Are crush washers NEEDED for Diff and Transfer fluid change?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TnShooter, Sep 17, 2014.
  1. Sep 8, 2016 at 5:45 AM
    Jakefromflorida2009
    Jakefromflorida2009 Member
    Jake
    1995 Single cab Tacoma 3.4L V6 4X4
    Whoops!
    Sorry for the mix up, and thanks very much for the information! Hope to knock this out soon.
  2. Sep 8, 2016 at 5:52 AM
    Tacologist
    Tacologist Well-Known Member
    Bob
    Tenessee
    05 Double Cab Shortbed
    Rear leaf suspension. Home done tailgate re-inforcement.
    I have been using a few turns of folded over, about as wide as a #12 wire, teflon tape high on the treads, near the head of the bolt for years in place of crush washers and never had a leak.
    I make sure no tape is left on the threads at each change.
  3. May 2, 2017 at 11:49 PM
    beavis87
    beavis87 Well-Known Member
    El Paso
    '10 Silver TRD OR
  4. May 3, 2017 at 3:53 AM
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    Old or new washer has nothing to do with over torqueing. Op, I would save money and time and just use old ones. Never had a leak and never replaced one. Now I have replaced rubber oil drain washers
  5. May 3, 2017 at 4:43 AM
    ejl923
    ejl923 Well-Known Member
    Eric
    Western Mass
    15 DCSB TRD Off Road
  6. Jul 3, 2017 at 5:53 AM
    Atomic
    Atomic Master Cylinder
    New Mexico
    13 TRD Sport Double Cab Long Bed
    My front differential lower drain plug is slowly leaking....good to have part no replace rather than reuse the gasket.
  7. Jul 3, 2017 at 7:55 AM
    abqnurse80
    abqnurse80 Well-Known Member
    Nic
    ABQ, NM
    2012 FJ Cruiser
    Bilstein 5100 all around, first clip front. AVS window visors, BFG AT KO2s. JBL.
    I didn't use the new washers when I changed diff, transfer and transmission, but I do have a set of new ones if they start leaking
  8. Jul 3, 2017 at 1:51 PM
    ejl923
    Eric
    Western Mass
    I always buy new gaskets, if your going through the trouble obtaining fluids
    And planning, buy the gaskets. It's not a huge financial hit. I always buy 2 or 3, you'll needem again, and good to have if you screw something up
    O'DubhGhaill, Atomic and buzzkill911 like this.
  9. Jul 3, 2017 at 2:15 PM
    jacoblb
    jacoblb Well-Known Member
    MD
    2010 AC 2.7L
    Yeah you should change the gaskets. It's a couple bucks compared to close to $100 for the oil. Why wouldn't you? Some people on here will tell you that you need to change your engine oil every 3k but don't need to change the crush washer, makes no sense.
  10. Jul 3, 2017 at 4:25 PM
    Atomic
    New Mexico
    ^^^ agreed.
    jacoblb likes this.
  11. May 24, 2018 at 4:42 PM
    quetzal
    quetzal Well-Known Member
    Mario
    Long Beach, CA
    '02 XtraCab SR5 TRD 4x4 5spd
    All-Pro UCAs, King 2.5 C/Os, All-Pro Expo Leafs, Bilstein 10" Shocks
  12. May 24, 2018 at 7:58 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    I just use Teflon tape and reuse the old washer. Never had a leak. I think it makes the plugs easier to get out the next time around too.
    b_r_o likes this.
  13. May 24, 2018 at 8:03 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    You can get multiple uses out of any washer If you don't over-torque it
    VA SOFTACO likes this.
  14. Nov 17, 2023 at 11:50 AM
    Dady83
    Dady83 Well-Known Member
    2020 Tacoma SR5
    Hi there, if u don't mind I'd like to have those part numbers, thx
  15. Nov 17, 2023 at 12:06 PM
    #35
    SH10151
    SH10151 Farang
    SF Bay Area
    2022 SR AC UP 4x4
    They are super cheap and there’s no reason not to have a box with a few on hand.
  16. Nov 17, 2023 at 1:46 PM
    #36
    TnShooter
    TnShooter [OP] The TacomaWorld Stray
    Deogee
    07' TRD Off-Road, Auto
    STOCK
  17. Nov 18, 2023 at 8:57 AM
    #37
    Dady83
    2020 Tacoma SR5
    Just drained my transmission pan, ONLY 2 1/4 quarts, I had heard about it for a long time buy IT'S REAL, some trucks come with low ATF fluid levels
