Are 2wd Tacomas really built to handle offroad?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Vrbas, Jul 2, 2010.
  1. Jul 2, 2010 at 5:27 PM
    Vrbas
    Vrbas [OP] Well-Known Member
    This is specific for base models (not PreRunners). And I'm talking about from the factory, not w/ installed lifts or mud tires.
  2. Jul 2, 2010 at 5:36 PM
    mrbadwrench
    mrbadwrench Well-Known Member
    Cleveland Ohio area
    2014 GMC Sierra 4x4, 1988 Mitsubishi J53
    With the factory LSD on the new ones, they're a lot better than other open differential 2WD pickups.
    Our 2010 does a dang good job in light muddy ruts, slippery grass, loose gravel and soil, whatnot. Pretty much anything you might encounter on our flat farmland.
    Would I try a mudhole, pile of boulders, or jumble of logs? Of course not.
    Your mileage may vary.
  3. Jul 2, 2010 at 5:36 PM
    jodiddly33
    jodiddly33 Well-Known Member
    Jonah
    DFW
    2010 Golf TDI
  4. Jul 2, 2010 at 5:45 PM
    Vrbas
    Very nice. And yeah, i'm not talking about crossing rivers or climbing mountains, just the "outdoors" i guess you could say. I think when alot of people hear "offroad" they automatically assume anything that will showoff how their truck can climb over a ditch or clear moving water... i'm just talking basic, woodsy or dirtsy areas with terrain "fluctuation" as opposed to terrain "mutation".
  5. Jul 2, 2010 at 5:48 PM
    Juggernaut
    Juggernaut Captain
    Sacramento
    10 PreRunner AC Sport Rally 5 Spd
    Tail gate hose clamp, Front Windows 50% tint, fog lights, 894 backup light mod, LED license & interior.
    They will do just fine on fire roads and the like, the ground clearance on the little 5 lugs is impressive for how short they are.
  6. Jul 2, 2010 at 5:52 PM
    Vrbas
    Interesting. Think they'd be able to cross semi-shallow streams just fine?
  7. Jul 2, 2010 at 5:57 PM
    mrbadwrench
    Cleveland Ohio area
    As long as the stream base is pretty solid, sure.
    You have three things to worry about:
    1) Water depth.
    2) Water pace
    3) Streambed quality.
    Ours trucks across our foot deep gentle stream with no trouble at all, thanks to the reasonable water depth and slate/bedrock stream floor. I'll post a picture next time I have to drive out that way. (Our property is cut in half by a stream, ugh. It's very annoying. Haven't had time to engineer a bridge yet).
  8. Jul 3, 2010 at 7:23 PM
    Vrbas
    Well i figure maybe because the base model is a little lighter it might have a leg up on the heavier ones, but i dunno if that makes sense.
  9. Jul 3, 2010 at 7:44 PM
    005Tacoma
    005Tacoma Well-Known Member
    Thomasville, Georgia
    2005 Toyota Tacoma
    They're TRUCKS people!! If your scared to take them places where they might get dented or scratched or bogged down then you might want to get a blue Prius.
  10. Jul 3, 2010 at 8:23 PM
    KaoskrewPB
    KaoskrewPB -Empty-
    That has nothing to do with the OP's question.^^
    We used to have a 2wd stock basic 2 door Tacoma and it was just fine on fire road and things like that.
  11. Jul 4, 2010 at 7:51 AM
    uood8
    uood8 If You Search...You Shall Find.
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
    light offroading would be ok, if you plan to go offroad alot you should look at a prerunner/4x4 with the beefier suspension.
  12. Jul 4, 2010 at 8:00 AM
    AZBACKCOUNTRY
    AZBACKCOUNTRY Well-Known Member
    Doug
    AZ-between the hammer and the anvil
    11' AC TRD OFF-ROAD 4x4
    Pelfreybilt front aluminum bumper,AVID off road weld on sliders, RCI Offroad IFS & transmission Skid (steel),upper grillcraft, OEM color matched front grill color,OEM color matched-rear bumper, ARE MX camper shell, wet Okole realtree seat covers,pelfreybuilt hi lift mounts,Timcha shackle receiver,bulaculla trailer relocate harness,ICON 2.5 Coilovers, ICON tubular UCA's. Allpro expo leafs, SS extended brake lines.Bilstein 110 extended rear shocks.prinsu Cabrac.dwreck pod mounts OKLED 18w cubes.Baja Designs Squadron-R Sport, LED Wide Cornering, Ambers fog/driving 20" IGGY LED Single Row bar.tepui awning,rotopax 2 gallon, TREDs and mount , 100 watt renogy solar panel.morningstar PWM 30 charge controller. Pro comp wheels - BFG 265/75/16 AT's. Skygear bussman fuse relay smart box. ARB 12v plug hard wired for ARB fridge. Pelfreybilt gas tank skid. Smittybilt X2O 10K winch
    Still great clearance on the capable 2wd. I like the idea of turning a switch to make the front 2 weels turn :)
    Az is a rock pit ....Tough dirt, sand and when it does rain here it all washes off into some DEEP fast rivers.
    Azbackcountry
  13. Jul 4, 2010 at 8:02 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners.
    I think you'll be fine keeping to the offroad you are speaking of. These trucks are tough.
    Trying to build up your post count with usless post I see. Why don't you make your own thread? Save us from having to read this kind of stuff. Your comment had nothing to do with anything in this thread.
  14. Jul 4, 2010 at 8:30 AM
    O.C.
    O.C. Well-Known Member
    NE PA
    90 DLX => 08 DC Offroad
    Nerf bars,Rugged cover Future: Vent shades,Bull Bar
    With proper usage of the pedal on the right you should do just fine.
  15. Jul 4, 2010 at 1:41 PM
    toku58
    toku58 Well-Known Member
    HAWAII
    4x4 Beast!
    6" Fabtech Stage II, 17x9" Centerline Eclipse rims, with 12.5x35x17" BFG KM2's. On board air system,Toyota skid plate, spidertrax wheel spacers, TRD CAI w/AFE ProDry filter (21-90045),Flowmaster Dual exhaust, GrillCraft grill w/custom emblem, Custom Shifter, BushWacker fender flares, Hood struts, Underhood lights, TW driveshaft, Wet Okole seat covers, Dashlight mod, Many other little things to make the truck complete!
    HMMMN? In comparison to a str8 front Toyota? NO!
    But in comparison to the other production trucks in it's class, that are being built today? Hell YES!!!:headbang:
    Just depends on your measuring stick!
  16. Jul 4, 2010 at 1:52 PM
    Brunes
    Brunes abides.
    Rotorhead
    This makes the most sense to me. The OP seems to understand that too.
    They aren't going to put up great flexing pics and drive thru the stuff folks have with locked lifted 4x4's with winches...but they'll get you around. You have to decide for yourself if it's adequate for your goals/environment...
  17. Jul 4, 2010 at 2:37 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Airaid Short Ram Intake, 285x75R16 Mickey Thompson MTZs, 16" Konig Countersteer rims, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    A good set of tires will do wonders for you. A stock 2wd with a decent AT on it will out perform a 4wd with those crappy duelers on there.
    Driver experience counts for worlds too.
  18. Jul 4, 2010 at 3:27 PM
    bishtacova
    bishtacova Don't buy a Ford
    2009 DC PreRunner V6
    4 leaf TSB, reflash ECM, Eurostyle antenna, thule roof rack, bed extender
    There is a thread on off road trails where they are rated by grades such as zero through five, etc. Just look at a trail and determine your abilities with the estimated grade.
  19. Jul 4, 2010 at 10:25 PM
    005Tacoma
    2005 Toyota Tacoma
    My post was just trying to say YESS a base model can handle off roading.
    I don't care about post count!
    Why don't you STFU
  20. Jul 4, 2010 at 10:29 PM
    005Tacoma
    2005 Toyota Tacoma
    Matter of a fact it DID!
    They're tucks so YESS a base model can handle off roading.
    No matter if its a Base, Prerunner or 4x4 Just know your trucks capabilities on or off road.
