Are 4x4 Tacoma's in SR5 Trim Factory Lifted?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Williston, Dec 12, 2024.
  1. Dec 12, 2024 at 12:52 PM
    Williston
    Williston [OP] Well-Known Member
    2014 Tacoma SR5 4x4 DC SB V6 AT Tow Pkg Entune+ Mostly stock with a few OEM mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. OEM All-Weather floor mats (summer).
    It has never occurred to me until I came out of the local ACE today to the parking lot. Parked right next to me was another very nice 2nd gen and I was surprised to see how much higher my truck was sitting as compared to theirs. The truck looked to be a regular 4x2 in standard trim. Not sure if it had 15" rims vs my 16", but my truck seemed to be much higher than just the 1" difference in tires and wheels would make. Any ideas/input on what would be attributed to the difference in height? The truck was much lower to the ground than mine.
  2. Dec 12, 2024 at 1:55 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    :worthless:
  3. Dec 12, 2024 at 2:46 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    How the hell do we know? We haven’t seen your truck or the other truck and nothing you’ve told us gives us any clues.
    If you want to know if your truck is lifted, get out your trusty tape measure, measure the vertical distance from the center of your hub to the edge of your fender flare, and report back.
    Also send pics of your suspension while you are at it.
    BTW: wheel/rim diameter has zero effect on truck height unless you have burned your tires completely off.
  4. Dec 12, 2024 at 3:07 PM
    4x4junkie
    4x4junkie Well-Known Member
    So Calif. (SFV)
    2018 TRD Sport ACLB MT
    OP's talking about 2nd-gens (so why is this in 3rd-gen??), OP's is probably stock and someone in a 5-lug parked next to him.
  5. Dec 12, 2024 at 3:32 PM
    TAZMINATOR
    TAZMINATOR Well-Known Member
    2017 Tacoma
    The truck you talked about that is parked next to your truck is 4cycl with 15" wheels (5 lug). Like mine had before I traded it in for my '17.
    2nd gen V6 engine models sit higher than 4cycl ones...
    Some people modify 4cycl trucks to sit higher than the stock height. For example, they swap wheels and bigger tires... And depending on the tire size, they add the lift so the tires can fit in.
    Williston[QUOTED][OP] likes this.
  6. Dec 12, 2024 at 3:39 PM
    Clearwater Bill
    Billy
    Largo Florida
    No
  7. Dec 12, 2024 at 4:35 PM
    Williston
    F: 21.25" / R: 22.50"
  8. Dec 12, 2024 at 4:42 PM
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    No is right!
    but comparing a 4x4 6lug or a RWD 6lug to a RWD 5lug the truck would be lifted in some capacity from the factory. SR5 4x4s aren't lifted from the factory.
  9. Dec 12, 2024 at 5:29 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    4x4s sit higher than 2x4s. Do the math...
  10. Dec 12, 2024 at 5:31 PM
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    Depends on which way you lay them down
  11. Dec 12, 2024 at 7:10 PM
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    "Stitch" & "Sumbitch"
    Hmmm ... Friday eve it is.
