ARE Cap Leaks on my 2020 TRD Off Road
Discussion in '3rd Gen. Tacomas (2016-2023)' started by DSizemore, May 4, 2021.
  1. May 4, 2021 at 6:27 AM
    DSizemore
    DSizemore [OP] Member
    Many of us are aware of the structural issue with the front bed rail and the leaks that come with all truck caps on our 2016+ Tacoma’s. I’m wondering if any of you guys have heard of a better fix than stuffing the void full of silicone and hoping for the best. I have a CX ARE and live in central KY. Any of you guys know a dealer who is aware of the problem and maybe has come up with a solution?
  2. May 4, 2021 at 6:50 AM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    Silicone alone won’t work. There are typically two foam blocks that are needed to fill the larger holes. Did they put those foam blocks in the front corners?
  3. May 4, 2021 at 6:58 AM
    ohioboater
    ohioboater Well-Known Member
    2017 DCLB 4x4 Sport
    The place I bought my topper from used 3M Strip Calk to deal with the gaps left by the differing heights between side and front bed rail caps. It's got some mechanic slang name that I can't remember. Butyl rubber strips that can be molded like silly putty. Waterproof, doesn't shrink, removable, and doesn't leave a residue like silicone.
    They also removed the front rail cap and sealed from underneath. It's why I ended up with a Leer instead of an ARE. The Leer dealer knew all about this issue and was up front that there would be a small labor charge to do the sealing right. The local ARE dealer claimed that no sealing was needed with Tacomas.
  4. May 4, 2021 at 7:23 AM
    DSizemore
    The dealer used those strips you reference and the bed is dry everywhere except the two front corners. Foam blocks...? Interesting. That would work, but they did not use them. First I’ve heard of them actually. Can you elaborate further...?
    Have you experienced the same leak that was fixed with foam blocks? I sure like the concept better than a tube of silicone in each corner!
  5. May 4, 2021 at 8:12 AM
    NoVa TRD Sport
    NoVa TRD Sport Well-Known Member
    Alexander
    Northern Virginia
    2021 Army Green TRD Sport
    Leer cap
    Toyota part nos. 6254104010 and 6254204010. About $32 each.
  6. May 4, 2021 at 10:19 AM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    My ARE was installed with a "Toyota gasket kit" and hasn't leaked in 4 years. Sounds like your installer skipped a step.
  7. May 4, 2021 at 12:31 PM
    NoVa TRD Sport
    Alexander
    Northern Virginia
    Leer cap
    Sounds like that's a standard bulb gasket for the underside of the shell, that sits on top of the bed rails. Most installers won't remove the bed rails to seal underneath them. But, that's precisely where the leakage comes from. (Water is splashed up through the hollow fenders, and finds its way through the rail clip holes.) The task the owner has to do, before having the shell installed, is to seal the front corners of the bed, and underneath all 3 bed rails.
  8. May 4, 2021 at 5:22 PM
    DSizemore
    Thanks guys. I’ll take a look at the kit and blocks. Parked level or on an incline, two puddles can be found after every rain harder than a sprinkle. If anyone knows of a dealer familiar with this problem please pass it along. At this point, I’m not above driving several hours for a reseal that solves the problem.
