Are bigger tires gonna hurt my clutch?
Discussion in '1st Gen. Tacomas (1995-2004)' started by backwoodz30, Aug 12, 2014.
  1. Aug 12, 2014 at 7:07 PM
    backwoodz30
    backwoodz30 [OP] Active Member
    Sylamore National Forest
    Bonestock old mans truck
    Brushgaurd no mods.
    I bought a 2000 tacoma with 30x9.50r15 tires and suspect its had this size or stock size its entire life. I'm right at 145k now on what I assume is the stock clutch. If I upgrade to 31x10.50 will it hurt the clutch. I know its about time to change it but I don't want to until I really need to. Clutch is still strong.
  2. Aug 12, 2014 at 7:15 PM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    No I run 31x10.50x15. All I have ever had on the truck. I also had heavy mud terrain tires. Clutch will be fine if you don't ride it.
  3. Aug 12, 2014 at 7:22 PM
    crazy joker
    crazy joker Well-Known Member
    Jesse
    Charlotte area, NC
    2014 DCLB sport 4x4
    Real men just call it camping
    Bigger tires basically have the same efect as taller gears. That will cause the clutch to work harder. Though it may wear a little faster, I doubt the clutch would be damaged.
  4. Aug 12, 2014 at 7:39 PM
    2000GTacoma
    Snow Hill NC
    Not that much difference here. Yes an inch taller and wider. But actually very close to stock.
  5. Aug 12, 2014 at 10:20 PM
    DSMJRV
    DSMJRV Well-Known Member
    justin
    Corona, CA
    I used to smoke my clutch a lot more when I had 33s grabbers that were 70lbs without the rim... climbing and sand smoked the clutch a few times, I tend to be hard on clutches though... anyways now that I went back to 31 ATs I havent smoked the clutch since....
  6. Aug 13, 2014 at 3:15 AM
    vern650
    vern650 Well-Known Member
    brandon
    hyrum, ut
    '97 4x4 taco xtra cab 3rz/5spd
    HBS leveling kit, 31x10.50 mudders, header/imco exhaust, rear billies, LR ucas, home brewed onboard air, cb radio
    clutch will be fine with 31"s
  7. Aug 13, 2014 at 5:45 AM
    backwoodz30
    Brushgaurd no mods.
    Thanks guys.
