Are camburg CO's on par with Icon and king?
Discussion in 'Suspension' started by Nmwill, Nov 12, 2013.
  1. Nov 12, 2013 at 9:45 PM
    Nmwill
    Nmwill [OP] Well-Known Member
    William
    Albuquerque
    2010 Tacoma 4x4 trd
    Blacked out emblems and grill. 265/75's shortened antenna
    I know the burg Co's are just SAW's. for those of you that have/had them. Are they on par ride and quality wise with icon and King? Honestly I just want red. And I don't need resi. Also are the burgs the same travel as the extended travel icons?
  2. Nov 14, 2013 at 10:45 PM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    Burg's are legit man......I believe they're already extended travel. Not sure how aggressive they're valved if you DD a lot but they're always re-valvable.
  3. Nov 15, 2013 at 8:55 AM
    jr114
    jr114 Well-Known Member
    Jon
    SoCal
    Truck
    Icon Ext travel CO, Icon tubular uniball UCAs, Maxtrac Spindles, Icon RR rear w 2"aal.
  4. Nov 15, 2013 at 9:56 AM
    ToyTec Lifts
    ToyTec Lifts Toyota Suspension specialist Vendor
    Rocky Mountains
    Toyota's are awesome
    Camburgs are a rebadged SAW so yes they are definitely a good setup. I'm partial to ICON's for 2.5 body coilovers though but thats just me.
    I believe they are standard travel since there is not a requirement to change the UCA's
  5. Nov 15, 2013 at 3:22 PM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
  6. Nov 20, 2013 at 10:15 PM
    Nmwill
    William
    Albuquerque
    2010 Tacoma 4x4 trd
    Anyone ridden in a truck with each type. Ie one with burgs one with icon one with king?
  7. Nov 21, 2013 at 10:48 AM
    Thetequilaworms
    Thetequilaworms Carlos@Camburg.com Vendor
    Carlos
    Huntington Beach
    Our Coilovers are not built in house. Sway Away still makes them for us. The diff is that they are not a standard 8" coilover, they are built specifically to work with our arms as where a King shock would be too big of a shock and you would be bottoming the shock out too soon.
    on paper they can all be an 8" travel shock, but collapsed and extended lengths vary. Our coilovers are set up to be ran with our arms so that is really where you will see travel gains.
    If you insist on running a king or an icon, we can provide you with the right shock specs and you can have either company build you the shock to those specs.
    PM me or give me a call at the shop if you guys have any other questions.
    Carlos @ Camburg
  8. Nov 21, 2013 at 11:57 AM
    Downsouth Motorsports
    Downsouth Motorsports Downsouth Motorsport Vendor
    Mission Valley, San Diego
    Front King 2.5, Coilovers, Camburg UCA, Rear King 2.0 Shocks, Lots of Tinted Windows, Cherry Third Owner
    Please correct me if I am wrong, but just for clarification when Carlos is referring to "his arms and the length of others shocks not being correct for his arms", he is referring to his long travel kit, not a upper arm kit.
    Sway-a-way/Camburg use a over cap top cap which makes the collapsed length shorter than other brands.
  9. Nov 21, 2013 at 3:13 PM
    motoxscott
    motoxscott Well-Known Member Vendor
    Scott
    Huntington Beach, CA
    2008 Prerunner
    Their seems to be some confusion in here so I will clear everything up .....
    1) Camburg bolt-in coilovers are manufactured by Sway-Away to our specs. They are an extended travel version designed to work specifically with our upper arms to maximize wheel travel. They are on par with every high end shock out there, after all we all use Eibach coils, billet aluminum and cad plated shock cylinders. Comes down to price, color, valving, wheel travel, etc.
    2) What Carlos explained has to do with 8" coilovers for long-travel kits, not bolt-in coilovers. All bolt-in coilovers are specific for the truck, some aren't extended travel for uniball upper arms though.
    - Scott @ Camburg
  10. Nov 21, 2013 at 3:56 PM
  11. Nov 22, 2013 at 11:32 AM
    Nmwill
    William
    Albuquerque
    2010 Tacoma 4x4 trd
    Awesome people are starting to chime in! So questions. To the camburg reps. What materials are the shocks? Can you list what metal is used for what? Ie shaft, body, valves. I know icon posted there materials. But can't find where. Also what's the Valving in comparison to icon and king? In between? Softer then both? Firmer then both? Springs rate is 650 correct? Question to Micah. Can dsm rebuild and re valve the burgs?
  12. Nov 22, 2013 at 12:16 PM
    Yes we can.
  13. Nov 22, 2013 at 7:04 PM
    motoxscott
    Scott
    2008 Prerunner
    Our Camburg coilovers for the Tacoma use an Eibach 13" x 650/lb coil, for guys that run heavier winch bumpers, etc I suggest using our FJ coilovers since they use a 14" x 700/lb coil and valved slightly different. This offers better control and you don't need to preload the coils as much with the added weight.
    Shock shafts are Nitro-steel like Sway-Away and Icon, no plating to flake off, etc.
    Shock cylinders are DOM tubing that is then honed to exact specs and tolerances. The outside is silver cad plated like everyone else.
    We use hi-temp viton shock seals, which is an available option for some other companies shocks.
    Aluminum parts are machined from 6061-T6 billet aluminum (not cast) that is then type 2 anodized red for the exterior parts.
    We valve our shocks for a plush all around ride for both street and off-road use, not just one or the other.
    I have personally ridden in trucks with everyone's coilovers and I have yet to find one that rides better than ours in my opinion. Camburg, FOX, Icon, King are all great shocks .... different strokes for different folks.
    - Scott @ Camburg
  14. Nov 23, 2013 at 12:19 AM
    Nmwill
    William
    Albuquerque
    2010 Tacoma 4x4 trd
    Awesome respones! +1 for burg. So a few more question Scott. My truck is a DD. will have a front skid. And possibly down the line a hybrid bumper and maybe a winch. 95% of the miles I drive are on pavement. But i would love to improve that ride. That pothole on my drive to work they jars my truck. I want it to feel like a small bump. Those nuisance speed bumps. Turn into "what speed bumps". And for the 5% my truck is on dirt I want that 10 miles of rough rutted dirt road to my fishing spot to turn into a nice scenic drive. I want that difficult trail that has kept me from exploring new spots to turn into a yellow brick road to adventure. In essence. I want improved on road ride. As well as better handling and damping for mild offroading. Do you feel the camburgs paired with your upper control arms fit those needs? Sure I could just go with icon or king. But to be honest I feel from the research I've been doing that camburgs don't get the respect and recommendation they deserve. And honestly... I really want red
  15. Nov 23, 2013 at 12:57 AM
    numbah57
    numbah57 GIVE THE MALL A BREAK...WHEEL THAT SHIT
    kahai
    Maui, Hawaii
    09 tacoma 2.7 Beaten not Babied
    URD ARB G2 PELFREY BAMF LCE AFE
  16. Nov 23, 2013 at 3:15 AM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    Pick a color dude.....if you really want red, Burg's are the way to go. All the big shocks are going to give you what you described.
  17. Nov 23, 2013 at 10:00 AM
    Nmwill
    William
    Albuquerque
    2010 Tacoma 4x4 trd
    That answers my question. Which in essence is. Our burgs comparable to icon and kings. Or comparable to toytec and OME
  18. Nov 23, 2013 at 10:31 AM
    numbah57
    kahai
    Maui, Hawaii
  19. Nov 23, 2013 at 10:40 AM
    straycat241
    straycat241 maXXXed out mid travel
    paul
    montclair, ca
    PreRunner TRD off road 4x2
    airaid intake, jba headers, jba exhaust, DMZ enginecage, King 2.5 coilovers , 1.25camburg uca's, total chaos lca's, shock hoops with Icon 2.5 piggybacks, camburg 4.0 Spindles, Defined engineering SUA, King 2.5" Shocks w/Reservoir, King 2.5 Bumpstops,shocktacobumper,moto metal 951's, compartment locks, blackgrill,Glassworks fenders front and rear,ViS racing glass hood,PIAA 510s,hella 500's,black rebadge,fabtech spare tire holder,tailgate delete,mudflaps delete,cobra 19 ultra iii
    op the saw/camburg coilovers are totally on par with icon or king co's. I've ran them for a few years and they held up really well and were valved nice, and only had to rebuild them once. I only switched to king co's because they had a resi, and the burgs needed more work/parts to run a resi. the burgs are also good price point at around 1050 while most co's with resi will run more
  20. Nov 23, 2013 at 10:44 AM
    numbah57
    kahai
    Maui, Hawaii
    Here's my setup
