Are door panels swappable from 01-04 to a 2000 model Tacoma
Discussion in 'Technical Chat' started by illbeda, Oct 5, 2018.
  1. Oct 5, 2018 at 9:28 PM
    illbeda
    illbeda [OP] Well-Known Member
    Interested in knowing if anyone has first hand experience with swapping a fully molded door panel (I believe 01 to 04 models) in place of the rather unimpressive flimsy 2 piece cardboard affair that was used on model years 95 thru 2000? Anyone?
    I would imagine they would have left the punched metal door frame alone,but you never know if some upstart engineer came along and changed it around a bit. Who knows......
    Actual first hand knowledge would be greatly appreciated.
  2. Oct 6, 2018 at 11:56 AM
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    I did this on my 99. The panels are a direct swap, keep in mind the following:
    01-04 uses a different size speaker
    different window switch trim and window switches
    has a tweeter in the door panel
    doesn't have the red courtesy light
  3. Oct 6, 2018 at 1:34 PM
    nzbrock
    Noah
    San Marcos, TX
    Yes the tweeter mounts to the door panel itself. If you don't want a tweeter then you don't have to hook it up. I mounted some aftermarket tweeters in its place.
    https://www.tacomaworld.com/threads/tiffany-the-taco.374490/#post-10346612
  4. Oct 7, 2018 at 12:42 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Do you want to sell your old ones??
    I like them much better the newer ones I got had been painted hot pink
  5. Jan 4, 2024 at 11:59 AM
    RGHRDR
    RGHRDR Active Member
    Bobby
    99 Tacoma
    Hello Taco world, can anyone tell me if i can hook up the master window switch and passenger switch from a 99 to 2003 master switches. Im switching door panels and noticed that the panel differs a lil.
  6. Jan 4, 2024 at 12:29 PM
    nzbrock
    Noah
    San Marcos, TX
    If you are putting 01-04 panels in your 95-00, then you have to use the 01-04 switches. I believe the wiring connectors are different as well.
  7. Jan 4, 2024 at 12:32 PM
    RGHRDR
    Bobby
    99 Tacoma
    so basically needing the whole wire harness?
  8. Jan 4, 2024 at 12:34 PM
    RGHRDR
    Bobby
    99 Tacoma
    or doing a lil splicing of wires and hope it works.
  9. Jan 4, 2024 at 12:35 PM
    nzbrock
    Noah
    San Marcos, TX
    You can re-pin the connectors, but you will need the connector for the 01-04 switch.
    I put 01-04 4 Door master switches in my 99 2 door. I bought the switches on ebay with the pigtail attached to the connector. I just de-pinned the 01-04 connector and re-pinned with the matching wires from my stock connector.
  10. Jan 4, 2024 at 12:40 PM
    RGHRDR
    Bobby
    99 Tacoma
    not quite electrically smart enough to do that on my own. lol
  11. Jan 4, 2024 at 12:53 PM
    RGHRDR
    Bobby
    99 Tacoma
    I see on ebay that they sell the actual 2 door master with bezel but no pig tail.
