Are all DA polisher created equal?
Discussion in 'Detailing' started by Venom, May 25, 2020.
  1. May 28, 2020 at 5:41 AM
    ace96
    ace96 Well-Known Member
    Western KY
    '11 SWB DC TRD SPORT
    AVS bug deflector, Weathertech digital fit floor mats, TRD skid plate w/ Sockmonkey decal, SOS Cocept sliders w/ Line-x, Pioneer 3500, Hybrid Audio Technology Mirus 6X9s & 6.5s, back up cam mod, Wet Okoles-front & rear, TRD exhaust, 17X9 XD Spy w/ Falken Wildpeaks, Avid light bar
    If you can use a rotary you will have no trouble with any DA you choose.
    Venom[QUOTED][OP] likes this.
  2. May 28, 2020 at 11:11 AM
    Venom
    Venom [OP] Well-Known Member
    Kevin
    Massachusetts
    It took me awhile to get used to the PC 7424 from using a rotary.
  3. May 29, 2020 at 5:44 AM
    Venom
    Kevin
    Massachusetts
    Thanks for the replies everyone!
  4. May 29, 2020 at 11:58 AM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    For comparison purposes, I'd call a Flex 3401 a low speed rotary with limited random orbital motion.
    ace96[QUOTED] likes this.
  5. May 30, 2020 at 4:57 AM
    Venom
    Kevin
    Massachusetts
    With RPM between 160-480 no load, it's a very low speed rotary. Which it's not bad for a beginner.
    There's a video showing how to turn the 3401 into a free spinning orbital DA, just by removing a gear. The gear can easily be put back in.
  6. May 30, 2020 at 5:11 AM
    Too Stroked
    Tom
    Quite true. Then again, I've only found the need for high speed on my rotary when I'm working on gelcoat on fiberglass boats. For cars (with paint), I don't get nearly as frisky. The beauty of that lower speed is that although you can do a ton of correction with the Flex, it's relatively hard to burn through anything for a beginner.
    ace96 likes this.
  7. May 30, 2020 at 5:54 AM
    Venom
    Kevin
    Massachusetts
    When I started detailing there was no DA polisher, or none was used as a DA polisher. Meguiars started with the 7424 for polishing cars. Time has differently change. Now I mostly use the rotary for major defect removal or headlight restoration, glass polishing etc. I had to remove a scratch from one of my vehicle that a fingernail will get caught on. I remove it with 3M Perfect-It compound and 3 passes with a wool pad on the Dewalt rotary. This was the last time I used a rotary for paint correction. It's been a few years. Grant it the rotary is smoother with a faster correction rate but it's not needed for majority of the detailing I do. This is why I have the 7424.
    I wouldn't say a DA polisher is relatively hard to burn through paint for a beginner. Just have to use common sense. Some people want to remove 100% of swirls, marring in their paint. So, they try to remove all defect without thinking it through. Then people will hold the polisher in 1 area, start burning through the paint, or holding the polisher on an edge where there thin paint. Knowledge goes a long way.
  8. May 30, 2020 at 7:47 AM
    ace96
    Western KY
  9. May 30, 2020 at 7:55 AM
    gorram
    gorram Well-Known Member
    2016 Limited
    Can't decide which polisher, why not all of them rolled into one:
  10. May 30, 2020 at 8:23 AM
    ace96
    Western KY
    That is interesting. I haven’t seen that yet.
  11. May 30, 2020 at 2:26 PM
    Venom
    Kevin
    Massachusetts
    I look the operator of the Flex was the only one using downward pressure. Yvan and Levi was mostly one handed the polishers. When the Flex operator use one hand while polishing temperature went down slightly.
  12. May 30, 2020 at 2:31 PM
    Venom
    Kevin
    Massachusetts
    If it ever comes out. It was supposed to be released last year but Lake Country postponed the release date.
  13. May 30, 2020 at 2:40 PM
    Venom
    Kevin
    Massachusetts
    Plus Yvan side had dings that created high spot which made him go through faster. I believe there was a discussion about this video on Autogeek Online.
    Don't mind I goofed posting this.
  14. May 30, 2020 at 3:25 PM
    Venom
    Kevin
    Massachusetts
  15. Jun 1, 2020 at 5:37 PM
    #35
    Scott W
    Scott W Well-Known Member
    Scott
    Saranac Lake, NY
    2018 Tacoma TRD PRO. Calvary Blue.
    TRD Performance Air Intake. TRD Shift Knob. KTJO 4X4 Red TRD Push Button Start/Stop. Calvary Blue FOBIK by AJT Design. 12volt Solutions Remote Start with CAR:LINK Smartphone Remote Start and GPS app. Sprint Booster V3 Throttle Response Enhancer. AFE Silver Bullet Throttle Body Spacer 46-38010. 2" Supreme Suspension Lift Kit. TOYO 265/75R16 Open Country A/T2. EGR Matte Black In-Channel Vent Visors. REK GEN Offroad Mud Guards. AMP RESEARCH Power Steps. JDMastar 10000lumes LED Low Beam Lighting T1. JD Mastar Raptor LED Lighting. TRUXEDO Tonneau Cover.
    I have both Griot’s Polishers. They are really nice. Orbital and variable. They have up three different pad densities. Pads are attached by velcro and they stay put.
  16. Jun 3, 2020 at 3:04 PM
    #36
    Steve-O
    Steve-O Well-Known Member
    SW Ohio
    2007 Tacoma 4x4, TRD Off-Road
    It is, as is their G8.
    I have a Flex 3401, the Griot's G8 and G9, and a PC7424 (first generation).
    I can't say that the G8 or G9 do any better of a job than the PC7424, but they both have features that make them nicer to use.
    The Flex 3401 has been nicknamed "The Beast" for a reason...it is just a much sturdier machine than any of the others in my collection. Being forced rotation, it also doesn't stall out on curvy panels. It corrects faster, but you do have to exercise caution using it. It is not perfectly suited for a beginner, but it also doesn't require all that much experience to use one effectively.
    I also used to have a full rotary, the key part being "used to". I used it once - it flung shit everywhere, and then I managed to have it catch on something and jerk out of my hands, causing some pretty decent damage to the bumper of one of my old cars. I tossed it aside and never tried it again after that...it just wasn't worth the potential for disaster. If I were to ever try one again, it would be on a car I cared nothing about until I got the technique down perfectly.
    Too Stroked likes this.
  17. Jun 3, 2020 at 6:18 PM
    #37
    Kabanstva
    Kabanstva Well-Known Member
    People that say that honestly have no business using ANY power tools. I've been using a Flex for 99% of every correction I've done in the last ten years. Never jumped on the Rupes bandwagon although I do have their ibrid for tight spots. I'll move on from a Flex when I see a better tool. So far I have not seen that better tool.
    Too Stroked and ace96 like this.
