Are early 2nd gen. Tacomas worth buying?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Moto521, Dec 11, 2023.
  1. Dec 18, 2023 at 10:57 AM
    #41
    Moto521
    Moto521 [OP] Well-Known Member
    2006 Tacoma DCSB TRD OR
    00R0R_fPUmO43urQZ_0pn0t2_1200x900.jpg So it's a done deal. Sitting in my driveway now. I know I paid too much, but I think overall I did good.
    I thank all of you for your input.
    TacoLolz, dk_crew, TegoTaco and 3 others like this.
  2. Dec 18, 2023 at 11:00 AM
    #42
    Strictlytoyz
    Strictlytoyz Well-Known Member
    Charles
    HA\/\/AII
    07 Shitbox
    @Moto521 , looks clean...congratulations!
    Moto521[OP] likes this.
  3. Dec 18, 2023 at 11:21 AM
    #43
    bevo2000
    bevo2000 Well-Known Member
    Plano, Texas
    2005 Tacoma DCLB 4.0 4x4
    Absolutely it's worth buying.
  4. Dec 18, 2023 at 11:21 AM
    #44
    bevo2000
    Plano, Texas
    She's a beauty. Congratulations!
    Moto521[QUOTED][OP] likes this.
  5. Dec 18, 2023 at 11:23 AM
    #45
    bevo2000
    Plano, Texas
    That red looks so sexy. My favorite color (although mine is white).
    OffroadToy[QUOTED] likes this.
  6. Dec 18, 2023 at 12:53 PM
    #46
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Nice ride ya got there! Congratulations!! :cheers:
  7. Dec 18, 2023 at 1:02 PM
    #47
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Make sure the rear locker works and hasn't seized...
  8. Dec 18, 2023 at 4:03 PM
    #48
    Moto521
    Did a full system check on the initial test drive. It did act up at first going into 4lo and locking the rear diff. But after a few tries both would function right away.
    Guy I bought it from had it for 3 years. And was born in the late 1940's. And only put 10k miles on it.
    Original owner was a Ford dealer tech. Full service records were provided. Judging from the exterior/interior wear this thing wasn't beat on.
    3JOH22A[QUOTED] likes this.
  9. Dec 18, 2023 at 4:07 PM
    #49
    GilbertOz
    GilbertOz Driver
    CA
    2014 AC V6 MT 4WD, 84K miles
    FOX 2.5, Deavers, ARB, OTT, 4xInnovations
    I had the same experience w/ intial unreliable activation, while testing 4WD, 4LO, and rear diff lock, when I was test-driving the used 62K mile 2014 4.0L TRD-OR I'm now driving.
    Almost certain that what's going on here is the actuator motors in the transfer case & the diffs work fine, but the wiper arm electrical contact points don't make complete contact on the first few tries. It takes switching things back and forth several times for the wiper arms to wear through a thin layer of surface oxides on the seldom-used contacts, at which point they eventually start making full contact & the various 4WD functions start engaging normally.
  10. Dec 18, 2023 at 4:12 PM
    #50
    TacoTuesday1
    SD CA
    you got any more details on that thing?
    Looks good
  11. Dec 18, 2023 at 4:24 PM
    #51
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    That's why I asked. The rear locker actuator can seize if not used regularly, more likely to happen if the truck has been mostly street driven.
    Check the thin breather lines going to the rear locker actuator, transfer case actuator, and front diff (ADD) actuator are in good condition. They are just rubber hoses similar to the type used for the windshield washer nozzles, and can definitely crack and fall off after 18 years.
  12. Dec 18, 2023 at 4:29 PM
    #52
    Moto521
    Well it isn't all sunshine and lollipops.
    I still need to hit up the Dept. of motor vehicles(tomorrow, I promise).
    California $$$. The sun visors have about 2" of play. That's going to drive my OCD nuts, so those will be replaced. Brake pedal/parking brake is low. Will pull rear drums for adjustment/inspection asap. Brake fluid needs a full on bleeding.
    I'll probably do a full on service just because the retired career technician in me won't feel satisfied until I do everything myself.
    dk_crew, Sprig, 3JOH22A and 1 other person like this.
  13. Jan 16, 2024 at 5:39 PM
    #53
    Moto521
    One month followup
    Finally got a chance to take a long drive.
    Mpg is what was expected. 21.5 @ just below the speed limit.
    Drivers seat !!! Has tons of adjustment range, but the steering wheel feels too far away if I go to far back. Going to try the seat risers.
    Sun visors suck. Found online it was a common failure. Honda had that exact same issue around the same time. Probably the same supplier.
    Compass display lights up but seems to only show NW
    Speedo is about 3 mph fast at hwy speed
    Still trying to "adjust" to the 5 foot bed.:(
    Rear brakes were probably original, and at the service limit.Replaced drums/wheel cylinders/shoes with oem. Full manual brake bleed. Brake operation is much better , but still lacking. Common on this model?
    Overall, I think it's a nice upgrade from my 1gen Tundra (2wd)
    TacoLolz and bevo2000 like this.
