Are Access and Truxedo soft roll up tonneau secure?
Discussion in 'Tonneau Covers, Caps and Shells' started by JonF, Jul 14, 2009.
  1. Jul 14, 2009 at 10:44 AM
    JonF
    JonF [OP] Member
    NJ
    08 PreRunner SR5
    I'm looking at these types of tonneau's because they are easy to "stow on the fly" (unlike folding covers) and do not intrude into the bed space (unlike hard roll up covers). I use my bed to haul my motorcycle so i need every inch of space up to the front of the bed and some covers are either not meant to be removed and intrude into precious bed space.
    My tailgate has a lock and i know these covers have a latch, but since they are vinyl, what about the security of the cover itself? I understand these have some sort of cross-bow supports but the mfg web sites do not really go into detail on how exactly the supports are integrated in. Are there just 2-3 to keep the fabric from sagging or are they continuous and adjacent from front to back (think venetian blinds)? Continuous would be better from a security standpoint since it would be harder to cut a hole if theres bars all along the way.
  2. Jul 14, 2009 at 10:49 AM
    Rtrn2taco
    Rtrn2taco Nostalgia...
    Philadelphia
    08 DC PreRunner (silver)
    My access cover has 2 - 1'' round cross supports. Not exactly what I would term secure but the cover can not be opened without having access thru the tailgate.
  3. Jul 14, 2009 at 11:45 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    They aren't a hard cover so they can be cut thru or torn off. They aren't hard to get thru...but they are more protection than nothing...
  4. Jul 14, 2009 at 11:50 AM
    Scooter
    Scooter Canadian Member
    Manitoba, Canada
    08 Double Cab TRD Sport Short Box
    Pop n Lock Power Tailgate Lock, Bak Flip Tonneau Cover, Factory DLR installed, Defrost with A/C Off, EZ Down Tailgate Damper, Code Alarm Security System with Remote Starter, Rear Spring TSB, Ming rust proofing & paint treatment, 3M fabric protector, Cargo Mat, Scanguage II, DYI Illuminated 4X4 Switch, Versa-Gate box extender & cargo divider, Toyota Roof Rails, Grom USB Audio adapter with bluetooth, LED Bed lights, OEM Backup Camera with LCD Display Mirror
    I have a Bak Flip G2. It's a hard cover that cannot be opened until you open the tailgate. It flips up against the back of the cab, completely out of the way, or you can easily remove it by undoing two knobs.
  5. Jul 14, 2009 at 11:50 AM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
  6. Jul 14, 2009 at 12:01 PM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    Secure only in the "out-of-sight, out-of-mind" way, but in that way they work very well.
  7. Jul 14, 2009 at 1:21 PM
    JonF
    JonF [OP] Member
    NJ
    08 PreRunner SR5
    Well, i called both companies and apparently neither have any models with continuous bows embedded in the fabric. Both products have 2-3 small bows only leaving entire tonneau pretty much pure fabric succeptable to a knife cut. I'll just have to consider other types of more secure covers.
  8. Jul 14, 2009 at 1:29 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Yeah...The backflip is probably your best bet then- If you are in an area where someone cutting into your tonneau will go un-noticed- You need a hard cover.
  9. Jul 14, 2009 at 2:00 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Exactly... out of sight-out of mind. The tailgate lock is just a deterant.
    I have an Advantage Torza Top and it's a soft cover that folds. It doesn't have snaps or ridges that you can peel out. The bows are part of the fabric (so to speak). I have a pop-n-lock also.
    Any soft cover can get cut open if someone wants in there bad enough.
