Are 2010's really a terrible year?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by puppyduks, Dec 20, 2023.
  1. Dec 21, 2023 at 5:59 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Not trying to be rude but I never understood why people think carburetor vehicles were so reliable. Something about driving around with a fishbowl of raw fuel on top of a hot motor just never sat well with me. 21st century vehicles are light-years ahead in terms of safety and reliability
    winkel likes this.
  2. Dec 21, 2023 at 7:46 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Alot of oldschool people like them because they are simple and generally can easily be fixed with basic tools, no scan tools or special equipment needed.
    I have nothing against them, they run pretty good when they are working right.
    The problem with older vehicles is our trash fuel, it detroys anything that wasn't specifically designed for it (& degrades alot of stuff that is) and doesn't last more than a month in anything with a vented fuel tank, in a sealed tank it lasts a bit longer but it still degrades very quickly and once it does it can trash your fuel system if you try to run it.
    kergilman, jackn7 and b_r_o[QUOTED] like this.
  3. Dec 21, 2023 at 8:39 AM
    ace96
    ace96 Well-Known Member
    Western KY
    '11 SWB DC TRD SPORT
    AVS bug deflector, Weathertech digital fit floor mats, TRD skid plate w/ Sockmonkey decal, SOS Cocept sliders w/ Line-x, Pioneer 3500, Hybrid Audio Technology Mirus 6X9s & 6.5s, back up cam mod, Wet Okoles-front & rear, TRD exhaust, 17X9 XD Spy w/ Falken Wildpeaks, Avid light bar
    Fishbowl of raw fuel? I would be more worried about the small bomb in the fuel tank (sarcasm). In other words there is zero concern with either.
  4. Dec 21, 2023 at 12:11 PM
    kergilman
    kergilman Active Member
    Kevin
    Tualatin, Oregon
    2009 2TRFE Tacoma SR5 Access Cab
    2" lift, ebay rock crawlers, ebay carpet bedliner
    The carburetor venturi turned into a fishbowl?
    ToyoTaco25 likes this.
  5. Dec 21, 2023 at 12:45 PM
    SilTac10
    SilTac10 Active Member
    2010 TRD OR
    None
    I recently sold my 2010 (pictured <-) not because it had issues it was because I couldn't turn down a very good deal on newer Gen2. I'm far from a mechanic but the issues it had were not significant enough to call one. If it'a good enough deal for a cleaner truck I say go for it.
  6. Dec 21, 2023 at 2:10 PM
    TacoTuesday1
    SD CA
    I mean
    DI injectors are typically pricier and harder to get to
    that require an HPFP that wears out
    same thing with diesel
    gas PI is cheaper easier and simpler (what 2nd gen uses) working automatically through ECU without adjustments needed
  7. Dec 21, 2023 at 3:42 PM
    puppyduks
    puppyduks [OP] New Member
    I found the VIN of the truck I have a hold on. It's 3TMJU4GN2AM107082
    I was also correct the first time I posted about the price of it. The price is 21,000. Mileage is 77K.
    If anyone can guide me I would be grateful.
  8. Dec 21, 2023 at 3:45 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    It’s not worth .21 cents if the frame isn’t solid.
  9. Dec 26, 2023 at 5:16 PM
    mountaincrawler
    mountaincrawler Well-Known Member
    Hillsboro, OR
    2010 4x4 OR MT
    3" Lift, 35s, 4.88s, Front eLocker, Steel Bumpers, Sliders, URD Clutch Details 3" Lift (AllPro Leafs with Walker Evans 2.5" shocks & Walker Evans 2.5" Non Res Coilovers) Total Chaos UCAs 35" BFGoodrich All-Terrain T/A KO2 17x9 Fuel Offroad Shok D664 4.88 Yukon Diff Gears (ECGS 3rd member) Harrop Elocker (front) Pelfreybilt Front Bumper w/ center hoop Pelfreybilt High Clearance Rear Bumper Pelfreybilt IFS Skid Plate Pelfreybilt Weld On Sliders URD Stage 2 Clutch and Flywheel Relentless Cab Mount Chop Plates ARB Air Compressor AllPro U-Bolt Flip Kit Amp Research BedXtender HD MAX Relentless Bed Rail DUAL Quick Fist Mounts Sport Grille OEM Roof Rack Marshall Offroad Fabrication Bed Bars TEPUI Explorer Series Kukenam 3 Roof Top Tent
    Also a 2010 owner here. Had it for over a decade now, just passed 100k miles, and the only issues have been from the modifications I've done to it :D The leaf spring recall didn't even matter since I had already replaced it with an aftermarket leaf pack for the lift, win win.
  10. Dec 26, 2023 at 10:10 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Not really more reliable,but really cheap and easy too fix,unlike the complicated computer controlled expensive crap now.
  11. Dec 27, 2023 at 10:08 AM
    JMcFly
    JMcFly Well-Known Member
    Central FL
    2012 Tacoma SR5 4x4
    yeah, just swap out those side saddle gas tank bombs for a fuel cell in between the frame rails.
  12. Dec 27, 2023 at 9:28 PM
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    Just hit 190K on mine. Very few problems and none significant. Most issues were a blower fan motor that cost 125 bucks and 10 minutes to replace. All the trade rags will mention electrical issues and the blower fan was the culprit. They have a redesigned one that is quiet now.
  13. Mar 30, 2025 at 3:10 PM
    jmbasile2
    jmbasile2 New Member
    Not True, my 2010 Sport access cab LB was covered for a complete new frame at a Toyota dealership.
  14. Mar 30, 2025 at 3:12 PM
    Bishop84
    Bishop84 Well-Known Member
    Not covered as of the post in 2023, all are off warranty/recall now.
  15. Mar 30, 2025 at 3:13 PM
    #35
    jmbasile2
    Also I am a contractor with 220,000 on my toy and have little or no problems, just basic maintenance & tires Great truck looking to upgrade now but way scared of the 2024-2025 4 bangers.
  16. Mar 30, 2025 at 3:14 PM
    #36
    jmbasile2
    sorry did not know that, they should cover the issue In my opinion
  17. Mar 30, 2025 at 4:40 PM
    #37
    Williston
    Williston Well-Known Member
    2014 Tacoma DC SB 4x4 V6 040 [SL] SR5 Trim [ED] Entune Audio+ [TO] V6 Tow Package
    Stock (99.999%) OEM Bed Floor Mat, OEM Front Bed Rail Cargo Net and hooks, OEM Gentex Auto-Dim mirror w/Compass & Outside Temperature Display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. (winter), OEM All-Weather Floor Mats (summer).
    Some 2014's and 15's are still covered under the frame warranty provided they had the mandatory/required inspection and CRC application performed prior to the deadline. My truck is covered for 12 years from date of first service, so after early 2026, that's it. Upon request, a dealer will also perform an annual inspection of the frame. I have had it inspected in the fall each year since 2021, (NTF) and treat it every fall with Fluid-Film before winter sets in.
  18. Mar 30, 2025 at 5:57 PM
    #38
    Williston
    Some are still covered under the 12-year frame warranty provided they had the mandatory/required inspection and CRC application prior to the deadline. I had mine inspected and treated in 2021, about 6 months prior to the deadline. It is covered for 12 years from the date of first service. (2026) I was also advised when it was performed that upon request, the dealer would also perform a no cost annual inspection of the frame. I have them inspect it every fall with Fluid-Film before winter sets in.
  19. Mar 30, 2025 at 6:02 PM
    #39
    Bishop84
    2011 - 2017 got the extension. If you got the treatment and inspection you got the extension. 2005-2010 got the initial recall and inspection/undercoating but no large extension. Hence 2010 not an ideal year.
    https://static.nhtsa.gov/odi/tsbs/2019/MC-10169416-9999.pdf
  20. Mar 30, 2025 at 6:21 PM
    #40
    Williston
    Thank you for that clarification. Key piece of information when shopping for one.
    When I was searching for my truck, I didn't realize they had left out and abandoned the earlier years to fend for themselves. Good to know. :proposetoast:
