!
    vijay[OP] and BrokenMech like this.
  6. Feb 4, 2017 at 3:28 PM
    #326
    AKHawkeye
    Anchorage, AK
    Locked as stock
    If you don't mind me asking, were you looking at the fiber optic cabling/regen sites being installed? I'm curious because my employer is installing the GCI fiber in that exact stretch (Galbraith Lake to Coldfoot) parallel to Quintillions. I'm one of the technicians tasked with splicing it. I was last up in that stretch in October/November and I'll be back this spring to finish up.
    South side of Atigun pass (seen on the left).
    vijay[OP] and DrFunker like this.
  7. Feb 5, 2017 at 2:03 AM
    #327
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Yup.
  8. Feb 9, 2017 at 11:32 AM
    #328
    AKHawkeye
    Anchorage, AK
    Locked as stock
    Heh, small world.
    VE7OSR[QUOTED] likes this.
  9. Jun 29, 2017 at 1:39 PM
    #329
    vijay
    I'm late to reply here but I'm glad you enjoyed the trip. It's beautiful up there!!!
  10. Jun 29, 2017 at 10:31 PM
    #330
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    and we're installing the equipment connecting to that fiber. Work schedule had two of us assigned to that, but now the schedule changed, Hope it changes back again so I can see that area in the summer.
    vijay[OP] likes this.
  11. Jun 30, 2017 at 6:24 PM
    #331
    AKHawkeye
    Anchorage, AK
    Locked as stock
    Just got done and back tonight after splicing the 25 remaining points and certifying/testing it.
    Started middle of May when everything was brown, now both sides of the pass are green and beautiful. Coldfoot was 60*F when I left at 0600, was supposed to reach the mid 70's today. Think I'll jump in the truck and head up there sometime in August for the sole purpose of hiking/climbing.
  12. Jun 30, 2017 at 6:29 PM
    #332
    Oreo Cat
    Oreo Cat Worst Member
    Coeur d’Alene, Idaho
    What's the thing on the grille for
  13. Jun 30, 2017 at 11:02 PM
    #333
    AKHawkeye
    Anchorage, AK
    Locked as stock
    Its a cover to help keep engine heat within the engine compartment. Pretty important at those low temperatures.
    Oreo Cat[QUOTED] likes this.
