ARE bed cap coming. What could I be doing to get ahead of things?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tonykarter, Oct 20, 2018.
  1. Oct 20, 2018 at 9:38 PM
    tonykarter
    tonykarter [OP] Crappie Savant
    Snuff Gully, Texas
    2018 DCSB 4x4 Sport 1993 4Runner SR5 4x4, 411,000 miles
    Pine tree air freshener
    What are some of the things you wish you would have done before your bed cap was delivered?
    I married my tacoma likes this.
  2. Oct 20, 2018 at 9:43 PM
    black coffee
    black coffee A is A.
    Glenn
    509
    2010 AC 4x4 SR5 V6
    IDK. Move the fridge?
    bryanjoh, Jeremy4x4, Dkurtz42 and 2 others like this.
  3. Oct 20, 2018 at 9:48 PM
    DIRTT_Fish
    DIRTT_Fish Well-Known Member
    2017 TRD OR DCSB
    Cbi t3, 888, HD Dakar, b110, wheelers bumps,ubolt flip, spc uca, +4" rear brake lines.
    Drink more beer.....
    Clean your rear window. And clean the glass on the shell. Gets hard to reach lol
  4. Oct 21, 2018 at 2:44 AM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Put foam weatherstrips or black silicone seal the holes in the front top bed wall corners, get your wiring started to install a light,
    and most importantly (seriously!) check that the bed is square with the cab of the truck- mine was not square and I had to remove the cap to have it done with my Toyota warranty.
    vuTron and I married my tacoma like this.
  5. Oct 21, 2018 at 3:06 AM
    jwctaco
    jwctaco Retired, going slow in the fast lane
    Jim
    SW Michigan
    23’ T4R
    Pull your bed side covers off and seal under them, I used a quality black silicone. Then seal the head rail , remove it,bead of silicone underneath. Then the gap between the head rail and the side covers. Get a good tailgate seal. Do a search on here for more tips.
    Mtn Mike and I married my tacoma like this.
  6. Oct 21, 2018 at 5:48 AM
    tonykarter
    Snuff Gully, Texas
    Bed being straight. That's one I probably would not have considered. Will do all of this. Where do most people run the 12V wires and to which fuse number do they attach it?
  7. Oct 21, 2018 at 7:14 AM
    1911tex
    1911tex Well-Known Member
    2018 Silver Metallic Limited
    Are you installing a bed cap or foldable cover? I had a cap before...did not like it due to having to remove it for any kind of height above bed sides forward. Even if the load is to the rear, you have to tie down the rear of the lifted cap making rear view mirror useless. The vast majority of new installs are foldable or retractable with makes much more sense for me. Just a thought.
  8. Oct 21, 2018 at 7:19 AM
    Greg617
    Greg617 Well-Known Member
    Greg
    New England
    2010 5-speed 4x4
    Dents and scratches... Fox 2.5 Factory
    Consider getting bed stiffeners before your cap weight can warp the bed. Totally something that can be done after putting on the cap though.
    I find the additional tie-down points very useful.
  9. Oct 21, 2018 at 7:49 AM
    COS_TACO
    COS_TACO Well-Known Member
    Colorado
    2018 SR5 ACLB V6 4x4
  10. Oct 21, 2018 at 7:52 AM
    COS_TACO
    Colorado
    What are everyone’s thoughts on bed stiffeners? Don’t need if only topper is going on? Suggested if topper + rack + goodies are going on top too? Can a topper actually warp the bed walls? It seems the topper weight would be pretty welll distributed along the 3 walls (if it’s topper only).
  11. Oct 21, 2018 at 8:04 AM
    Markc1024
    Markc1024 Well-Known Member
    I'd agree alone should be fine. I believe that the topper itself has a degree of structural integrity that would help to keep things from flexing out.
    COS_TACO[QUOTED] likes this.
  12. Oct 21, 2018 at 9:00 AM
    jwctaco
    Jim
    SW Michigan
    23’ T4R
    Plus one for the bed stiffeners, piece of mind.
    COS_TACO likes this.
  13. Oct 21, 2018 at 9:10 AM
    COS_TACO
    Colorado
    I guess it also wouldn't hurt having the extra stiffness for when I throw the XT250 in the back and strap her down to the sides.:thumbsup::bikewheelie2:
    jwctaco likes this.
  14. Oct 21, 2018 at 9:33 AM
    jwctaco
    Jim
    SW Michigan
    23’ T4R
    I have Total Chaos bed stiffeners, great product. They also additional tie down points on them, very handy.
  15. Oct 21, 2018 at 11:07 AM
    tonykarter
    Snuff Gully, Texas
    Thanks! Never heard of bed stiffeners until now, but yes, they would be helpful: 200 lbs on the Z-series cap, way too much camping stuff in the bed, rack above, with a pirogue or fishing kayak on it. Will research these for sure.
  16. Oct 21, 2018 at 11:13 AM
    baldbeardedtaco
    baldbeardedtaco Well-Known Member
    FL
    18 TRD Sport DCSB MGM
    I seriously don’t see the point of bed stiffeners, just because you install a shell. All the fear mongering because of the composite bed I don’t get it- I had a sport trac previously which has a composite bed and had a shell installed for 9 yrs straight and it didn’t have any issues people warn about Here.
    I didn’t have any extra weight on the shell either… maybe that matters but I think imo it’s worthless just for a standard shell install. If my bed walls collapse after I install my shell I will personally apologize to everyone that suggested the stiffeners
    Just my 2 cents
  17. Oct 21, 2018 at 11:18 AM
    Methadras
    Methadras Well-Known Member
    South DFW, TX
    2021 White TRD Sport 2WD
    Fox 2.0 Lift, JLA Uppers, Dual battery setup, ARB-Double Barrel compressor, CBI skidplates, CBI Covert bumper, Winch, various light setups.
    Bed stiffeners do a couple of things. One is true up your bed or at least help true it up. The second thing it does, believe it or not, is improve your ride by stiffening that bed from roll flex and moves a lot of that stress to the stiffeners. I love mine. Actually improved the feel of my ride.
    I married my tacoma and jwctaco like this.
  18. Oct 21, 2018 at 11:29 AM
    baldbeardedtaco
    FL
    im Sorry, I don’t see it under normal driving circumstances or just adding a shell to be beneficial or necessary just because of it being a composite bed.
    Obviously do whatever gives you piece of mind but I have had experience with a composite bed and shell with no issues so that’s what I’m basing my decision on (granted it wasn’t a Tacoma)
  19. Oct 21, 2018 at 11:40 AM
    Methadras
    South DFW, TX
    That's fair. A lot of it might be subjective. In some cases depending on the cab installation might actually help true up beds on their own. Even without a bed cab, if you do any off roading, those stiffeners are a real boon imho.
  20. Oct 21, 2018 at 12:19 PM
    AverageGuyTaco
    AverageGuyTaco Well-Known Member
    2017 TRDOR-DCLB
    I have had an ARE MX cap for just a year on my 17 TRDOR. I didn’t use bed stiffeners and have had no issues with bed warping. Ive been on several trips with a rack on top and about 80lb worth of stuff. Lots of rough dirt roads. I was in Death Valley for three days a few weeks back.
    Biggest issue is sealing up all the holes and gaps in the bed. I agree on the front bed rail. Get some black silicone and seal that up. Much easier to do with no cap on. Also I was not happy with the front seal that comes with the cap so I replaced it.
    The rear window on the ARE doesn’t seal well at the corners. There is a huge gap. I used left over tailgate seal to fill in those gaps.
    Even with all the gap sealing, I still get dust in. On my trip to Death Valley I got into some really fine dust near Eureka Dunes. It got through the seals a bit. I need to follow up to see if I can fix this.
