Are 2” block rear spacers okay for daily driving?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoMan1265, Aug 3, 2021.
  1. Aug 3, 2021 at 7:41 PM
    TacoMan1265
    TacoMan1265 [OP] Member
    Fredy
    Toyota Tacoma SR5 2010
    2010 PreRunner Tacoma double cab. Mainly just wanted it for aesthetics for my father. Gonna get some new TRD 17” rims on the rig with some 265/70/17’s. Put a cheap 2” block spacer lift in the rear and partnered it up with Old Emus 60091 shocks since the old ones were leaking. Will the spacer cause any issues after the bigger tires are put on? I don’t mind slapping off the block lift just for some reassurance but is anyone running a 2 inch block lift with issues? I know it screws with the driveline angles but my dad just daily drives the truck doesn’t do much off roading with it. Regardless just don’t want anything detrimental happening. Just was looking for a nice leveled look.
  2. Aug 3, 2021 at 7:43 PM
    Bishop84
    Bishop84 Well-Known Member
    You don't need to lift the rear for tire clearance, they don't rub any pretty much any size.
    1" rear spacer is the general max for tacoma. 2" is fine but as you said driveline angles and axle wrap starts to be an issue.
  3. Aug 3, 2021 at 8:00 PM
    TacoMan1265
    Fredy
    okay thanks. I’ll keep that in mind. Starting to think I probably should’ve left the springs stock but the Old Man Emu shocks said they were for a 2” lift so probably should’ve just slapped some newer bilsteins on. Hope he doesn’t have any issues with it for I’ll feel bad lol.
  4. Aug 5, 2021 at 10:56 PM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    For me personally, blocks gave me axle wrap along with increase wear on my stock leafs. Going with a whole leaf pack replacement fixed the issues.
  5. Aug 6, 2021 at 12:18 AM
    pahaf
    pahaf Well-Known Member
    paul
    NorCal
    2015 Tacoma TRD Off Road
    Bilstein 6112/5160 OME Meduim leaf pack JBA HD UCA 3* retard exhaust gear TRD Pro Sema rims 265/70R17 Falken Wildpeak AT3W
    I ran 2” blocks for about 10k miles. It was fine. As long as you don’t accelerate like crazy, they will be fine
