Are 5100's safe?
Discussion in 'Suspension' started by 705 Taco, Apr 27, 2011.
  1. Apr 27, 2011 at 6:06 PM
    705 Taco
    705 Taco [OP] Zombie Killer!
    Dean
    Barrie ON / St. Petersburg FL
    2016 TRD OR AC
    --Stock 2016. --------------------------------------------------------------------------------------------- 2011 had 6 inch ProComp lift, Eibach coils on 5100 Bilsteins at zero, 1/4 inch Toytec spacer on drivers side, rear TSB, 1.5 inch Deaver AAL, ProComp blocks and rear shocks, 8000 lb Warn winch on a Trans4mer grill guard, 33 inch BFG AT's, 18x9 XD Monsters, PIAA headlights, PIAA driving lights, Pyro's blue LED gauges, LED strip below tailgate, Armor Lid hard tonno, Hidden Hitch, Dee Zee bed mat, Tint, XM, Garmin GPS, Ultra Gauge
    I just picked up my front 5100's to go with my Eibach coils. I was able to move the circlip to the .85 position useing just my fingers. Is this normal? It sure looks like a big pot hole would force the circlip out of the grove or the spring seat past the circlip. There is not much circlip surface area for the spring seat to sit on. Does the spring seat capture the circlip and stop it from expanding and popping out of the grove? I may be paranoid but the thought of the front suspension collapsing on the highway doesn't appeal to me.
  2. Apr 27, 2011 at 6:07 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Its fine. The seat prevents trh clip from comming out.
  3. Apr 27, 2011 at 7:40 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    If you installed the spring perch correctly (so it looks like a bell), the perch surrounds the c-clip and won't let it expand to move....
  4. Apr 28, 2011 at 2:36 AM
    705 Taco
    Dean
    2016 TRD OR AC
    Thanks for the info guys. I'm gonna pay the dealer 2 hrs labor to do it but I just wanted to make sure everything was right before I got there. I test fitted the spring on the spring seat and it looks like all the pics I've seen on tw but I just wanted to make sure. Thanks again.
