Arcticelf's sold his truck BS thread
Discussion in '2nd Gen. Builds (2005-2015)' started by Arcticelf, Jul 27, 2015.
  1. Apr 7, 2019 at 7:15 AM
    #621
    Grand dude
    Grand dude Well-Known Member
    Dave
    lehigh valley, PA.
    2016 trd or dcsb & 2002 trdor exclb
    cool stickers and a baseball card With clothes pin, sounds awesome ! wicked
    :spy:
  2. Apr 7, 2019 at 8:18 AM
    #622
    Skierrichy
    Skierrichy MadRad
    Richard
    Willington
    2011 TRD
    To many, but never done
    :rofl:im rubbing left side where CMC is!
    Looks like I'm cutting more:fingerscrossed:
    steele-taco likes this.
  3. Apr 8, 2019 at 7:25 AM
    #623
    Arcticelf
    Arcticelf [OP] Well-Known Member
    Gladiator
    Just keep cutting :)
  4. Apr 8, 2019 at 7:30 AM
    #624
    Arcticelf
    Gladiator
    Exactly this. I like the crossmember.
    EatSleepTacos[QUOTED] and Bastek like this.
  5. Apr 8, 2019 at 7:31 AM
    #625
    Arcticelf
    Gladiator
    Just remember to make sure there is clearance to adjust the clevis. That's one thing I did wrong and it's a pain.
    EatSleepTacos and Bastek[QUOTED] like this.
  6. Apr 8, 2019 at 7:44 AM
    #626
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Thanks, I really like it too. And adjustments are a piece of cake. Plus I think the angled straps look really cool.
    Arcticelf[QUOTED][OP] and Bastek like this.
  7. Apr 8, 2019 at 7:49 AM
    #627
    Bastek
    Bastek Average Member
    Seb
    SI NY
    '17 OR dcsb
    KDMaxP10, plastidip
    I like that as well :thumbsup:.
    Only thing I would worry about in my case, is frame flex. It could crack the welds. Unless I'm overthinking it.
    You have that fancy cross brace between your shackle mounts, right? If so, that would prevent some flex
  8. Apr 8, 2019 at 8:12 AM
    #628
    Arcticelf
    Gladiator
    It will help limit frame flex, which is another benefit
  9. Apr 8, 2019 at 8:12 AM
    #629
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Yeah, so I have two crossbars out back
    Bastek[QUOTED] likes this.
  10. Apr 8, 2019 at 1:32 PM
    #630
    steele-taco
    steele-taco Well-Known Member
    james
    Jersey shore
    17 TRD OR DCSB white
    @EatSleepTacos
    Do you have a brace across your rear shock towers, or at least the option to put one there?
  11. Apr 8, 2019 at 1:36 PM
    #631
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    No. The only off the shelf one that does that is archive garage, at least that I’m aware of.
  12. Apr 8, 2019 at 1:42 PM
    #632
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
  13. Apr 8, 2019 at 1:48 PM
    #633
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
  14. Apr 8, 2019 at 2:22 PM
    #634
    steele-taco
    james
    Jersey shore
    I was thinking that’s what you had. Now I remember you welding up some pre cuts.
    I’m thinking about the archive and putting a brace in and kinda making a tire shelf/rack.
  15. Apr 8, 2019 at 2:35 PM
    #635
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    No, I have BAMF towers but I have archive hammer hangers with a cross bar. Maybe that’s where the confusion came from. And that’s a good idea. I’m working with a local member to build him one off of his archive towers
  16. Apr 11, 2019 at 3:54 AM
    #636
    steele-taco
    james
    Jersey shore
    Want to hit AOAA the 19th or 20th or both?
  17. Apr 11, 2019 at 4:14 AM
    #637
    Skierrichy
    Skierrichy MadRad
    Richard
    Willington
    2011 TRD
    I want to so bad but I need to get re-geared down at ECGS first either last weekend in April or first weekend in May.
    Then I will after.
    fatfurious2 likes this.
  18. Apr 11, 2019 at 7:20 AM
    #638
    Grand dude
    Dave
    lehigh valley, PA.
    Hey Terin i need to pick your brain...
    I just finished wiring new trailer lights( break, turn...etc) I have grounded the lights to the trailer then ran a grounding wire from the trailer to the four pin harness, all is good. My question is; I want to add an Independent Electrical System to the trailer containing 12 volt battery, fuse block, switching and eventually solar to run auxiliary lighting,Refrigeration ,and any other goodies I can come up with. The question is can i ground these additional accessories to the trailer as well without interference too the trailers running light system and Tow vehicle or do I need to run independent grounding to the trailer battery?
    Skierrichy and fatfurious2 like this.
  19. Apr 11, 2019 at 7:36 AM
    #639
    Redmann
    Redmann DILLIGAF
    Reds
    Not Philly
    2009 AC TRDOR
    Yeah. Ground to the trailer.
  20. Apr 11, 2019 at 7:37 AM
    #640
    Grand dude
    Dave
    lehigh valley, PA.
    will cause conflict ?
