Are all air filters equal?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hammer Slammer, May 18, 2014.
  1. May 18, 2014 at 9:14 AM
    Hammer Slammer
    Hammer Slammer [OP] Member
    Time to replace the air filter for the first time on a 13 V6. Is any one better than another?
    Buy from a dealer, auto parts store?
    KN a good idea?
  2. May 18, 2014 at 9:27 AM
    Joe D
    Joe D .
    I've always had good luck with OEM.
    I've read a few horror stories about guys with non-oem including K&N.
  3. May 18, 2014 at 9:37 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
  4. May 18, 2014 at 9:54 AM
    boomer6
    boomer6 Well-Known Member
    TN
    Tacoma TRD Offroad
    disabled DRLs disabled seat belt chime disabled the key in the ignition with door open buzzer Installed Illuminated 4wd switch circuit board Marker lights Flashing with turn signals Toggle switch ABS Disable Fog Lights on AnyTime Mod Changed to Yellow bulbs in the Fog Lights Converted interior lights to leds Installed oem roof rack Installed Firestone Ride Rite Air Bags and Daystar Cradles for the air bags Added oil catch can Relentless Tailgate Protector installed
    +1 OEM
  5. May 18, 2014 at 9:57 AM
    smmarine
    smmarine Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    What about the AFE pro dry? I thought that was a good one cause it's high flow, not oiled, and washable
  6. May 18, 2014 at 10:03 AM
    Jefes Taco
    Jefes Taco Well-Known Member
    Denver, CO
    14' DCLB TRD Sport supercharged
    Just buy the OEM filter from cheapest place you can find it. Don't overthink this. There's no real advantage to filers that flow 'more' as the factory filter flows more than enough to keep up w/ the engine. It will also filter best.
    Many aftermarket filters do flow more air. But more air means bigger holes which means bigger pieces of stuff gets through with more air.
    Regardless, you factory air filter can flow more air than the factory engine could ever need or use. It's when you start forcing air i.e. supercharger, turbo that you might exceed the factory paper filter.
  7. May 18, 2014 at 3:56 PM
    adamh1977
    adamh1977 Well-Known Member
    arkansas
    trd sport 4x4
    any time fog,tinted windows to 5% ,plasti dipped gun metal gray,toytec 5100's eibach coils ,led map and dome lights
    yea oem DON,T GO WITH K&N WET i had it on my for awhile and had to clean my MAF twice the last time it looked like it grew hair on it and after that i threw it in the trash
  8. May 18, 2014 at 3:59 PM
    MARSHBUSTER
    MARSHBUSTER Well-Known Member
    Jim
    Alamogordo NM
    2005 SR5 4X4 Tacoma TRD
    Grill Gaurd/ Winch Bumper, Mile Marker 9000 LBS Winch, Custom Head Ache Rack, Custom Rear Bumper, Marathon Camo Max 4 Seat Covers
    STAY AWAY FROM AFE DRY!!!!!!!!!! I am having my Head Gaskets done on my 05. When the mechanic got into the engine and found the LARGE AMOUNT of DIRT in my Intake he wasn't impressed. I am going back to OEM.
  9. May 18, 2014 at 4:08 PM
    car78412
    car78412 Well-Known Member
    Hudson Valley NY
    13 Tacoma reg cab 4x4
    OEM for engine. Anything else for cabin.
  10. May 18, 2014 at 4:11 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    OEM
    it's impossible to have more airflow with the same amount of filtering. So a lot of aftermarket filters may have more "flow", but at the cost of throwing dust into your engine
  11. May 18, 2014 at 5:08 PM
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    Napa gold
  12. May 18, 2014 at 11:29 PM
    BenMara
    BenMara That Asian RedNeck
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    TRD Blower, Ham Radio, DBA T2 Rotors
  13. May 18, 2014 at 11:40 PM
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    Not true, if you can increase the surface area of the filter you can increase flow without sacrificing the filtering ability of your filter. Hence why I LOVE the Donaldson dry filter in my Volant CAI. It's basically a very high end diesel engine filter adapted to fit in a CAI box!
    My vote is still OEM if you have a stock Tacoma. Oiled filters are like asking to have to buy a new MAF sensor every year, plus they plain old suck at filtering if they are not lubed 100 percent correctly.
  14. May 19, 2014 at 1:10 AM
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    Just installed URD TCAI. Love it. I got 23 MPG on my way to work (12 miles, 50 mph the whole way). I usually get around 21. The sound at WOT is amazing. I definitely recommend. My intake temperature is always the same as ambient unless I'm idling, then it'll rise about 3-4 degrees > ambient. Stock intake would rise to over 100 degrees when idling. Gotta love it.
  15. May 19, 2014 at 1:12 AM
    kyleTRDtaco12
    kyleTRDtaco12 Well-Known Member
    Kyle
    New Jersey
    2012 Toyota Tacoma Base DCSB 4x4 V6 6MT (202)
    TRD Cat-Back Exhaust TRD Sport Package Springs & Shocks (Front Linear Coil Springs, Rear TSB Leafs) Front & Rear Toyota/Bilstein 40mm Shocks) Silver Toyota 16" SR5 Wheels with 265/70/16 BFGoodrich Rugged Trail T/A Tires w/ Locks OEM Black-Chrome Housed Headlights (SR package) OEM TRDpro Grille Insert RokBlokz Rally MudFlaps w/ Stamped Logo OEM 'TRD Sport' Bedside Graphics TRD QuickShifter w/ TRD Shift Knob Hawk HPS Front Brake Pads w/ Brembo Blank Rotors OEM Front Aluminum Skid-Plate eBay TRD seat covers Rear Diff. Breather Mod A/C Drain Extension Mod OEM Fog Light Kit OEM Intermittent Wiper Switch OEM Bed D-Rings OEM Bed Mat OEM Door Sill Protectors Blacked-Out Badges (from Xrunner 205 Black Sand Pearl) Pop & Lock Tailgate Handle TruXedo TruXsport Roll-Up Tonneau Cover AVS BugFlector II Front Bug Guard AVS In-Channel Window Vent Visors TRD High Pressure Radiator Cap Stubby Radio Antenna Ultra-Gauge EM v1.2 w/ Windshield Mount BullaCulla 7-Pin Relocation Bracket Misc. Stickers
    x2 for aFe
  16. May 19, 2014 at 8:02 AM
    RearViewMirror
    RearViewMirror Saw things so much clearer once you... were in my
    Craig Christ
    State of Love and Trust
    2023 Subaru WRX GT Manual
    OEM / End Thread.
    Same thing with Oil Filter too
  17. Jun 11, 2014 at 8:57 PM
    Doomstacoma
    Doomstacoma New Member
    Florida
    Tacoma 4X4
    K & N air filter, Ipod adapter
    regarding K & N air filters I have been using them on all my vehicles including my 2006 Tacoma, I recently removed, inspected and cleaned the MAF sensor. I looked at it with a magnifying glass and found no sign of oil residue I cleans it on a coffee filter and no noticeable dirt was seen. I think the key is to use a light coat of oil per instructions and they work fine, honestly I have not seen any significant difference in MPG or power but I have not had to buy any new air filters in a long time so saved money there. I can get about 20 mpg if I drive real gentle and keep it below 70. However, that is difficult so 17-18 is what I usually get driving 75 or so.
  18. Jun 11, 2014 at 11:37 PM
    TheMuffinMan
    TheMuffinMan Banana Nut
    Coeur d'Alene, ID
    2023 Tundra Limited Crewmax 6.5' 4x4
    K&N let more air through by filtering it less. They are somewhat tricky to oil correctly and the gains are almost non-existent. I'd stick with OEM.
  19. Jun 12, 2014 at 5:31 AM
    jethro
    jethro Master Baiter
    Geoff
    Southern NH
    2020 Ford F-150 Lariat 5.0L V8
    I bought the cheapest one they had at AutoZone. Think it was an STP. It looked better quality than the OEM that came out and it was $18.99. I like to replace them every 10k miles since I live on a dirt road.
  20. Jun 12, 2014 at 5:36 AM
    RearViewMirror
    Craig Christ
    Better
