Are all gen 1 sr5 seat belts interchangeable ??
Discussion in '1st Gen. Tacomas (1995-2004)' started by stener, Aug 24, 2015.
  1. Aug 24, 2015 at 11:27 AM
    stener
    stener [OP] Member
    brian
    alberta.Canada
    1999 tacoma trd
    I have a 99 sr5 in need of new drivers seat belt ,does any one know if any year of gen1 tacoma seat belts will fit? Or does it have to be a 1999? Thanks
  2. Aug 24, 2015 at 1:52 PM
    Laxtoy
    Laxtoy Dog is my backseat driver
    Maltby, WA
    99 3.4l 5 speed 4WD 2023 Limited DCLB 4WD
    Fox 2.5 DSC resi CO's w/ 700lb King Coils, Camburg uca's, T-100 rear leafs, 13WL Tundra brakes, 1" 4crawler body lift, 295/75/16 Hankook MT, Ruff Stuff u bolt flip, 10" Fox LSC resi shocks turned back on custom mounts, home built rear high clearance bumper with dual swing outs, Diode Dynamics SSC2 Pro rear floods, Skid Row front and transfer case skid, home built transmission skid, Mercerfab sliders, home built front bumper, Badlands Apex 12k winch with synth line, 4.56's, ARB rear locker, home built rack with CVT Mt. Shasta, eBay snorkel, Sierra LEDs 20" dual amber/white light bar, Diode Dynamics SS3 Max amber fogs, Mini D2S projector retrofit, Blue Sea ML-ACR, dual Odyssey PC1200's, 100 watt solar panel, 20 plate heat exchanger/home built shower kit
    i've had issues finding this answer, the part numbers vary as far as I know based on year, color, cab style and seat type. I called the Toyota dealership parts department to get a part number to verify, you might be able to get a for sure answer from them in terms of interchangeability. I'd think if you were taking a 97 belt to put in a 99 that had a similar color if that even mattered, and it came out of a similar truck, like both were extended cab bucket seats or regular cab bench seat you'd be sure it'd fit, otherwise it's maybe a difference of a few inches in length, but I think the buckles are all the same as long as they're front seats to front seats and not from the rear in extended/double cabs.
    my truck for example: driver side 99 SR5 ext cab bucket seat moon mist grey part number: 73220-04090-B0
    Another piece of info that might really help, my sister has a 97 DLX ext cab bench seat moon mist grey and she swapped the passenger side belt to the driver side when it failed and it's working for her
  3. Aug 24, 2015 at 4:05 PM
    stener
    stener [OP] Member
    brian
    alberta.Canada
    1999 tacoma trd
    Appreciate the info . My original thought was to do just that,swap the belts but on my truck they are different mounting bolt paterns. The part number will be helpfull. Thank's again
