Are 3rd gen front brakes the same as 2nd gen
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rebel1851, Jan 1, 2022.
  1. Jan 1, 2022 at 9:51 PM
    rebel1851
    rebel1851 [OP] Member
    2006 4x4
    Will 3rd gen pads and rotors work on 2nd gen? Found a deal on marketplace, guy is selling brand new slotted and drilled rotors and brand new pads for a 100 bucks.
  2. Jan 1, 2022 at 10:59 PM
    No Shoes Nation
    No Shoes Nation Well-Known Member
    2008 Taco SR5 Access Cab 4.0 4x4
    Hmm . . . none as yet, that's why i'm here . . .
    You feel u need slotted/drilled rotors. There made for a reason, tacos really don’t fit that reason but it’s ur money
    wi_taco and Geeves77 like this.
  3. Jan 1, 2022 at 11:51 PM
    Desert Dog
    Desert Dog Well-Known Member
    Los Gatos
    2007 DCSB
    Work in progress
    I have same question. Someone is selling low mileage 3rd gen rotor and calipers on Craigslist off a TRD and wondering if they will fit my 2nd gen TRD. Coming up on 200K on my truck and thinking may be good to swap out to a newer set.
  4. Jan 2, 2022 at 6:23 AM
    ZColorado
    ZColorado Well-Known Member
    Near Boulder Colorado
    13 DCSB OR 6MT
    35's,Kings, NWF, 488, Harrop, SPC, Archive, Method, RCI, C4
    Yes. looks like the brakes are the same from 2005 to current (2022)
    https://www.rockauto.com/en/catalog...l+v6,3445493,brake+&+wheel+hub,brake+pad,1684
    Used brakes... I've pad slapped (just swapped pads) a number of times if the rotor surface looks perfect. but re-using used pads? thats not something I would suggest. QC976 pads can be had for <$30 online.
    Drilled and Slotted... enjoy your cracked rotors... I am definitely not a fan there.
    Hell, on my tacoma I am frustrated by how strong they are, I have to be careful to have a feather touch... and I am on 35s! (but I have the TRD OR version with the electric brake booster.)
  5. Jan 2, 2022 at 7:52 AM
    DG92071
    DG92071 Well-Known Member
    I had drilled a slotted rotors on my 96 4WD for a couple years with zero issues. It takes extreme high heat to make those cracks they're referring to, like in a race situation, but this is the internet where most everything is exaggerated to the extreme.
  6. Jan 2, 2022 at 8:02 AM
    jmahad01
    jmahad01 Well-Known Member
    Sort of. I have had those spider cracks on my track car with AP racing brakes. Obviously extreme conditions.
    More importantly, I have seen rotors spider crack on a street vehicle when hitting that puddle just right with the brakes warm. Everyone can have a different experience with all these variables.
    DG92071[QUOTED] likes this.
  7. Jan 2, 2022 at 8:54 AM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    I would bet 90% yes they are interchangeable. We know the wheels are swappable between gens (of same lug pattern), so this means the brake rotors should be a swap..
    And then I highly doubt Toyota being as conservative as it is, chose a new caliper design for the 3rd gen.
  8. Jan 2, 2022 at 9:21 AM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    And this helps him answer his question how?
    DG92071 likes this.
  9. Jan 2, 2022 at 11:14 AM
    rebel1851
    2006 4x4
    Thanks for the replies. My current pads and rotors still have a lot of life left, I was just curious if they would fit. I thought it was a good deal and thought about getting them just to have for the next time it needs pads/rotors.
    DG92071 likes this.
