Are 285s worth it?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Mnewman03, Nov 13, 2018.
  1. Nov 13, 2018 at 5:28 AM
    Mnewman03
    Mnewman03 [OP] Well-Known Member
    2016 MGM DCSB TRD OR
    Finally getting around to lifting my truck so I'm trying to read up on lifts and tires. Are 285s worth it for a truck that will see minor off roading a couple times a month with all the driveline issues, trimming, etc?
  2. Nov 13, 2018 at 5:31 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Worth it that's all personal preference. I'm going to go with 255/80/17 it's a skinny 33 with my 3 inch lift. No trimming or rubbing at all.
    Cpngo, JDKred, GillyLink and 13 others like this.
  3. Nov 13, 2018 at 5:34 AM
    Clearwater Bill
    Billy
    Largo Florida
    Driveline issues are from the lift, not the tires. No lift is required for 'minor off roading'.
    Seems in your case a lift and 285s are a cosmetic package. Which is fine, if that's what you want.
  4. Nov 13, 2018 at 5:35 AM
    honda50r
    honda50r Not a Mallcrawler
    East Tennessee
    2nd Gen Tacoma
    Not Stock
    If you're asking this question. Then no
  5. Nov 13, 2018 at 5:35 AM
    Ravnikar610
    Ravnikar610 Well-Known Member
    Minnesota
    2016 OR DCSB
    Wider tires are only beneficial off road. If you are in an area that gets snow/ice go with skinny 33's. If you want an aggressive look with skinny tires, consider a heavy offset wheel or spacers.
    xxTacocaTxx likes this.
  6. Nov 13, 2018 at 5:56 AM
    SportsmanJake
    SportsmanJake Well-Known Member
    VA
    2006 Tundra
    285/25 r20s are definitely not worth it if you plan on leaving the pavement. It's only a 25 inch tire, you would probably get hung up on speed bumps.
    Auzea and Thuguon2.7 like this.
  7. Nov 13, 2018 at 6:06 AM
    Mtn Mike
    Mtn Mike Well-Known Member
    Spokane, WA
    2017 TRD OR AC
    Why are you lifting it if you aren't doing serious off roading?
    Edit: I ask, because if the answer is "looks", then 285s are definitely worth it because the truck will look better. In a truck that doesnt go off road, you've already moved beyond good handling, good gas millage, practicality, and cost effectiveness.
  8. Nov 13, 2018 at 6:21 AM
    Mnewman03
    When I say minor, I just meant I'm not going to be thrashing it, the trails I ride still require additional clearance at some parts.
    Mtn Mike likes this.
  9. Nov 13, 2018 at 6:32 AM
    Mtn Mike
    Spokane, WA
    2017 TRD OR AC
    Imo, if you're gonna lift it, upgrade your tires too. 285s look pretty good on a 3rd Gen.
  10. Nov 13, 2018 at 6:32 AM
    Trouble_The_Tacoma
    Trouble_The_Tacoma Well-Known Member
    Conrad
    Are they "Worth It." That my friend is a question only you can answer as none of us will be footing your bills. If you're doing it only for looks (absolutely nothing wrong with that), keep in mind that everything will be more expensive. Tires, fuel, etc. If you were doing it for a purpose or job related, it would be justified (but still just as expensive). But just as Unchained 5150 said, I think the skinnier 255's perform better off road and probably get better mpg's anyways. Sadly though I don't think 2nd or 3rd gens look as good as the 1st gens with 255s, but I digress.
    Also depends on what your final goal is for the truck and how long you plan on keeping it, right? If you plan on keeping it forever, you could try 285s for a set of tires and make a change later after your first hand experience with the 285s. If you plan on selling it in 4 years, keep it stock, or keep the stock parts at least. But if I was planning on keeping my truck forever (I want to hit 400,000mi,) I'd leave it as close to stock drivetrain as possible to reduce any unnecessary or unwanted problems down the road. My goal is to keep the truck efficient, light and nimble. Better for fuel economy, off-road and the engine in the long run.
    I think as long as you do it "right" You'll be happy. Don't be like my friend who lifted his Ram 7in then complains about not having torque because he doesn't want to re-gear. That's not good for the truck. Do your homework, write up your own pro's and cons list, then write up a budget and go with what your gut tells you. But trying out 285s for a while isn't a bad option. Tons of people on here who would buy them from you if you changed your mind.
    Good luck. Let us know what you decide.
  11. Nov 13, 2018 at 6:34 AM
    AddicTioN
    AddicTioN Forklift technician
    wyatt
    north carolina mountains
    2020 dclb off road
    Trimming and drive line issues? I have 45k on my truck with 285s on for about 40k of that. No trimming or driveline issues at all.
    SurfratTX likes this.
  12. Nov 13, 2018 at 6:36 AM
    Clearwater Bill
    Billy
    Largo Florida
    Lift gives clearance mostly for approach and departure angles, and of course only for the body.
    Tires are what raises the axle line.
    You can run full 33's in a 255 on OE or T4R wheels with no lift. No rubbing, trimming or cutting.
    JDKred, FishaRnekEd and CXYyuppie like this.
  13. Nov 13, 2018 at 6:38 AM
    medjah
    medjah Volleyballing
    Blake
    Austin, TX
    09 Barcelona Red DCSB SR5 TRD OR
    OME 887 Springs OME 90000 Shocks OME Dakar Light Duty Leafs Wheelers SuperBump Bumpstops w/ u-bolt flip Sway Bar relocate Red Brake Lines Ultimate Headlight Upgrade Airflow Snorkel Rear diff breather mod CMC AtTheHelm Bed Stiffeners AtTheHelm Front Rail Chock System Hood Struts
    I love my 255/85-16s with SpiderTraxx spacers. (2nd gen but still...)
    EDIT: Cooper ST Maxx
  14. Nov 13, 2018 at 6:43 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Wheel spacers or lift spacers? Shouldn't need wheel spacers to run them.
  15. Nov 13, 2018 at 6:44 AM
    medjah
    Blake
    Austin, TX
    Wheel spacers. I wanted that slightly more aggressive look. :D
    EDIT: lift is full OME
  16. Nov 13, 2018 at 7:20 AM
    Sub_Par
    Sub_Par Well-Known Member
    Buffalo NY
    2011 TRD Off Road
    I have skinny 33s on SCS Stealth 6 wheels and did have some rubbing on the mud flaps, and very little on the plastic at the back of the tire. Both were minor but I also have 3* of castor to push the tire forward. I had to trim for the same tires on my 2nd gen as they rubbed a lot worse in reverse on that truck. I feel like with the 17x8.5 wheel the 255s actually don’t “look” that skinny so I kinda get the best of both worlds.
  17. Nov 13, 2018 at 2:08 PM
    Kaiser1
    Kaiser1 Well-Known Member
    2017 tacoma
    I had to put wheel spacers on the front with my 285/75/16. Tires were rubbing on the upper control arm..
    Fast1, Skeou, ChadsPride and 2 others like this.
  18. Nov 13, 2018 at 2:12 PM
    doorsidedown
    doorsidedown Well-Known Member
    I love the look and function of my 285s but it really does take a toll on MPG. Works fine for me because it’s not a DD.
  19. Nov 13, 2018 at 2:13 PM
    AZBACKCOUNTRY
    AZBACKCOUNTRY Well-Known Member
    Doug
    AZ-between the hammer and the anvil
    11' AC TRD OFF-ROAD 4x4
    Pelfreybilt front aluminum bumper,AVID off road weld on sliders, RCI Offroad IFS & transmission Skid (steel), RCI LCA skids (aluminum),upper grillcraft, relentless hi clearance bumper,OEM color matched front grill color, ARE MX camper shell, wet Okole realtree seat covers,pelfreybuilt hi lift mounts,ICON 2.5 Coil-overs extended,, ICON tubular UCA's. Allpro expo leafs, SS extended brake lines.Bilstein 110 extended rear shocks.prinsu Cabrac.dwreck pod mounts OKLED 18w cubes.Baja Designs Squadron-R Sport, LED Wide Cornering, Ambers fog/driving 20" IGGY LED Single Row bar.tepui awning,rotopax 2 gallon, TREDs and mount , 100 watt renogy solar panel.victron 20 amp Bluetooth charge controller,Pro comp wheels - cooper st maxx 285/75/16 tires. Skygear bussman fuse relay smart box. ARB 12v plug hard wired for ARB fridge. Pelfreybilt gas tank skid. Smittybilt X2O 10K winch
    285/75/16 here in Az- Awesome!
    Cooper st maxx!
    SurfratTX, DRansom, butters_ and 4 others like this.
  20. Nov 14, 2018 at 4:10 AM
    Mnewman03
    I'm torn between 275s and 285s. I can get a C load 285 for less weight than the 275, just not wanting to have screwed up CV angles and vibes. Thoughts?
