Arctic Travel - California to Arctic and Back in Winter
Discussion in '2nd Gen. Tacomas (2005-2015)' started by vijay, Dec 11, 2015.
  1. Dec 15, 2015 at 9:22 PM
    #121
    jeverich
    jeverich Well-Known Member
    Jake
    PNW/Kodiak
    07 2.7 4x4
    OME 886/Old Man Doug Suspension Lift, ARB Bumper, Bruteforce High Clearance w/Swing Out, De-badge, Block Heater, Homemade IFS Skid, 7" Kragens, Blue Seas Fuse Block, BlitzPro Fogs, 12k BadLands Winch, BAMF Sliders, ARB Locker, 4.88s Yaesu FT-1900R, Larsen 150B NMO Mount Antenna
    For sure. Not trying to be a dick; but as DoorDing said... Slow down. Salt and sand are virtually non-existent once you get to the "real road". As soon as I got north of Dawson Creek there was a plethora of cars and trucks towing 5th wheel campers in the ditches - the weather had turned to shit, and a recovery wasn't feasible until the spring thaw. Don't be one of those guys.
    Another word of advice - be very careful traveling over the holidays. Most of the gas stations in the YT have no problem with closing for the holidays - especially after dark. I literally made it to Palmer Junction on fumes due to my own ignorance.
    Crom, vijay[OP] and DoorDing like this.
  2. Dec 15, 2015 at 9:25 PM
    #122
    vijay
    vijay [OP] Well-Known Member
    Yes, thank you. I filled up all 4 cans in Seattle( 18-20 gallons on stand by).
  3. Dec 15, 2015 at 9:27 PM
    #123
    vijay
    Travel times are the same but place were a bit ahead.
  4. Dec 15, 2015 at 9:35 PM
    #124
    jeverich
    Jake
    PNW/Kodiak
    07 2.7 4x4
    Totally botched that post - stay with me whilst I navigate these interwebs...
    You're on the cusp of the snow covered section of the highway. Don't expect it to go away until June. That being said; I found that most of is has okay traction. Don't expect to stop within a reasonable distance, as it's not going to happen.
    There were a couple of conditions I found that had absolutely shit traction; the one that sticks out most prominently was this:
    Shit traction on top of an ice base. You'll become familiar with a highly scientific method deemed the "Pucker Factor".
    Most of the road has good traction, though.
    If I'm bugging you with my posts, let me know... Mostly you're making me want to do the drive again.
    Pirhett, Biscuits, nTg and 4 others like this.
  5. Dec 15, 2015 at 9:52 PM
    #125
    vijay
    Hey team, It turns out my previous post came out all negative. But the fact is, Canada is just awesome, it's absolutely beautiful. I wish I could spend a week between Hope, BC and CacheCreek, BC( right along hwy 1). This is what vacations are made of....
    On way to Prince George, BC
  6. Dec 15, 2015 at 9:53 PM
    #126
    vijay
    No, you are not bugging anyone...keep them coming.
    Crom likes this.
  7. Dec 15, 2015 at 9:53 PM
    #127
    Yukon Yak
    Yukon Yak Well-Known Member
    Denis
    Whitehorse, Yukon Canada
    2015 TRD Access Cab Trails Team
    BFG KO2 285/75R16 OME 886/Dakars Rotopax Pelfreybilt Aluminum Front/Rear HC with gate Dual Batteries Rigid fogs, 20 inch spot/flood, SQR back up Cobra 75, 3' fire stick Custom Storage/Dog Platform in Cab Allpro Apex sliders Allpro Apex Aluminium Pack Rack Allpro Aluminium Gear Rack
    We have been having a great warm winter ... Not allot of snow. it should be smooth driving through the Yukon ... Water is still open everywhere so expect some ice fog along the way if the temperatures dip. I'll PM you my info
    Pirhett and vijay[OP] like this.
  8. Dec 15, 2015 at 9:54 PM
    #128
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    The moose by MacLeod Lake are especially frequent!You will see the places they break through the snow bank to come out on the road to lick the salt. They are the same colour as the pavement so especially hard to notice at night with their head down on the pavement. If you are going to collide with a moose, get your head down onto the passenger seat; Those 800lbs are coming into your windshield!
    Bijoux Falls is always a cool spot to stop, just before you climb up the hill into Pine Pass. In the Pine Pass be aware , even if the road is bare and wet in the winter there are several sharp corners that are shaded all day, and end up being very icy. There are two or three corners like that with the river on your left side, and the mountain side on your right as you are headed to Chetwynd. Heart Lake is a cool area, with a Forestry camp site. There are a few cabins on the short gravel road in, so sometimes it is kept open in the winter, but not always.
    There are two routes outside of Chetwynd, one takes you via Hudson's Hope to Ft.St. John, and is actually shorter for you as it comes out on far NW end of Ft.St. John. The W.A.C Bennett Dam is right close by on this route, and is an impressive sight. The other route makes a big triangle route to Ft.St. John via Chetwynd North east to Dawson Creek, (a must tourist stop) then west to Ft.St. John and is the most common route. We always took a shortcut to cut that triangle off via Sunset Prairie Rd (gravel roads through rural farms, and oil patch) Side trip to Tumbler Ridge is cool, lots of wildlife in there.
    vijay[QUOTED][OP] and DoorDing like this.
  9. Dec 15, 2015 at 9:57 PM
    #129
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Yup, they have the snowflake. I use them as my summer tire. LOL
    DoorDing likes this.
  10. Dec 15, 2015 at 10:01 PM
    #130
    vijay
    I wish! but I have to get back to my kid. Now that I know places like this do exists not just in movies or fairytales, I will be coming back. This place is an absolute paradise.
    2big4arunner likes this.
  11. Dec 15, 2015 at 10:02 PM
    #131
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    That big rock in the Thompson River is called "the frog" I've been through that section when there is water coming onto the highway (one lane was closed , and traffic controlled) and the water pillow was pushing up against and pouring over the frog! They white water run that section of River from Spences Bridge to Lytton. Clinton through to 100 Mile House can be especially nasty in a winter storm! lots of black ice. Your last pic looks like just south of 100 Mile House. If that's right, there is a forestry lookout tower at the top of the hill on the right, called Begbie Mtn. It's a short 5-10min. hike for some awesome views from there, especially on a clear day.
    Crom and vijay[QUOTED][OP] like this.
  12. Dec 15, 2015 at 10:38 PM
    #132
    StOrMyThEtAcO
    StOrMyThEtAcO @stormythetaco
    Cody
    CO
    18 TRD Sport mom bus
    All of them
    Jealous.
    Just started watching the expedition overland series on YouTube an it makes me want to go up that way so bad.
    Stay safe Vijay :thumbsup:
    cruiseroutfit, VE7OSR and vijay[OP] like this.
  13. Dec 15, 2015 at 10:53 PM
    #133
    Sdtrueblue
    Sdtrueblue Well-Known Member
    Markie B
    San Diego, CA
    2015 DCLB Sport
    6112’s/5160’s Snugtop Rebel NTG’s 265/70/17
    The best thread I've read all week!!
    I live vicariously through others' adventures.
    :cheers:
    SC2SC, vijay[OP] and VE7OSR like this.
  14. Dec 16, 2015 at 6:43 AM
    #134
    Mad Man Marty
    Mad Man Marty Well-Known Member
    Marty
    PA
    2007 Tacoma SR5 TRD Sport
    6speed, TRD intake, bed tie downs, weathertech rear,Tint
    Looks like fun.
    OP,please tell me you have a gun.
    Be careful.
  15. Dec 16, 2015 at 6:44 AM
    #135
    theredofshaw
    theredofshaw Well-Known Member
    Somewhere on the East coast
    not a taco (guess that means I can be a MOD now)
    (totaled) 2011 Tacoma DC
    he drove through canada, if he had one when he started he probably doesn't have it anymore...lol
    nickj604 and DrFunker like this.
  16. Dec 16, 2015 at 9:13 AM
    #136
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Its true , everybody I know is likely to die at any moment
    FLYH2O, Biscuits, Hartford and 4 others like this.
  17. Dec 16, 2015 at 9:22 AM
    #137
    la0d0g
    running for the hills
    For crawling not hauling
    Me too! Something about being an organism :notsure:
    Hartford likes this.
  18. Dec 16, 2015 at 9:23 AM
    #138
    evan
    evan Well-Known Member
    SK, Canada
    Post of the year!
  19. Dec 16, 2015 at 9:46 AM
    #139
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    Great pics.
    How long is this trip? Duration, was it ever touched upon?
    vijay[OP] likes this.
  20. Dec 16, 2015 at 10:22 AM
    #140
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    You can bring your long gun into Canada, just not the assault carbine or handgun.
    http://canada.usembassy.gov/traveling_to_canada/bringing-weapons-into-canada.html
    I know, amazing place Canada is, where you could die without your gun beside you. We prefer teddy bears.
    I read that as 'orgasm' at first glance.
    Biscuits, Jaab and la0d0g[QUOTED] like this.
