Are 10 ply Duratrac's too much tire?
Discussion in 'Wheels & Tires' started by Fabulous, Jan 16, 2011.
  1. Jan 16, 2011 at 2:32 PM
    Fabulous
    Fabulous [OP] Well-Known Member
    Fabian
    Calgary, AB
    2017 Tacoma double-cab TRD Sport
    TRD Pro grill and fog lights, Toytec Boss lift, 265/70-17 Duratracs on 17 x 8.5 FN Verge wheels, LEER canopy, 30% tinted front windows.
    A guy locally is selling some brand new 10 ply 265/70-17 Duratrac's for almost half the price of new. I was gonna get the c load ones, but for the price would the 10 ply ones not work?
  2. Jan 16, 2011 at 2:38 PM
    98_Mud_bug
    98_Mud_bug 98_mud_bug
    lucedale Ms.
    98 tacoma sr5/ 06 x-runner
    3 inch suspension lift, night shades corner and blinkers projector headlights with halos and 3 led's 18 inch kmc xd rockstar wheels,275/65/18 kelly safari tsr's, bush whacker fender flares 7 inch touch screen, 2 kenwood 12's, Magnaflow exaust single in dual out,
    they will be fine, you dont have to run the rated psi in them, i have 10 ply kelly safari tsr's, i only rin 40psi in them.
  3. Jan 16, 2011 at 2:53 PM
    BrettBretterson
    BrettBretterson Wild Ginger
    Bothell, WA
    06 DCSB TRD OR 4x4
    5100's
    No reason not to get them, especially for half price. Jump on it!
  4. Jan 16, 2011 at 3:12 PM
    Yamaha Dave
    Yamaha Dave Well-Known Member
    I'll give you two reasons why it would be retarded to run 10 ply.
    1.) Your ride will be like a dump truck
    2.) Your MPG will drop significantly
  5. Jan 16, 2011 at 3:20 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Fabian ,
    I have 265/70/17 10 ply Hankook Dynapro M/T's , in all honesty the next time I buy tires I will probably get AT's , but my truck does not ride like a dump truck , and I average 18 MPG .
  6. Jan 16, 2011 at 3:25 PM
    primer
    primer Well-Known Member
    T
    OK
    06 SS Mica AC 4x4 TRD Off-Road
    (Mostly) debadged, Homelink mirror, Elevated rear diff breather, LED illuminated 4x4 switch, Color matched grill surround, Bed cover, Ivan Stewart wheels, Bridgestone 265/75 Dueler AT Revo 2 tires
  7. Jan 16, 2011 at 3:25 PM
    Fabulous
    Fabian
    Calgary, AB
    Thanks for the reply's...don't matter anyway, the tires sold in 25 minutes.
  8. Jan 16, 2011 at 4:19 PM
    HUNT
    HUNT Well-Known Member
    Tommy
    Wildwood Ga
    2003 Double cab 4x4
    Bilstein 5100 set @ 0, OME 881,Wheelers 5-leaf, OME NitroCharger Sport shocks, 4-RUNNER LIMITED WHEELS, Duratracs, 265/75/16
    x2
  9. Jan 16, 2011 at 4:54 PM
    BrettBretterson
    Bothell, WA
    06 DCSB TRD OR 4x4
    5100's
    You have no idea what you're talking about. I am currently running 10 ply E load 18" Duratracs and experience neither. The tires do not ride harsh and I'm still getting 18 MPG on 32's.
  10. Jan 16, 2011 at 6:08 PM
    Yamaha Dave
    Going to a 10 ply load E rate tire will produce a harsher ride and will reduce your MPG. That is 100% FACT.
    Have ever actually weighed a load E rated tire? So unless you can prove otherwise that somehow Load E tires are magically made of some new light weight synthetic rubber and weigh less than a load C than I'd say you have no idea what you're talking about.
    The average E rated tire was designed to handle about 3,000-3,5000 lbs. PER tire. Something our little Tacomas couldn't even handle. You do realize that tires like that were designed for trucks like half tons and F-250s right? So as I've said before why you would willingly buy and E rated tire unless you had no other possible choice is beyond me.
    :boink:
  11. Jan 16, 2011 at 6:11 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    x2! But the reason you'd buy a tire that heavy for a truck our size is for off-roading. The heavier tire has a thicker sidewall and would be much harder to puncture. Otherwise, for road use, I couldn't agree more.
  12. Jan 16, 2011 at 6:12 PM
    OZ-T
    Peter North
    British Columbia
    My truck is on 10 ply Hankook MT's and it doesn't ride like a dump truck , as you put it .
    I also average 18 mpg , good enough for me , thanks for your concern though ;)
  13. Jan 16, 2011 at 6:59 PM
    BrettBretterson
    Bothell, WA
    06 DCSB TRD OR 4x4
    5100's
    That is not 100% fact actually. Do you not realize they make different compounds of rubber? Have you ever owned Duratracs? Do you have any idea how soft they are? Have you ever worked in the tire industry? If not, you probably also don't realize that full size truck owners constantly complain of 10 ply Duratracs producing a soft squishy ride.
    And yes, I have weighed them actually, and I can answer yes to all of the above.
  14. Jan 16, 2011 at 7:03 PM
    Dibblit
    Dibblit Eh?
    Paul
    Fort McMurray
    11 Tacoma
    OME suspension ARB OBA ARB locker
    I had the same problem, 10ply Toyo M/T 285/75/16. Thought about it 5 min too long and they were sold. lasted 15 min on kijiji
  15. Jan 16, 2011 at 7:34 PM
    Yamaha Dave
    1.) Of course they make different kinds of rubber compounds that's what sets most of the tires apart besides the actual structure and tread design which is the compounds they are composed of.
    2.) Do I own Duratracs? No I have BFG A/T KOs. That's of no significance. A 10 ply Load E rated tire is a 10 ply Load E rated tire.
    3.)Yes as a matter fact I do I worked at a Tire dealer in Houston for 4 years, than moved on to my career in another field.
    4.)I am aware of full size truck owners complaining about the squishy ride and also "highway wondering." I am also aware that common sense tells me that most of these full size trucks probably weigh in excess of 6,000 lbs. empty with no load. Not to mention most of these guys will probably be loading equipment in the back and maybe even pulling a fully loaded trailer with a Bobcat in addition to that.
    :rolleyes:
  16. Mar 7, 2018 at 10:48 AM
    cargreg
    cargreg Member
    Greg
    Fort Mill, South Carolina
    2020 TRD Offroad 6M
    Bilstein 6112 on 6/5th notch front, Wheeler's Offroad AAL in rear with Bilstein 5160 shocks.
    I know this is a really old thread, but this is one of the first things that came up when I Googled "Tacoma 10 Ply Tires", so I know it's still of reference to some people.
    I recently went through this myself. When I first got my truck I put Bilstein 5100s on it with a 1" block in the back. The front was set to the 4th notch with stock coils. I also added Mickey Thompson ATZ LT rated 10 ply tires. I would have to agree with previous posts that it rode like crap. The first thing I attributed this to was the Bilsteins being set so high. So I bought the OME 884 coils and dropped my 5100 to the 0" setting. There was no difference. Then I decided to pull the trigger on a set of Falken Wildpeak AT3 tires. Got them installed today and holy crap, NIGHT and DAY! The truck rides and drives sooooo much better.
    My 2 cents. nuff said...
    Armed in Utah likes this.
  17. Mar 8, 2018 at 11:26 PM
    REDdawn6
    REDdawn6 Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
  18. Sep 30, 2020 at 9:13 PM
    The605taco
    The605taco Well-Known Member
    Sawyer
    2014 4X4 short bed
    6112(notch 3) 5160 icon AAL Baja fogs and Ditch lights Headwaters seat covers Off roam phone mount Diamond back cover
    I will up date everyone how i like my 10 ply duratracs. They go on in the morning and get tested hunting this weekend!!! 265/75r16 for your information
  19. Sep 30, 2020 at 9:14 PM
    Bishop84
    Bishop84 Well-Known Member
    I had those exact tires. For reference C load are impossible to find, so even if you did go with them you would be SOL with a flat tire.
  20. Sep 30, 2020 at 9:33 PM
    Interbeing
    Interbeing A Canadian living in Texas
    Austin, TX
    2020 Tacoma TRD Off-Road 4x4 DCSB AT
    TRD Pro suspension with Headstrong 3 Leaf AAL, DV8 OR front slimline bumper & Engine Skid Plate, RCI OR high clearance bumper, CaliRaised Trail Edition Sliders, Spidertrax 1.25" Wheel Spacers, 265/75 16 GY Duratracs, wrapped the OEM wheels, OR Roof Rack, Extang Exceed Hard top Tri fold tonneau.
    I've been running DuraTrac E Load 265/75r16s for about 7,000 miles now at 38psi. They actually ride quite well, but I did drop about 1 mpg with fuel mileage though.
